22nd December 2005, 18:50 | #381 | Link |
I found a glitch in the new LS script on this line:
\ : Smode==2 ? sharpen(float(strengthH)/100.0,float(strengthV)/100.0) I changed strengthH to just strength and it seems to work just great. Didee to you recommend keeping the "strengthV" setting the same as the "strength" setting i.e LimitedSharpen(ss_x=1.2,ss_y=1.2,Smode=2,strength=40,strengthV=40) |
23rd December 2005, 14:01 | #382 | Link |
Ah, indeed. Thanks for spotting it, Socio. The previous link now points to a corrected version.
Unless specified otherwise, "strengthV" defaults to the setting for "strength", i.e. normal symmetrical sharpening. The scenarios for asymmetrical sharpening are those mentioned by Mug Funky: mostly for analog sources, perhaps for anamorphic sources, or perhaps when blowing non-anamorphic up to anamorphic. For VHS sources, Smode=0 with radius=1.5~3.0 and radiusV=~1.0 could be a good way ... except for if horizontal oversharpening is already present, but that's another story. Then, in reverse chronological order: @ Mug Funky: You meant Smode=3, didn't you? Yes, this one could be made working asymmetric, too. But that indeed requires MaskTools 2.0 ... it could be done with 1.5.x also, but would be rather slow. Plus, for that Smode it would (will) most likely be horizontal-only and vertical-only sharpening. Producing a weightened version for that one is not trivial, and probably not worth the effort. @ Chainmax: Soothe will not be implanted into LimitedSharpen. Applying Soothe is easy enough, isn't it. Something with integrated Soothing is in the works ... but it's not LimitedSharpen. @ foxyshadis: Thanks for the service. Seems like I'll have to revise the documentation anyways, so let's wait for that. @ Clouded: To whom do you apologize - to me?? Wrong address, as I live in the glass house - making announcements, then let people wait 'til they're blue in the face ... However, if some of the "support" filters could work on chroma too, it would help indeed. (Top ranking: the "difference" filters.) @ Isochroma: Fine if you like LimitedSharpen, but no way to accord me money for it. *** Happy Xmas everyone - have a good time. ***
1st January 2006, 21:30 | #383 | Link |
Noob entering =p
I'm having some trouble with it. I know I set it up correctly, and results may vary based on signal quality, etc. When I view using GAM the image looks very pastel like, almost cartoonish at medium distance. Up close everything is COMPLETELY smoothed, at medium distance it's cartoonish looking like I said and very aliased as if I were viewing some low quality movie in full screen. I'll post shots later, werk time =p |
2nd January 2006, 13:09 | #385 | Link |
JarretH:
Please post the parameters you're calling LimitedSharpen with. Also before/after screenshots could help. Posterization and aliasing is likely to happen with ultra-high values for "strength", or generally when "strength" is set too high for the chosen supersampling factor. If you're using no supersampling (ss_x=1.0 & ss_y=1.0), then aliasing will show up with much lower strength settings already. When no supersampling is used, Smode=4 might be better suited than the others, because of its non-linear response. The "soft" parameter will help on all Smodes to prevent or reduce the introduction of aliasing and posterization.
2nd January 2006, 19:11 | #386 | Link | |
Hey Didee
Are you referring to this? Quote:
Is there a way I can check if it's hyperthreading? I didn't see two processes using half/half cpu. I'm still tweaking what I like. Been doing some tests on foodtv I could never figure out how to take captures with GAM. |
2nd January 2006, 19:31 | #388 | Link |
Could be caused by RemoveGrain. Especially the first one (merge 75% of RG mode4) for my taste is too strong. Comment out both the lines with MergeLuma(RemoveGrain(..)..), and see if it looks better then.
Note: I had suggested those MergeLuma(Removegrain...) thingies to Socio for realtime processing because this works very fast. For "real" processing, I'd rather recommend SPresso. Takes somewhat more processing power, but it's more efficient, doing less harm.
2nd January 2006, 20:57 | #389 | Link | |
2nd January 2006, 23:09 | #391 | Link | |
3rd January 2006, 06:00 | #392 | Link | |
I think I settled on this
5th January 2006, 02:59 | #395 | Link | |
Posts: n/a
If you think my point is wrong, just say it with you own words. It's one thing to be sarcastic, another to forge someone's post. . Last edited by Neil Lee; 5th January 2006 at 03:03. |
5th January 2006, 03:09 | #396 | Link |
Angel of Night
Clouded already did profiling a few pages back and used it to filterize the slowest and hardest hit luts; his half-and-half variation probably includes 80-90% of the speedup of moving to fully optimized C/asm. A good coder must pick one's battles.
However, I just noticed clouded forgot to modify his script to use MakeDiff/SubtractDiff, so you might give the edited version a whirl. (I'll add the latest mods whenever people think they're stable.) The affected lines are: Code:
sharpdiff=MakeDiff(tmp,last) sharpdiff2=mt_lutxy(sharpdiff,sharpdiff.removegrain(19,-1), \ "x 128 - abs y 128 - abs > y "+AMNT+" * x "+AMNT2+" * + 100 / x ?") soft==0 ? last : SubtractDiff(tmp,sharpdiff2) |
5th January 2006, 06:39 | #397 | Link | |
ReMember
6th January 2006, 02:06 | #399 | Link | |
6th January 2006, 04:34 | #400 | Link |
The MakeDiff version needs the latest support dll here:
http://people.pwf.cam.ac.uk/mg262/po...t_03Dec05B.dll regards, Li On |
