Old 16th February 2019, 20:08   #54781  |  Link
alexnt
Is there any way to restore the settings.bin file That I backed up?
alexnt is offline   Reply With Quote
Old 16th February 2019, 20:59   #54782  |  Link
IceB
MadVR FHD 8bit SDR vs UHD 10bit HDR to SDR comparison
I have red several threads on the HDR to SDR / UHD 10 bit to FHD comparison threads and finally decided to give it a go as there is more and more UHD 10bit HDR content.
After some learning curv with the latest build of madVR and testing the "Mehanik HDR10 test patterns", I have tuned my settings and made a comparison of the several frames of different versions ( FHD / UHD 10bit HDR ) of the same great action movie " Mission: Impossible - Fallout " .
I have also tested another movies and my conclusion is unequivocal - I definitely like the compressed UHD 10bit HDR to SDR by madVR in comparison to the FHD 8bit version on my rig. I watch movies in the dedicated HT room, small but all black walls and ceiling on 96" CARADA screen with good old JVC DLA-X30 that provides a very good black levels. The lamp has made around 2500 hours run, but still good with 100nits target on madVR . The pj was calibrated a while ago with my old MONACO XR DTP94 colorimeter for REC. 709 2.2 curve and since then I am using the i1pro spectro but waiting till I order a new lamp to get it re calibrated.
Since I have been looking for any detailed A/B images on the web and could not fine anything detailed and interesting (sorry if I missed something), I made for you a single frame comparison and uploaded it on my web site with the before/after view including the madVR settings data running on GTX 1070ti. Some frames have more obvious differences the others have less, yet as mentioned the UHD content compressed by the madVR has more clarity as a result with more details in near whites ( low highlight recovery is applied ), deeper and punchier colors with much more detailes and contrast darks that adds more depth to the picture. The textures are a bit sharper as well.
Enjoy and let me know what you think.
here
hover with the mouse over the screenshots
IceB is offline   Reply With Quote
Old 16th February 2019, 22:09   #54783  |  Link
Warner306
I also prefer the HDR images. Even at 100 target nits, the improvement in contrast is noticeable. Maybe the only complaint I'd have is it looks like the gamma is ever so slightly raised in the HDR shots, which you can notice in some of the changes to some color tones. But none of the images look overbright.
Old 16th February 2019, 22:34   #54784  |  Link
tp4tissue
tp4tissue's Avatar
Originally Posted by svengun View Post
HI SamuriHL, I also have GTX1060 and an LG OLED.
Do you use ToneMapping ? When applying ToneMapping for me, rendering for goes from 30ms to 55-60ms and makes it unwatchable
Only when I downscale a lot of settings (Chroma from NGU High to low, Image Upscaling to NGU low & downscaling to Spline, it is somewhat acceptable ( 30-35ms )
And strangely enough, I get the best values with 800 nits, while my 2015/16 OLED is rated at 540 nits
If you do use ToneMapping, would you mind sharing your settings ?
you're upscaling 4k to 8k ngu then downscaling to 4k ? < you shouldn't do this >
Because ngu will only touch chroma upscaling on 4k to 4k, LUMA is 1:1, so whatever ngu setting you put for LUMA upscaling doesn't affect performance
On my 1060, for 4K HDR, I have it on NGU medium (Chroma), w/ Tone Mapping to SDR + highlight recovery, it runs ~22-30ms. Luma is 1:1 untouched.
My 1060 runs at 2088mhz, it can go to 2112mhz, but it doesn't always auto boost to that high because madvr is not a saturating load at 22-30ms
For 1920x1080 upscale, setting is NGU high chroma, NGU high luma.
Ghetto | 2500k 5Ghz
Old 16th February 2019, 23:58   #54785  |  Link
tp4tissue
tp4tissue's Avatar
The contrast is static no ? So, whatever tone mapping we do at 100nit , it's trading crush for highlights ?
Ghetto | 2500k 5Ghz
Old 17th February 2019, 00:00   #54786  |  Link
tp4tissue
tp4tissue's Avatar
here
Have you compared the lut between colorimeter only and spectro+ colorimeter ?
Is it a huge difference ? I'm hunting for a spectro atm.
Ghetto | 2500k 5Ghz
Old 17th February 2019, 01:10   #54787  |  Link
IceB
Sure there is - different creature.
I got the spectro mostly for work. Will give the pj a go once I will get my hands on the new lamp. Profiling/calibration is time consuming.
Old 17th February 2019, 01:12   #54788  |  Link
IceB
I can definitely live with that. The benefits are obvious.
Old 17th February 2019, 01:28   #54789  |  Link
Manni
Don't waste your money with an x-rite "recalibration" of your i1pro. It's not a re-calibration, it's a re-certification. They read it, and they certify it if it's still within specs (which it should be as they don't drift unlike filter based colorimeter). They don't correct or change anything. If it's out of specs, it's "defective" and they charge you more to correct it. But if it was defective, you would know it, no? so unless you suspect something to be wrong (and are ready to pay more than the initial recert), I'd just skip this.
I wasted the money once, and when I saw that the numbers on their new certificate were exactly the same as on my original certification (the one you get when you buy the thing), I asked them and that's how I found out. So personally I won't do it again.
I guess it's worth doing it if you do pro calibrations, but they people expect a better spectro than an i1pro in that case.
I've had my i1pro2 for years and I don't believe it has drifted one bit. My projectors, on the other hand, especially after a few thousand hours...
Just my .2 cents of course, it's your money
Win10 Pro x64 b1909 MCE
i7 3770K@4.0Ghz 16Gb@2.18Ghz EVGA GTX 1080 Ti SC2 11Gb@2GHz 442.74 RGB Full 8bits
MPC-BE/LAV/MadVR/jRiver/MyMovies V5.25/CMC V3.2
Denon X8500H>HD Fury Maestro>JVC RS2000
Old 17th February 2019, 01:29   #54790  |  Link
tp4tissue
tp4tissue's Avatar
I just meant by eye, did the spectro introduce a significantly different image vs colorimeter alone.
Not talking about measurement , since it's already known that spectro will improve delta-e greatly.
Also @ Manni, perhaps you could chime in on my question as well.
Ghetto | 2500k 5Ghz
Old 17th February 2019, 11:34   #54791  |  Link
it depends on your end device and how far off your white point is with a colorimeter.
don'T forget this is mostly about the white point and if that white point is off doesn't matter that much as long as it is constantly off by the same margin so your eyes are fine and able fix the issue. one of the reasons you may not notice the drift.
the i1d3 drifts but not by much it also depends on how it is stored.
spectro meter drift like no one else business in comparison.
Old 17th February 2019, 13:33   #54792  |  Link
Warner306
Yes, but you are rolling off the brightest information, which should be handled more gracefully. Raising the target nits slightly will change the color saturation, but then the image would be darker relative to the SDR screenshots. So you are right that there is a tradeoff.
Old 17th February 2019, 16:26   #54793  |  Link
alexnt
Hi can some one explain me why cpu usage is so high?
Old 17th February 2019, 16:38   #54794  |  Link
madjock
Upload the image to an external image site and post a link, as it takes a while to be cleared on site.
You will need to give more information on your setup and settings as well ?
Windows 10-1909 | i5-3570k | GTX 1070 Windforce OC Rev2 8GB : 430.64 | Yamaha RX-V377 | Philips 65PUS6703 - 65"
Old 17th February 2019, 16:54   #54795  |  Link
alexnt
https://postimg.cc/JstcR1SP
i5 4690k stock
r9 290 4gb stock
16gb ram
settings in madvr?
Old 17th February 2019, 17:13   #54796  |  Link
tp4tissue
tp4tissue's Avatar
i5 4690k stock
r9 290 4gb stock
16gb ram
settings in madvr?
that's not high cpu usage, the core is only running at 35x instead of full , so it just looks higher.
But if you enable dx11 accleration in lav filter, it may bring that down further assuming the gpu accleration works on the file you're using.
If you delid and overclock to 4.8ghz , it'll look even lower.
Keep in mind, if you run any 4k files on 64bit mpchc cpu decode, it will use an avx code path, which may require lowering memory frequency to reach 4.8ghz stable.
Ghetto | 2500k 5Ghz
Old 17th February 2019, 17:29   #54797  |  Link
alexnt
it goes from 35 to 38 and has some drops to around 20.
and render time is lower than I remember, it was around 18-20s.
https://postimg.cc/nXJ5cSvX
settings in lav filter
As i remember I had lower cpu usage and higher render time.
I had some time to watch a movie and yesterday when I switched to fullscreen monitor went black. It was fullscreen exclusive that had a problem(i never had it before). I use madvr for years with no problem.
So i uninstalled madvr, mpc before I figured out.
Then reinstalled and noticed those numbers.
Do you believe it ok?
Old 17th February 2019, 22:38   #54798  |  Link
KoD
Regarding the i1Pro re-certification, they measure 12 tiles or so to check if the measurement deviations are still inside a certain dE range, and do another check to see if repeated measurements of the white tile are within 0.1 dE. If it is, then that's all. If it isn't they can change the light source in the spectro with a new one. The "Certificate of Performance" is valid for only one year.
I have a request for madshi, regarding madVR: right now, madVR is able to passthrough the HDR metadata to the display. I would request to also be able to send the display the Dolby Vision metadata. This kind of metadata can now be preserved in the HEVC stream when using x265 3.0.
LG is providing mp4 video files for SDR / HDR / DolbyVision at these links, that can be used to test:
■ SDR - https://lgtca.box.com/v/SDR
■ HDR - https://lgtca.box.com/v/HDR
■ Dolby Vision - https://lgtca.box.com/v/DoVi
When using the files on a USB stick connected to one of the TV USB ports, the TV switches on HDR or DolbyVision as expected. I imagine the signaling in the video stream is all that's needed for that. PC games can also switch on Dolby Vision, so sending the metadata from a graphics card should also be possible.
As a side-note, for DolbyVision to work with Mass Effect Andromeda on the LG 65C8, the GPU needs to be configured to send RGB full range 8 bits, from my experiments. Using YcbCr will not work for enabling DolbyVision - you'll get a pink corrupted image.
These files are mentioned in the LG OLED 2019 AutoCal FAQ v2.0 pdf file that Ted posted on avsforum, as a way for users to make the TV switch in HDR or DV mode in order to be able to perform display calibration of those modes.
KoD is offline   Reply With Quote
Old 18th February 2019, 00:49   #54799  |  Link
tp4tissue
tp4tissue's Avatar
I don't know what you saw before/after.
if the dxva says inactive "While the movie" is playing. That means the gpu acceleration is not compatible with the file you're trying to play.
-In which case- it will default to CPU decoding. Different files have different compatibility.
But overall, it does not look high to me.
Again, you have other options, such as overclocking, if you need more oomph for hard to decode files. (not this one obviously)
Ghetto | 2500k 5Ghz
Old 18th February 2019, 01:07   #54800  |  Link
el Filou
el Filou's Avatar
Check those LAV settings while playing a movie that gives high CPU load, and see which decoder is active. If it's avcodec then hardware decoding isn't active and that could explain it.
With hardware acceleration, CPU usage should be very low, definitely much lower than 66% @ 3,5 GHz
(Edit: do you have stuff like black bar detection enabled in madVR? That can use up some CPU, but I don't know how much exactly)
HTPC: Windows 10 1909, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
