8th September 2015, 13:54 | #32781 | Link |
I am getting a black screen when upscaling with DXVA with 0.89.0 and 0.89.1 on my home machine (Win7 x64 GTX970) and my work machine (Win8.1 x64 Geforce 220.)
Seems to work fine with alternative methods. Downscaling with DXVA just crashes MPC. |
8th September 2015, 14:46 | #32782 | Link |
It happens with the omega 14.12, all windows update driver updates and the current stable 15.7.1 and again in directx 9 and 11, also I did update to the current 0.89.1 which didnt change a thing so I dont think it can be a driver bug.
8th September 2015, 15:31 | #32784 | Link |
Lost In The Web
Not sure if it can help you madshi to identify the problem I reported in post #32788
But I tested again with different videos resolution, here go the result The second Chroma line (with Jinc AR) don't appear with a 640*480 / 652*480 / 720*480 or a 848*480 video, but appear with a 638*480 or smaller
Windows 11 11th Gen Intel(R) Core(TM) i5-11400F Nvidia Geoforce RTX 3050 MPCHC - madVR - Lav Filters - XySubFilter |
8th September 2015, 16:03 | #32785 | Link |
After going through some videos and doing more testing:
Profile support for Zoom Control would be nice. I'd probably set things up so that Blu-rays are untouched - not that I have experienced any issues, just that I can't think of any examples which would need it. I'd have DVDs set up to crop and clean up bad edges. And all other videos would only crop the edges. Regarding the "cleanup image borders" option. As far as I can tell, this is telling the player to crop the image by X amount of pixels. Unless the aspect ratio of the film matches the aspect ratio of your screen, it means that only two of the edges will be cropped. Would it be possible for madVR to draw black bars over those areas so that all four sides are cropped equally? |
8th September 2015, 16:04 | #32786 | Link | |
8th September 2015, 17:02 | #32787 | Link | |
MPC-HC Developer
Black bars detection doesn't work with interlaced content apparently. It cannot decide on AR. Sample BlackBars.mkv Last edited by kasper93; 8th September 2015 at 17:26. |
8th September 2015, 18:28 | #32788 | Link |
Kid for Today
Truth be told I can still make it freeze occasionally and I even got the "internal error" mVR crash report once but I would need to do more detective work in order to find an easy way to reproduce. It's a whole lot more stable than before, no question about it
Gotcha, 15:9 DVD movies from the 70's are a pain to zoom in. Last edited by leeperry; 8th September 2015 at 18:35. |
8th September 2015, 18:54 | #32789 | Link | ||||||||||
Chroma > Nnedi32 Image > Nnedi64 > Nnedi64 < Lanczos4 AR Choma > Jinc AR With SR in refinement on I get: Chroma > Nnedi32 Image > Nnedi64 > Nnedi64 < Lanczos4 AR Choma > Jinc AR > Jinc AR Which might be a bit weird, too, but different to what you're reporting. Quote:
Anyway. Are you using Crossfire? If so, try disabling it. If not, do you have the options "use a separate device for presentation" or "use a separate device for DXVA" enabled? If so, try deactivating them. Also try disabling D3D11 presentation, if you have that enabled. Does any of that help? Have you tried resetting madVR to default settings, just as a test? Quote:
(Unfortunately I fear the things I innovate are going to be copied soon, as usual lately...) Quote:
Yes, definitely. And also for the whole device section. Quote:
Can't reproduce a crash, but I can reproduce some problems related to DXVA scaling. Will have a look at it. |
8th September 2015, 19:13 | #32790 | Link | |
Thanks !
s/w: Vista Home Basic 32bit (no Aero), MPC-HC, EVR Custom Presenter, CoreAVC Pro, ffdshow, SPDIFer h/w: Antec 2480 case, Gigabyte GA-MA69GM-S2H, 4200+, 2.5gb+512mb, ATI x1250 IGP, MS MCE remote |
8th September 2015, 19:32 | #32791 | Link |
It would be nice if you could make the effort to read at least *a couple* posts back to see if your question was already asked and/or answered. If you had done that you would have found an explanation, even with screenhots, only 13 posts before yours.
8th September 2015, 19:41 | #32792 | Link | |
I was really thinking that I'd prefer to err on the side of caution with Blu-ray since the majority of them do touch the edges of a 16:9 screen, but it does sound like it would be best left enabled at all times, and I'll just use profiles to specify whether edges should be cropped etc. |
8th September 2015, 19:44 | #32793 | Link | |
8th September 2015, 19:45 | #32794 | Link | |
I think as developer you are too close to the project, to understand what I mean (which is why I said "someone" - in addition to the fact that someone else could save the time of the developer by explaining). The post 13 back gave "possible uses". What I am looking for is an explanation of what the phrases mean. A "black bar" is a visually black area outside of the desired image, usually due to the screen being a different aspect ratio than the video. So what is being detected ? What is being "masked" by what ? Is "zoom" simply adding to madVR the same frame size changing that previously required the player itself ?
s/w: Vista Home Basic 32bit (no Aero), MPC-HC, EVR Custom Presenter, CoreAVC Pro, ffdshow, SPDIFer h/w: Antec 2480 case, Gigabyte GA-MA69GM-S2H, 4200+, 2.5gb+512mb, ATI x1250 IGP, MS MCE remote Last edited by ADude; 8th September 2015 at 19:47. |
8th September 2015, 19:52 | #32795 | Link | |
See the first image in that post 13 posts back. The black bars I'm talking about are those "encoded letterboxes" described in that image. Also look at all the other images in that post and try to understand what purpose they have in the context of that post, then you should get a pretty good idea what it's all about. |
8th September 2015, 20:01 | #32796 | Link |
Hm, thats pretty rare to have a problem nobody else has, also DXVA2 direct just full crashed my system after having the status window up for 3 minutes, needed to hard reset my system cause it froze, also when it does freeze it mainly sets my screen into one solid color and sometimes it comes back with windows telling me it reset the driver, sometimes it just stays there and theres nothing I can do. It seems as if having DXVA2 disabled leaves it crashless the longest from what I can tell so far, is this some sort of GPU accessing issue?
8th September 2015, 20:06 | #32797 | Link |
AMD is known to be a bit unstable with DXVA2, well, at least I have heard plenty of reports and experienced a bunch of fun myself. You might have found one of those fun occasions.
8th September 2015, 20:08 | #32798 | Link | |
8th September 2015, 20:14 | #32799 | Link |
madVR v0.89.2 released
http://madshi.net/madVR.zip Code:
* fixed: one more media player startup crash * fixed: DXVA deinterlacing and black bar detection didn't like each other * fixed: DXVA scaling had some problems with v0.89.0 and v0.89.1 * fixed: some media player size/pos zoom wishes were not properly applied |
8th September 2015, 21:07 | #32800 | Link | |
SR off: http://i.imgur.com/maff9s2.png i use nnedi3 32 for chroma and doubling chroma
Windows 10 // i7-8700k + GTX 1080 SLI // MPC-BE x64 + LAV + XySubFilter |
