21st February 2020, 20:53 | #7421 | Link | |
Pig on the wing
Some tests; Hot Fuzz is an easy clip with clear scene cuts. The correct amount of keyframes in the testclip is 13. Threshold 0.5, it misses all scene changes Threshold 0.1, it misses a lot of them Threshold 0.05, it still misses some quite obvious ones Threshold 0.025, it begins to place too many (29) Threshold 0.03, still too many (19) Threshold 0.035, almost the correct amount (14) The default encoding missed two very obvious scene cuts which the histogram one was able to find. The histogram one had one false detection in a scene of higher motion. The false one was in the middle of the scene and slightly less blurry, and I suspect that red text on a white shirt skewed the detection routine there even more.
22nd February 2020, 18:27 | #7422 | Link |
Pig on the wing
I uploaded the source clip here: https://drive.google.com/open?id=19c...J08OaQbfBIHUjm
To encode, I cropped off the black borders and downscaled with Spline36 to 1280x544. The histogram sc detection picks up frame 805 incorrectly, others seem good to me. For some reason, I am unable to tweak the --scenecut and --scenecut-bias parameters to get the standard sc detection to pick up frames 380 and 582 which are perfect cuts between scenes.
24th February 2020, 08:05 | #7423 | Link | |
Angel of Night
25th February 2020, 11:43 | #7426 | Link |
Herr
I'd appreciate it if devs here, that releases x265-builds, comments on what compiling-setting they use!
My favorite is compiler-setting is "Optimization: Compile for speed", although maybe it doesn't matter that much since x265 is mostly coded in assembler. |
27th February 2020, 12:33 | #7428 | Link |
Is it viable to make a --frame-dup mode 2 without generating VFR video? I don't know why x265 spends so many bits on duplicated frames.
Example: 1) Download wallpaper on https://wallpaperscraft.com/download...4996/1920x1080 2) Create avs with ImageSource("planet_clouds_light_star_94996_1920x1080.jpg",start=0,end=199,fps=23.976) 3) Encode avs with x265 x64 10bit, crf 22, preset slow and --csv-log-level 2 --csv 4) Open csv and examine used bits https://i.imgur.com/vSwL4KQ.png Why frames with 100% skip 64x64 need to use more than one thousand bits? Why the bits variation on duplicated frames, shouldn't almost all of them have similar size in bits? x264 has much less variation on bitrate with same video. x64, 10bit, crf22. I've filed an issue on x265's bugtracker, https://bitbucket.org/multicoreware/...t-variation-on Last edited by fauxreaper; 28th February 2020 at 21:59. Reason: Wrong quote |
1st March 2020, 21:20 | #7429 | Link |
change from 3.3+1 to 3.3.+2 that haven't been mention anywhere??? command give "unknown parameter" with 3.3+2
--no-rskip --> --rskip 0
AMD Ryzen 9 5950X, 32GB DDR4-3200 CL16, RTX 3060, 2TB NVMe PCIE4.0, NAS with 8x16TB HDD Last edited by jlpsvk; 1st March 2020 at 21:33. |
2nd March 2020, 01:46 | #7430 | Link | |
Frame-dup should be fully compatible with constant frame rate, since it is putting in skip frames, not changing frame durations (which was how WMV9 did it back in the day). |
2nd March 2020, 04:24 | #7431 | Link | |
Basically, --rskip 0 is (old) --no-rskip, (old) --rskip 1 is --rskip, --rskip 2 and --rskip 3 use a different method of analysis to decide when to perform the skip. --rskip-edge-threshold controls how much recursion the encoder skips, if you've set --rskip 2 or 3. From my limited testing it seems to still need |
2nd March 2020, 18:11 | #7432 | Link | |
AMD Ryzen 9 5950X, 32GB DDR4-3200 CL16, RTX 3060, 2TB NVMe PCIE4.0, NAS with 8x16TB HDD |
2nd March 2020, 20:33 | #7433 | Link |
RD Level Rskip Mode Skip Recursion Heuristic 0 - 4 1 Neighbour costs. 5 - 6 1 Comparison with inter2Nx2N. 0 - 6 2 CU edge denstiy. 0 - 6 3 CU edge denstiy with forceful skip for lower levels of CTU. What is the default? --rskip 0 is the same as no --rskip ? https://x265.readthedocs.io/en/defau...mdoption-rskip I hope I added it correctly. Code:
New OptionParam With { .Switch = "--rskip", .Text = "Recursion Skip", .Expand = True, .Options = { "Disabled", "0 - RD Level 0-4 Neighbour costs", "1 - RD Level 5-6 Comparison with inter2Nx2N", "2 - RD Level 0-6 CU edge denstiy", "3 - RD Level 0-6 CU edge denstiy with forceful skip for lower levels of CTU"}, .Values = {"", "0", "1", "2", "3"}}
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 2nd March 2020 at 20:50. |
3rd March 2020, 08:57 | #7435 | Link |
Pig on the wing
So --rskip 1 is now the same as --rskip previously?
Once again, would be very nice to know which use cases would benefit from the other settings. To me it looks like the changes commited lately have something to do with cartoons and anime, which I never touch myself.
3rd March 2020, 11:13 | #7436 | Link | |
So, your option mapping would not be correct. 0 is disabled. 1 is both those modes, depending on RD. Default is actually 1, and not disabled, unless --tune grain is used, according to the docs.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 3rd March 2020 at 11:15. |
3rd March 2020, 11:24 | #7437 | Link |
Appears so, yes. I've not changed my command line since the change and it just defaults to --rskip 1 now.
I'll have a play around with --rskip 2 and 3 shortly but looks like there's also a --rskip-edge-threshold setting to take into account with those too. I didn't find the speed difference between the old --rskip and --no-skip to be worth the trade off though, so unless the speed drop-off with --rskip 2 and 3 is substantially less then I don't expect them to be of much use. |
3rd March 2020, 12:29 | #7438 | Link |
@nev
I think I got it now, thank you. Code:
New OptionParam With { .Switch = "--rskip", .Text = "Recursion Skip", .Expand = True, .Options = { "Undefined", "0 - Disabled", "1 - RD Level 0-4 Neighbour costs, RD Level 5-6 Comparison with inter2Nx2N", "2 - RD Level 0-6 CU edge denstiy", "3 - RD Level 0-6 CU edge denstiy with forceful skip for lower levels of CTU"}, .Values = {"", "0", "1", "2", "3"}},
6th March 2020, 11:21 | #7439 | Link |
Angel of Night
If you want to use the bleeding edge builds, you have to be prepared for things to break occasionally, and UIs to catch up later. Otherwise, stick to stable builds or the build provided by the UI.
7th March 2020, 01:30 | #7440 | Link | |
結城有紀
It could be confusing to write 3.3+X in version number indicating a future 3.4 dev version. |
