Old 18th January 2018, 13:55   #15401  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Originally Posted by jlpsvk View Post
it would be great to have possibility to ENABLE or DISABLE "Force HDR to SDR when coverting to HEVC" per job, not globally.
why???
Old 18th January 2018, 15:21   #15402  |  Link
gabbett1
Hello Atak,
I recently installed the updated version of Ripbot264. Ever since, when I'm trying to encode, I get an error popup that says:
ffmpeg.exe has stopped working
Thoughts on how to correct this? Everything I look up online says it's an issue with firefox, but it only happens when I'm encoding.
Thanks
gabbett1 is offline   Reply With Quote
Old 18th January 2018, 16:10   #15403  |  Link
byteshare
ByteShare
byteshare's Avatar
v1.22.1
Added: Server automatically kills crashed ffmpeg.exe and discards current encoding progress.
Awesome, will give this a try, thank you!
Old 18th January 2018, 16:11   #15404  |  Link
byteshare
ByteShare
byteshare's Avatar
Originally Posted by gabbett1 View Post
Hello Atak,
Thanks
Would you please confirm what version you're on?
At wait point exactly are you getting the FFMPEG error?
For me in DE mode, turning the server off, closing the error and starting it again usually works, but on the most recent version there is a method that should be doing this automatically.
Old 18th January 2018, 16:24   #15405  |  Link
gabbett1
I'm using version 1.22.0.7. It's random when it happens. Happens on the computers I'm using the encoding server on as well.
Old 18th January 2018, 17:48   #15406  |  Link
jlpsvk
why???
Because it would be time-saver. Because I can then have in one queue both... 4K HDR -> 4K HDR HEVC and 4K HDR -> 4K SDR HEVC jobs... now i must first do one, change setting, do other... quite disturbing.
jlpsvk is offline   Reply With Quote
Old 18th January 2018, 19:32   #15407  |  Link
GZZ
I still have Undetermined subtitles when it should have a language name.
Example
25_subtitles_Undetermined.sup
If I look up in the Mediainfo.txt file I can see it should be Romanian.
GZZ is offline   Reply With Quote
Old 18th January 2018, 20:27   #15408  |  Link
slalom
slalom's Avatar
So change it to Romanian
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
slalom is offline   Reply With Quote
Old 18th January 2018, 21:14   #15409  |  Link
byteshare
ByteShare
byteshare's Avatar
Try updating to 1.22.1 since it has support for handing FFMPEG errors that previous versions did not.
Assuming you mean an FFMPEG error on the PC with the Encoding Client on it (manage the encoding servers)?
You said it happens on the encoding server to, do you mean just in the encoding log or an actual FFMPEG error popping up?
Old 19th January 2018, 00:58   #15410  |  Link
Arbie
Where to get latest update?
I keep trying to find 1.22.1 or whatever is the latest. The link on the first page has 1.22.0 but the exe is dated 1 Jan.
Where to look for these newer ones I see mentioned?
Arbie is offline   Reply With Quote
Old 19th January 2018, 05:15   #15411  |  Link
burt123
burt123's Avatar
Have you got auto update enable in Ripbot settings ???
I should get it automatically, if enabled, and you're connected to the "net" !!!
burt123 is offline   Reply With Quote
Old 19th January 2018, 17:50   #15412  |  Link
GZZ
Is this a forum to correct errors in the progam or a forum kick other people because they report at possible mistake in a program ?
Old 19th January 2018, 21:34   #15413  |  Link
gabbett1
Mine "tries" to auto update but the version it says I have afterwards is 1.22.0
Old 19th January 2018, 21:45   #15414  |  Link
slalom
slalom's Avatar
I'm not sure its the program. If it's the program, Atak should fix the Greek subtitles too
Old 19th January 2018, 22:19   #15415  |  Link
dracore
well, ive just grabed the latest release and now ripbot will not even load for me before the update all was fine and dandy
dracore is offline   Reply With Quote
Old 19th January 2018, 23:36   #15416  |  Link
GZZ
Is it possible to control the among of thread on each server using DE ?
I use 3 machines to encode some UHD disc. Ryzen 7 (8 core, 16 threads) and an old Intel Core I7-4770k (4 core, 8 threads) and a Core I7-6700HQ (4 core, 8 threads). The problem is that MDegrain dosnt like hyperthreading. I tried to encode a chunck manually using 8 or 16 threads on my Ryzen 7. 8 threads (video=Prefetch(video,8)) gave me 3fps, but with 16 threads video=Prefetch(video,16) it gave me half fps.
I can limit the number of threads to 8 when using MDegrain filter. But I would like to limit it to 4 threads on my Core I7-4770k and my I7-6700HQ. The temperary aproach is to set limit at 4 threads and then use 2 servers on my Ryzen. But it would be nice if I could specfify it on a server level, then I could mix more servers with differnt cores and still get the best out of them.
Update: Not sure its MDegrain. I think its MT part that dosnt run better when using the hyperthreads, looks like it runs faster with just using the among of threads that matches the core. Maybe too much waiting time between threads when using 16 threads.
Update2: Maybe just an option to only use real cores and not hyperthreading for the MT part of AVS script. It did run better and faster on all my machines with just limiting the number og threads to the actual number of cores on the cpu.
Old 20th January 2018, 00:59   #15417  |  Link
Arbie
That doesn't work in the case of "Java not found", because the program won't go past that point. The GUI never opens.
So -- is there a location to pick up the latest version?
Old 20th January 2018, 07:58   #15418  |  Link
GZZ
I got java 8 Update 151 installed, I think its the 32bit version, even though I run 64bit windows. I downloaded it from java.com and works out of the box with ripbots.
Old 20th January 2018, 15:33   #15419  |  Link
Atak_Snajpera
CPU: Xeon E5-2690@2.9GHz (8C/16T)
MDegrain2 + Prefetch(16)
MDegrain2 + Prefetch(8)
Old 20th January 2018, 19:12   #15420  |  Link
Arbie
Still working on "Java not installed" error on my Windows 10 64-bit system (running as Standard User)...
• My RipBot264 version is v1.22.0.7
I can't find where to download the latest version, which is listed as having a fix for this.
• "Update" won't fetch the latest version because the program never gets to the point where I can enable that.
• I think Java 32-bit is installed on my PC, based on the following evidence from the registry, folders found, and command prompt output (except for one folder not found):
REGISTRY
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Runtime Environment
has
CurrentVersion = 1.8
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\JavaSoft\Java Runtime Environment
has
FOLDERS
found with Java components:
C:\Program Files\Java\jre1.8.0_151
C:\Program Files (x86)\Java\jre1.8.0_152
BUT THIS FOLDER NOT FOUND:
C:\Windows\SysWOW64\java.exe
COMMAND PROMPT:
Microsoft Windows [Version 10.0.16299.192]
(c) 2017 Microsoft Corporation. All rights reserved.
C:\Users\[my user name]>java -XshowSettings:all
VM settings:
Max. Heap Size (Estimated): 247.50M
Ergonomics Machine Class: client
Using VM: Java HotSpot(TM) Client VM
Property settings:
awt.toolkit = sun.awt.windows.WToolkit
file.encoding = Cp1252
file.encoding.pkg = sun.io
file.separator = \
java.awt.graphicsenv = sun.awt.Win32GraphicsEnvironment
java.awt.printerjob = sun.awt.windows.WPrinterJob
java.class.path = .
java.class.version = 52.0
java.endorsed.dirs = C:\Program Files (x86)\Java\jre1.8.0_152\lib\endorsed
java.ext.dirs = C:\Program Files (x86)\Java\jre1.8.0_152\lib\ext
C:\WINDOWS\Sun\Java\lib\ext
java.home = C:\Program Files (x86)\Java\jre1.8.0_152
java.io.tmpdir = C:\Users\[MyUserName]\AppData\Local\Temp\
java.library.path = C:\ProgramData\Oracle\Java\javapath
C:\WINDOWS\Sun\Java\bin
C:\WINDOWS\system32
C:\WINDOWS
C:\Windows\system32
C:\Windows
C:\Windows\System32\Wbem
C:\Windows\System32\WindowsPowerShell\v1.0\
C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common
C:\WINDOWS\system32
C:\WINDOWS
C:\WINDOWS\System32\Wbem
C:\WINDOWS\System32\WindowsPowerShell\v1.0\
C:\Program Files\Process Lasso\
C:\Users\[MyUserName]\AppData\Local\Microsoft\WindowsApps
java.runtime.name = Java(TM) SE Runtime Environment
java.runtime.version = 1.8.0_152-b16
java.specification.name = Java Platform API Specification
java.specification.vendor = Oracle Corporation
java.specification.version = 1.8
java.vendor = Oracle Corporation
java.vendor.url = http://java.oracle.com/
java.vendor.url.bug = http://bugreport.sun.com/bugreport/
java.version = 1.8.0_152
java.vm.info = mixed mode, sharing
java.vm.name = Java HotSpot(TM) Client VM
java.vm.specification.name = Java Virtual Machine Specification
java.vm.specification.vendor = Oracle Corporation
java.vm.specification.version = 1.8
java.vm.vendor = Oracle Corporation
java.vm.version = 25.152-b16
line.separator = \r \n
os.arch = x86
os.name = Windows 10
os.version = 10.0
path.separator = ;
sun.arch.data.model = 32
sun.boot.class.path = C:\Program Files (x86)\Java\jre1.8.0_152\lib\resources.jar
C:\Program Files (x86)\Java\jre1.8.0_152\lib\rt.jar
C:\Program Files (x86)\Java\jre1.8.0_152\lib\sunrsasign.jar
C:\Program Files (x86)\Java\jre1.8.0_152\lib\jsse.jar
C:\Program Files (x86)\Java\jre1.8.0_152\lib\jce.jar
C:\Program Files (x86)\Java\jre1.8.0_152\lib\charsets.jar
C:\Program Files (x86)\Java\jre1.8.0_152\lib\jfr.jar
C:\Program Files (x86)\Java\jre1.8.0_152\classes
sun.boot.library.path = C:\Program Files (x86)\Java\jre1.8.0_152\bin
sun.cpu.endian = little
sun.cpu.isalist =
sun.desktop = windows
sun.io.unicode.encoding = UnicodeLittle
sun.java.launcher = SUN_STANDARD
sun.jnu.encoding = Cp1252
sun.management.compiler = HotSpot Client Compiler
sun.os.patch.level =
sun.stderr.encoding = cp437
sun.stdout.encoding = cp437
user.country = US
user.dir = C:\Users\[MyUserName]
user.home = C:\Users\[MyUserName]
user.language = en
user.name = [MyUserName]
user.script =
user.timezone =
user.variant =
Locale settings: OMITTED FOR BREVITY
