Old 6th April 2020, 20:02   #7521  |  Link
MeteorRain
結城有紀
Originally Posted by Patman View Post
I used the x265_git and it happened too. Or is it a mirror in preparation for git usage?
That's not what I mean. Note the word style.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 6th April 2020, 21:10   #7522  |  Link
Patman
Patman's Avatar
My fault. I only read your entry quickly when I was on the road and read it correctly again this evening You could be right about that.
Patman is offline   Reply With Quote
Old 6th April 2020, 23:15   #7523  |  Link
_kermit
The values are specific to the professional grading monitor that was used to master the HDR. The premise is that the content will have no visible-by-creative-intent values outside of what the mastering monitor was capable of.
You need to use the values that are appropriate to the mastering monitor, which isn't something you can know from anything in the source other than this metadata. So, copy it if you have it. Otherwise leave it blank rather than specifying an incorrect value.
Not defining it in the command line would re-use what's in the source then?
to add: If so, is that also true for --max-cll ?
_kermit is offline   Reply With Quote
Old 6th April 2020, 23:59   #7524  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Not defining it in the command line will simply not set it. x265 has no vision into the source metadata.
Also yes, this is true for --max-cll.
Old 7th April 2020, 10:31   #7525  |  Link
dREV
dREV's Avatar
I suppose it's as somebody wrote few posts ago about things breaking when grabbing the latest as I tried the latest build Barough shares x265 v3.3+17-gdf2ac512d https://forum.doom9.org/showthread.p...30#post1905930 appears both --profile main444-12 --input-csp i444 and --profile main444-10 --input-csp i444 are broken (if somebody else can also confirm) and may include 4:2:0 10 bit equivalent. 8 bit works fine.
Hope Barough will see this post.
I don't know if it's related but as of far as I've tested x265 v3.3+2-gbe2d82093 has stopped working telling me Error message for your references: System exception - Access violation when Prefetch(1) is in the end of the script of AviSynth+ 3.5 but runs when (I think its disabled) Prefetch(0) is set. No issues with x265 v3.2+22-a8a2c4c37267.
I'm just writing this in case they may be related or not. I really do not know if Prefetch is even worth using since the AviSynth thread is of no help neither the documentation.
Another question in regards to an interest in figuring out if a speed in my encoding with AviSynth+ is possible.
As I recall the settings for slow and veryslow were changed sometime ago and prior my encodes were a bit faster with my settings which have hardly changed since that implementation (likewise with my AviSynth filtering) but I dunno if choosing slower is the same as veryslow as I cannot tell just doing several encode tests at my end.
These are my current settings:
--level 4.1 --crf 16.0 --aq-mode 3 --aq-strength 0.80 --deblock=-1:-1 --me sea --merange 57 --psy-rd 1.00 --rc-lookahead 40 --bframes 16 --ref 6 --subme 7 --qcomp=0.75 --fades --limit-refs=0 --no-limit-modes --rd 6 --psy-rdoq 5 --rdoq-level 1 --tu-intra-depth 4 --tu-inter-depth 4 --ipratio 1.4 --pbratio 1.3 --max-tu-size 32 --ctu 64 --qg-size 64 --limit-tu 0 --max-merge 5 --no-rect --colorprim bt709 --transfer bt709 --colormatrix bt709 --preset veryslow --sar 1:1 --input-depth 16 --profile main444-12 --input-csp i444 --tune animation --no-sao --no-amp --no-strong-intra-smoothing --dither
In 720p if that matters and yeah I am going overboard on some settings. I'm attempting to modify to shorten it some and just found out --ref 8 exists or I wasn't paying much attention to the documentation but doesn't seem to work at this resolution.
Wish the developers would give why the encoder stops to work on some settings instead of just stopping it with no explanation. Well, thanks if anybody gives any suggestions or critique.
dREV is offline   Reply With Quote
Old 7th April 2020, 13:13   #7526  |  Link
_kermit
now I'm confused, sorry that I keep asking:
if used, the correct values must be provided
or
it doesn't matter and they should not be provided?
(for both)
Actually there is more to it:
If I don't provide in particular max-cll, that metadata is missing in the mkv and that data is for example used by the Radiance Pro.
So I think this should be in the new, at least, file since it was in the original?
Old 7th April 2020, 13:42   #7527  |  Link
MythCreator
or
(for both)
It doesn't matter if you provided it or not, because the thing without those preferences is still playable, but if you want to enjoy the "correct" color and light, then you must provide them in command line.
and for the last question, to be honest, I don't know if I need those preferences, why export a new file or something else instead of set them in command line?
Ryzen 7 1700
GTX970
Ryzen 7 2700X
Fury Nano
MythCreator is offline   Reply With Quote
Old 7th April 2020, 18:28   #7528  |  Link
_kermit
Ok, I stick with providing the parameters then.
If that information isn't there, the Radiance Pro is using default values
(AFAIK), so they are rather important and can not be provided otherwise.
And since I provide max-cll in the command line as parameters, that is fine.
The primaries seem only to have two variants so far:
R: x=0.708000 y=0.292000, G: x=0.170000 y=0.797000, B: x=0.131000 y=0.046000, White point: x=0.312700 y=0.329000
and
R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000
thank you all!
Old 7th April 2020, 19:36   #7529  |  Link
onekmilesbehind
R: x=0.708000[...]
and
R: x=0.680000[...]
Took me too long to realize those correspond with BT.2020 (top) and DCI-P3 (bottom), both very common with HDR media.
onekmilesbehind is offline   Reply With Quote
Old 7th April 2020, 20:46   #7530  |  Link
_kermit
ah, that's good to know
thanks.
Old 9th April 2020, 21:13   #7531  |  Link
Patman
Patman's Avatar
Originally Posted by filler56789 View Post
And the problem hasn't been fixed yet
Just wondering how and why they (MCW) approve the commits without testing the commits...
They could fix the problem. Look here. I think there will be an official fix soon.
Old 10th April 2020, 21:29   #7532  |  Link
filler56789
SuperVirus
filler56789's Avatar
Thanks!
https://bitbucket.org/multicoreware/...a725d4fa84a084
filler56789 is offline   Reply With Quote
Old 11th April 2020, 06:13   #7533  |  Link
tuanden0
Unable to finish encode after using x265 version 3.3+19 and 3.3+21 on http://msystem.waw.pl/x265/
So i have to turn back on version 3.3+10
I got stuck after they encode to last frame
tuanden0 is offline   Reply With Quote
Old 12th April 2020, 15:04   #7534  |  Link
filler56789
SuperVirus
Thanks for the useful information,
I have just reported the latest-and-greatest problem to the x265 devils.
Old 13th April 2020, 02:30   #7535  |  Link
MythCreator
My encoding work stuck on 3.3.19 & 3.3.21 too. It won't stuck on 3.3.10 with exact same settings, video and compiler. And it doesn't matter what compiler is, GCC or VS stuck on 3.3.19 and all goes well on 3.3.10. So the problem has to be in those commits between 3.3.19 and 3.3.10.
vspipe 2>NUL "RAW.vpy" - | C:\Encoder\x265_64_10bpp.exe --input-res 1280x720 --fps 29.970 --input-depth 16 --force-flush 0 --ctu 32 --no-strong-intra-smoothing --selective-sao 0 --no-sao --bframes 8 --weightb --no-open-gop --ref 6 --rc-lookahead 48 --aq-strength 1.0 --psy-rd 2.5 --rd 6 --aq-mode 1 --aq-motion --hme --hme-search "2,2,3" --hme-range "24,24,36" --me star --subme 6 --merange 64 --crf 18 --output “RAW.hevc" -
here's the command line that I'm using.
Ryzen 7 1700
GTX970
Ryzen 7 2700X
Fury Nano
Old 13th April 2020, 08:33   #7536  |  Link
Patman
Patman's Avatar
I think all the problems are caused by the implantation of the abrEncApp.
EDIT: Here is a link to version 3.3+15 (multilib exe). This version is the last one without implementation of the abrEncApp. Please test if there are any problems with encoding.
Old 13th April 2020, 15:34   #7537  |  Link
MythCreator
I tested this version, the encoding ends well.
Ryzen 7 1700
GTX970
Ryzen 7 2700X
Fury Nano
Old 13th April 2020, 17:26   #7538  |  Link
Patman
Patman's Avatar
Thank you very much, this confirms my suspicion that it has to do with the implementation of the abrEncApp.
Old 14th April 2020, 05:31   #7539  |  Link
tuanden0
I tested your x265 version and it work! Thank you!
Old 14th April 2020, 09:26   #7540  |  Link
LigH
LigH's Avatar
the x265 devils.
You slipped.
New German Gleitz board
