15th February 2013, 12:57 | #14162 | Link |
Impressive video from today's meteor attack in Russia, Chelyabinsk.
https://www.dropbox.com/s/xt6t6zbbav6tmak/Russia%20%281%29-HD.mp4 But it's not playable in DXVA mode (ATI hardware on signature system). Not DXVA-compliant or ATI hardware/drivers ?
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
15th February 2013, 13:53 | #14165 | Link |
You'll have to enable UHD/4K decoding in LAVs options because it only checks based on height. It'll then probe the hardware for support for this resolution, if it works or not, i don't know. NVIDIA supports "rotated" resolutions like this, i think, not sure about AMD.
15th February 2013, 16:27 | #14166 | Link | |
Here are some resolution-limit-test samples, made by mpc-be team, I think you will like them. h264_dxva_width_limit_test h264_dxva_height_limit_test h264_dxva_macroblocks_limit_test h264_dxva_square_limit_test PS: Use latest mpc-hc or PotPlayer for the accurate result. |
15th February 2013, 17:22 | #14167 | Link | |||
I did the test using Radeon 3650 and my 5750 with MPC decoder, LAV Video and PotPlayer. MPC decoder and PotPlayer if you force it to always use DXVA regardless resolution, can actually play in DXVA mode that "rotated" 720 x 1280 clip. So AMD supports those "rotated" resolutions, too - even in very old hardware like Radeon 3650. On the other hand, LAV Video doesn't support it even in newer hardware like 5750 and even if you enable UHD/4K decoding. So, Nevcairiel if you have time you can check again the UHD/4K option with AMD hardware.
15th February 2013, 17:47 | #14168 | Link |
They are not very common, so its not a big thing, but i can probably make the check smarter to allow them.
16th February 2013, 04:43 | #14169 | Link |
Hi nevcairiel. First off, I'd like to thank you for creating LAV filters.
They are amazing! I have a feature request for the LAV Splitter, if you don't mind. This feature is the only thing keeping me from switching over from Haali. Haali has an option called "Use custom media type for H.264". This option enables me to watch 10 bit video (Hi10P) on Windows Media Player & Windows Media Center. I was wondering if you could implement this feature in the LAV Splitter. Thanks! |
16th February 2013, 08:16 | #14170 | Link |
No, i cannot implement a stupid option like this.
There are plenty tools to configure which decoder is used in WMP, you don't need to use a wrong solution like this.
17th February 2013, 13:22 | #14174 | Link |
I have an interlaced VC-1 file that doesn't deinterlace properly with WMV9 DMO (using either MadVR or EVR). It plays properly using CUVID. I assume it's a problem with the codec but what do I know, it might be fixable. Sample is here.
It's a 1080i/25 video that was converted (pretty badly) to 1080i/30 for BD so it's never gonna look properly smooth. You can tell when it's not being deinterlaced properly by the combing though.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
17th February 2013, 13:30 | #14175 | Link |
Looks fine here. All frames are marked as interlaced, so from the decoders point of view, everything is fine. And i also see no combing. EVR deinterlaces it to 60p
PS: Blu-ray supports 25i just fine, whats with the conversion crap? :d
17th February 2013, 13:50 | #14176 | Link | |
It's so that they can have one international BD master that can be released everywhere I guess. Total bullshit considering the majority of the market is in the UK and they already have the 1080i/25 master that they used for HDTV.
17th February 2013, 14:30 | #14177 | Link |
Are there plans to incorporate support for Matroska file segments?
The last reference about segments I was able to find is from 2011, so I hope you don't mind me bringing this up again. |
17th February 2013, 15:34 | #14178 | Link | |
