28th March 2017, 18:10 | #5101 | Link | |
Try zooming in with staxrips video comparison tool, you'll see the extra noise\blocking around places like hair when higher AQ strength is used. |
28th March 2017, 18:23 | #5102 | Link | ||
My understanding of max merge is that it allows motion predictions to be more accurate by giving the encoder room to expand it's search. Someone please correct me if I misunderstand it's purpose. ref is the number of reference frames the encoder can use. This is taken from the docs. Quote:
28th March 2017, 18:32 | #5103 | Link | |
First tests on 5 mins video gives approx 5fps which is still kinda acceptable. As for video comparison tool the difference with my previous settings is noticeable but not so relevant. Again, pixel peeping is not my goal, when video is playing the difference is barely visible. Still, there is something to consider: the input video quality. Usually I re-enable amazon webrips or bd TV shows and what I have noticed is that my 8 fps template works OK with those, but when it comes to standard webdl approximately 6000 lbs avc yes, your additional tweaks make a difference as for noise and details in dark areas. Above all I am looking after killing any smoothing effect, I accept some blockyness but not "plastic faces". Have also tried fast preset, somehow the impression is that overall image is sharper but detail loss is too high. Inviato dal mio GT-N7100 utilizzando Tapatalk |
28th March 2017, 18:41 | #5104 | Link |
Pig on the wing
As a non-technical person, I've never really understood --max-merge. What does it do in layman's terms? I've understood that it doesn't merge blocks but the resulting vectors from n blocks to predict motion.
28th March 2017, 18:58 | #5105 | Link | |
For an extreme MM example, do a test and output as low resolution, like 250 res and CQ 27. Do Max Merge 1 and then Max Merge5. MM1 probably looks like a mess, while MM5 probably looks way too smooth and has obvious big, thick edges on things. More MM might be "expanding its search," but more importantly, and sometimes badly, it does what its name says: merge. In the 720p 2000kbps zone, MM5 can kill detail and make things look flat. Things will still have "chunks" and "areas" of detail, but it's not fine detail, and, frankly, can look as if you're using a lower resolution than what you are. A funny thing about the default presets last time I checked is the slower the preset the more Max Merge is used. So you get (some) people using slower presets hoping for more detail, but then there's still SAO, intra smoothing and whatever else, but now also more Max Merge is used, which makes things even more smoothed. For reference frames I've pretty much settled on 4 refs and 10 b-frames as the sweet spot. B-frames seems to help more than more refs. I think more refs helped but the speed/quality trade-off wasn't ideal. People will say 10 is too much and rarely gets used, but I have seen the difference, and some others have said the same, so whatever. Having said that, I don't think refs and b-frames are something to be overly concerned about. Last edited by Dclose; 28th March 2017 at 19:01. |
28th March 2017, 19:46 | #5106 | Link | |
Will get back. |
28th March 2017, 19:59 | #5107 | Link |
@need4speed
I don't always zoom in when comparing, I just did it with this last because I could see something was different. After zooming in is when I noticed it. Maybe just try to up ref but keep max merge at its default. I checked the docs and confirmed my gut feeling. If rect is disabled amp is disabled as well. From the docs: This setting has no effect if rectangular partitions are disabled. Default disabled |
28th March 2017, 20:10 | #5108 | Link |
@Dclose
Yeah I'm not a fan of rdoq 1, I think 2 is better. I'll have to test MM again, I know the last time I did it it looked better. That was at 1080p with a "healthy" bitrate. b frames are for compression not quality. I & P frames have higher bit rates and quality. @need4speed what settings did you use for ref and mm? |
28th March 2017, 20:14 | #5109 | Link |
@Dclose and @Need4speed
Something to keep in mind, it's best to compare b frame to b frame from the source and your encodes. Try using something like AvsPmod. You'll need to add .ffinfo(cfrtime=false,vfrtime=false,version=false,colorspace=false,colorrange=false,cropping=false,sar=false) to your script. This will show you what type of frames you are comparing. You shouldn't compare mismatched frame types. Source I vs encode B for a worst case scenario. |
28th March 2017, 20:28 | #5110 | Link | |
I don't write the manual for this stuff. I just run test clips and look for the differences. *shrug* |
28th March 2017, 20:44 | #5111 | Link | |
28th March 2017, 22:34 | #5114 | Link |
If one minute of video looks different than another one minute of video, and the only thing changed is the x265 b-frame setting, I'm going to assume the difference in video has something to do with the b-frame setting.
29th March 2017, 04:54 | #5115 | Link | |
Actually last encode from an Amazon webrip (approx 13k kbs avc) was made with 5 ref and 5 bframes. I have left untouched max merge. Can't really tell why but it looks a bit better, somehow clearer image and dust in the air looks better. Good tips, thanks. What about early skip in this context? Inviato dal mio GT-N7100 utilizzando Tapatalk |
29th March 2017, 17:39 | #5118 | Link | |
What kind of CPU do you have again? If you're looking to speed up encodes try adding these settings. --ctu 32 generally provides better quality and is noticeable faster. I use it on almost every encode. My exceptions would be high CRF,14-16, encodes that I want a bit more compression. --qg-size <CTU/2> So if your running ctu 32, then it's 16. Faster and generally better quality but less compression. Also you may want to take another look at --deblock. I did a shit ton of tests with it and settled on --deblock -3:0. The first param is it's strength, second is how many pixels it affects. I found that negative numbers for the 2nd param, pulls the deblock to far from the edge of the block. basically defeating the purpose of using it. I tested disabling deblock and didn't like the outcome. Try adding these settings: --ref 6 --ctu 32 --qg-size 16 It should be a bit faster and give better quality. Last edited by brumsky; 29th March 2017 at 18:05. Reason: typos |
29th March 2017, 20:24 | #5119 | Link | |
For starters I have tried to raise maxmerge and, well, again personally speaking the difference is not worth a 8/9 to 4/5 fps speed drop. Raising ref and bframes to 5 was a good hint, so thanks also for this. Deblock..went through a lot of testing in the past months and, to be honest, ended up leaving disabled. Again, my own personal opinion. Bottom line is that I try to keep things simple, with an eye on speed and not worrying much about final size (happy if files are 30% lighter). By keeping simple I must admit my ignorance, too many parameters to play around with and, also reading over and over white papers, I am all but sure what each one does in combination with others. Basically I am alost there in terms of speed/details/quality, but at times there's still the impression to look at things through a window, so to speak. Clean glass but there's still something that doesn't match AVC final result. Would need a dehaze filter like in Lightroom What it still amazes me is how a couple of tweaks (leaving CRF alone) can make a file the half or the double. In there past three days I have had an output of 890megs or 1,9 gigs out of the same original file! Whatever, I will try to go back and retouch CTU and QG size and see if with latest releases the benefit is worth additional tweaking. now will try to leave everything as is and run a second encode with early-skip enabled. Thanks again! |
29th March 2017, 20:54 | #5120 | Link | |
b-frames 3-8 don't change too much as the total number of b per gop is about the same ctu 32 isn't better/faster than 64 qg-size don't has to be ctu/s, ctu 64 + qg-size 8 is legit reference > 4 can be over level 4/4.1 so you lose compatibility with a lot of hw decoders.
powered by Google Translator |
