5th May 2015, 13:30 | #1985 | Link |
Troubleshooter
I tested both the original NNEDI3 and OpenCL versions with my Optimus system using the Nvidia GPU, and they both look like they work without problem. Both seem to preform equally on my system (30-32ms render times on the video I tested them both on). NEDI seems like the better performing video doubler on my system (compared to NNEDI3). NEDI renders the same video in 17-18ms on my system (nearly twice as fast as NNEDI3).
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. |
5th May 2015, 14:15 | #1991 | Link |
Suptitle, MediaPlayer.NET
That's quite easy via the custom render script.
For my case, it's a ~1% GPU usage difference. Like I said, slightest margin. |
5th May 2015, 14:17 | #1992 | Link |
Anyone else getting out of memory problem after switching between the two NNEDI3 versions running x64 Edition? I can't replicate the problem on my machine...
EDIT: BTW, I can't even replicate this problem on x86 Edition if I don't set my decoder queue too high. Last edited by Zachs; 5th May 2015 at 14:21. |
5th May 2015, 14:23 | #1993 | Link |
Not necessarily switching between the two NNEDI versions, just simply changing from no renderscript to either NNEDI3 version will do it, I did focus on the shader version though and I think it was more likely to happen with that.
5th May 2015, 14:26 | #1994 | Link |
Just a heads up. I released v.16 which works around NV's blank screen / no luma problem when NNEDI3 OpenCL is used following a device reset. Let me know if this 'fixes' the problem for you (it's likely you'll still see the broken image for a split second before the proper one replaces it).
5th May 2015, 19:00 | #1998 | Link |
Troubleshooter
I haven't encountered it. Does it occur instantly, or after a certain amount of time with NNEDI3 running?
direct3d, mpdn, nnedi3, opencl, reclock |
