7th July 2005, 08:38 | #261 | Link | |
haubrija, you're more lucky than I am. I only realize this oversize problem on the process of 2nd pass. First pass takes me about 22hrs to complete on my P3 1GHz machine. From the command line generated by MeGUI, I think MeGUI should replace the bitrate in the configuration panel (says 700 default) to what it calculated (says 626kps, with 128kps of AAC audio) in the AutoEncode mode. It doesn't make sense since the audio size is already known, the "Automatic Encoding" dialog box also shows the required Avereage Bitrate to fit the target output size. Why the program doesn't allow to change the default 700 (in config panel) to the calculated bitrate? This option is remain in gray and unselectable. This is a bug of MeGUI? Thanks. |
7th July 2005, 08:54 | #262 | Link | |
clueless n00b
A job has it's own configuration.. at the point you press queue, the currently active settings (minus bitrate in case of video in auto-encode or one click mode) will be plugged into that job. After it is in the queue, it has no reference whatsoever to what you see in the codec configuration dialog. You can change that all you want.. once a job is in the queue, you can only change it if you a) load it, b) modify it, c) update it. a & c require the appropriately named buttons in the queue tab. Now if you're refering to the "Average Bitrate" textfield in the "Automatic Encoding" groupbox in the Automatic Encoding window... this is a bitrate preview and it does change if you change the file size. I'm quite confused why you think you need to specify a bitrate. You do not.. MeGUI is smart enough to calculate the bitrate for you, taking up to two audio tracks and up to 5 subtitle tracks automatically into account. And it has to be a hell of a coincidence if the average bitrate in the place I just mentioned is exactly 700 kbit/s. Try this: configure audio and video, go into one click mode, note the average bitrate shown. Then press cancel, press the X button to clear the audio, and go to the auto encode window again. Note that the average bitrate has changed.
7th July 2005, 10:46 | #263 | Link | |||
Following is my encoding steps: 1. Video: a. Set input AviSynth Script. (A movie windows shown). b. Define the Video Output: AVC, MP4 and use "automated 3pass" *If the bitrate is 800 here, I will get this in the command line! 2. Define Audio input and output @128kbps (assume no problems here). 3. Click on "AutoEncode", now I got the calculated is 626kbps (Video file size will be 593221KB). Assume no additional audio, subtitles and chapters to add. I click on "Queque" button. 4. Use text edit to open the corresponding job file *.xml. I found the command lines in jobs now specifying "--bitrate 800". This 800 is the bitrate in the config dialog rather than the calculated 626 (which takes audio size into account). My problem is the MeGUI "AutoEncode" provide correct bitrate but when it generate the command line for jobs, it uses the bitrate in the config dialog! Wondering is this happen to you too, or it just happen to me only. May be my steps in creating the jobs are incorrect. Quote:
Hope my explanation above is clear enough. Thanks. |
7th July 2005, 12:06 | #264 | Link | |
clueless n00b
However, if you try without audio encoding, but do specify an audio track to be muxed, then you will immediately see in the log that MeGUI is calculating the video bitrate, and if you check the jobs, the bitrate will match the value the log tells you. If you're just muxing pre-existing audio files, MeGUI can calculate the video bitrate accurately right there. And if you combine the two scenarios (one pre-existing audio track, one to be encoded), you'll have a hybrid mode in which MeGUI reduces the desired size by the size of the pre-existing audio, and then recalculates again once your audio track to be encoded has been encoded. So, once again.. if your output is oversized I need to see the log, plain and simple. You'll see MeGUI recalculating bitrates in there. The last version might lack some entries but you'll see the recalculation for sure as that's a part of the code I have not touched since the introduction of the 3 pass mode. And naturally I have checked that the bitrate recalculation works properly when I made those changes.
7th July 2005, 13:02 | #265 | Link | ||
My senerio might be able to be explained. I've input an EXISTING audio as one of the encoding job. I then delete off the job later because only doing this I would notice the change of bitrate in Video to fit 1 CD correctly in the "AutoEncode" dialog. I simply thought that the shown bitrate in gray will be used in the encoding process. That is my first use of MeGUI and that's why I thought I was correct. Now I know I shouldn't do so . I've tried the encoding with auto3pass and it takes me 20hrs+ for a pass of 2hr DVD movie. I don't want to wait for another day and I think it might be good enough with a 2nd pass video. It is my mistake to remove the 3rd pass while the 2nd encoding is in process. I just thought that they are independent processes running in sequence. Not knowing that MeGUI is getting the jobs done in sequence with dependant of previous job in auto3pass. I believe that is the cause where the video size is increased to an undesired size after I've remove the 3 pass from the encoding sequence. Thanks for you well explanation about the details. Keep on the good job. |
7th July 2005, 13:12 | #266 | Link | |
7th July 2005, 13:18 | #267 | Link | ||
clueless n00b
So, even if you stop encoding after audio encoding by pressing the stop button in the queue tab, the bitrate will still be updated.. but the next job won't be encoded. So unless you manage to crash MeGUI just in the right moment, the recalculation will always be done. With pre-existing audio, unless MeGUI crashes before adding the jobs to the queue, the bitrate will be in order. Quote:
What you should've done is just set up video, then check "add additional streams" and specify your audio stream in the mux window that pops up.. that way the size of the audio would've been taken into account and your video would've ended up having the size you wanted it to have.
7th July 2005, 13:33 | #268 | Link | |
Again, thanks doom9. I would try these out and let the machine runs for this coming weekends. I'll report again if the oversize problem presented. However, I don't think it will happen again. |
7th July 2005, 17:11 | #269 | Link |
Doom9,
Just a point of clarification. I beleive it was oversized because it mp4box imported the video twice. It saw that they were the same name so it imported the video (named temp.mp4) and then what it thought was the audio but was actually the same file (temp.mp4). So I don't think the oversize was the fault of megui... just me. |
7th July 2005, 20:30 | #271 | Link | |
clueless n00b
7th July 2005, 20:45 | #273 | Link | |
clueless n00b
MeGUI is a mencoder gui (hence the first two letters of the name).. it'll support what mencoder supports in terms of codecs.
7th July 2005, 21:52 | #274 | Link |
clueless n00b
the new build for today is out. enjoy
8th July 2005, 14:47 | #275 | Link |
I got a crash on exiting MeGUI 0.2.1.0a - I cleaned the directories for a fresh install of MeGUI and all required tools, created a few video profiles, and closed MeGUI. Here, .NET reported a failure not being able to access a file (unsupported path format). The reason must be: I used a colon in the profile description ("x264 HQ Auto3pass 16:9"). This would result in an invalid filename.
In case you still need a crash report, I saved it. |
8th July 2005, 17:24 | #276 | Link |
MeGUI is getting better and better. I like it. I'm still playing around with x264 and found your GUI very helpful.
A few suggestions from my side: Could you add the output filename automaticly when opening an avs or an audio file? Like when I open mymovie.avs, the output box could already have the filename "mymovie-video.mp4" or something simmilar in the same directory. For autoencode it doesn't really matter how the immidiate files are called anyways. I wouldn't mind seeing the commandlines in the mainwindow. Something like in the config windows, would be nice. In the x264 config window when selecting automated 2-pass the shown commandline is a bit confusing. Could you maybe show both passes seperately on top of each other in the commandline? The avsynth creator doesn't support resolutions higher than 720. I would like to be able to define the noise-options with my favorite filters for avisynth myself somewhere. I wouldn't mind seeing ProjectX support in MeGUI to fix the sync-issues in some of the TS files. Having this in the 1-click tool would be great, too. Now something farfetched maybe, but I'll ask anyways: When doing lots of testencodes with x264 with resolution up to 720p I noticed, that playback load depends on many parts. The more options you choose for x264 the higher the playback load (obviously!). The higher the bitrate, the higher the playback load. The more noisereduction filters in avisynth the lower the playback load. The last two things are hard to predict, but they change the playback performance quite a bit. Maybe there is some way to guess or compute the expected playback performance? Could you add a compressibility check with x264 to MeGUI? There is probably too little experience with this yet, but it would help to decide on the right options. |
8th July 2005, 17:40 | #277 | Link | |
Posts: n/a
There is a standardised restriction on bitrate and other properties such that the video can be guaranteed to be playable on hardware capable of decoding this h.264 profile/level. I believe Doom9 is considering adding these profiles/levels to the gui. |
8th July 2005, 18:08 | #278 | Link | ||||||||
clueless n00b
8th July 2005, 18:15 | #279 | Link |
Doom9,
I'm at work right now so I can't drop post a log, but I beleive I'm having a problem with the acc encoding. I want to encode to 5.1 aac but it seems to only be encoding in regular 2.0. I'm using mplayer for playback. In my audio options, I've been setting it for: 5.1, CBR 224, HE, leaving everything else default. I have a soundstorm motherboard so I'd really love to get the 5.1 working. Is this a limitation of mplayer or a possible problem with megui. Thanks for any help. |
8th July 2005, 18:34 | #280 | Link | |
clueless n00b
@haubrija:
