Old 16th June 2007, 17:40   #321  |  Link
Zagolski
Zagolski's Avatar
dmz01
We very wait.
Zagolski is offline   Reply With Quote
Old 16th June 2007, 18:08   #322  |  Link
moshmothma
Originally Posted by dmz01 View Post
I'm working on MKV input now. Maybe afterwards.
Thanks for all your work DMZ01. If you are looking for input, I would vote for the muxer before mkv.
Your work is definitely appreciated!!
moshmothma is offline   Reply With Quote
Old 17th June 2007, 00:56   #323  |  Link
Alkasar
it's pretty easy to mux elementary streams to mkv with existing tools.
it's also pretty easy to demux mkv to elementary streams for TSRemux to mux.
Either way will do.
Deliver the easyest first, dmzerone
cheers
Alkasar is offline   Reply With Quote
Old 17th June 2007, 01:24   #324  |  Link
TEB
Hi. I have a strange .ts capture laying on the disc with 2 different videopids, and 1 audio. Tho TSremux says its 1 video and 2 audio.
When i remux the stream and keep all the components, the new filesize is downed by like 30%..
When i remove 1 of the audio pids, the filesize is also downed by 30%...
Both files cant be read by VLC, tho the origional can.. I chose .ts 188bytes.
First remux can be read fine by Powerdvd 7.3, but the latter with 1 audiostream removed jumps like crazy in powerdvd 7.3..
Something fishy is going on..
Check ure pm for dl info.
br t
TEB is offline   Reply With Quote
Old 17th June 2007, 08:33   #325  |  Link
madshi
Either way will do.
The problem with demuxing MKV is that you lose the timestamps. That can be a problem if the timestamps cannot be fully recovered. This can happen sometimes. E.g. if you demux the Equilibrium HD-DVD video track and try to remux it via mp4box or mkvtoolnix, the video plays shorter than the original. That's because demuxing loses the timestamps.
dmz01, I hope you can preserve the MKV timestamps in your MKV input solution? That would be important IMHO.
madshi is online now   Reply With Quote
Old 18th June 2007, 14:18   #326  |  Link
phaeton
I think that is what he will do I doubt that something which will take just elementary streams out of MKV and into TS would hardly be useful We wait dmz01, we wait!
phaeton is offline   Reply With Quote
Old 18th June 2007, 16:07   #327  |  Link
Gavroche
I vote for a TS muxer, will be useful to mux VC-1 and AC3 cause XMuxerPro didn't recognize vc1 at 23.796 correctly
Gavroche is offline   Reply With Quote
Old 18th June 2007, 16:13   #328  |  Link
colinhunt
As far as I know, writing a full-blown muxer is very difficult. That's why there are large companies who sell their muxers for plenty of $$$. It would certainly be great if TsRemux included a muxer one day, but I feel it's probably a bit too much to ask for.
colinhunt is offline   Reply With Quote
Old 18th June 2007, 20:04   #329  |  Link
baudi
What exactly do you mean by framerate changer? What are you trying to achieve?
I mean a new option so that one can change the video framerate from a .ts container to another output framerate in also a .ts file. For example 23.976fps to 25fps.
Similar to ReStream utility with MPEG2 and like mkvmerge with any codec (in the "Timecodes:" control).
It would be great to multiplex the .ts video stream with an AC3/DTS audio from a PAL DVD. Thank you again.
baudi is offline   Reply With Quote
Old 18th June 2007, 21:34   #330  |  Link
dmz01
Sorry, but TsRemux does not modify elementary streams. It only repackages them into a new container. What you're asking is something that would require elementary stream modification and would require muxing from scratch.
dmz01 is offline   Reply With Quote
Old 19th June 2007, 03:40   #331  |  Link
dmz01
New Version 0.0.16:
Bug fix release. Fixes most bugs reported by various users. Thank you for your samples that allowed me to find and fix those bugs.
Old 19th June 2007, 06:57   #332  |  Link
colinhunt
Thank you! I'll set up a mirror for the new version, just in case.
Here: http://www.box.net/shared/xajh1s4tgj
Old 19th June 2007, 09:34   #333  |  Link
oldpainless
dmz01
Just a quickie to ask how things are comming along with the MKV input?....
Regards
Kevin
oldpainless is offline   Reply With Quote
Old 19th June 2007, 13:52   #334  |  Link
dmz01
Originally Posted by oldpainless View Post
dmz01
Regards
Kevin
It's not a quick thing. Be patient. Maybe around two more weeks. Remember I do have a regular job.
Old 19th June 2007, 14:10   #335  |  Link
oldpainless
That soon...Cool...
Kevin
Old 19th June 2007, 19:34   #336  |  Link
b_squared
Chapters
dmz01,
how hard would it be for you to take a text file as an input specifying the chapter boundaries?
I have some Jools Holland episodes in HD here (ripped from my Dish DVR) that'd like to make mini-BDs out of, with the different performances indexed by chapters.
Thanks a lot for all your work so far. Amazing stuff!
b_squared is offline   Reply With Quote
Old 20th June 2007, 00:47   #337  |  Link
Alkasar
oh yes it is very important.
We struggle a lot with desynchonisations issues on our work to remux mkv to TS to play with our set-top box (freeboxHD).
link here (French only).
Our mkv2ts tool is targeted on mkvs with h264 video. The steps are : demux the original mkv to elementary streams, mux the h264 to mp4 and use mainconcept/elecard directshow filters to mux to TS. This does a much better job than XmuxerPro.
Curiously, a working solution to fix sync issues, is to cut a few seconds out of initial mkv with mkvmerge and process the rest with our tool. I have no idea what this fixes, but it works.
Old 20th June 2007, 04:30   #338  |  Link
phaeton
Alkasar, is there any way on getting some English instructions on how to use your tool? Is there a way to automate it around a large amount of files?
Old 21st June 2007, 13:59   #339  |  Link
oldpainless
I've tried it.....
Old 21st June 2007, 18:37   #340  |  Link
smekoslav
I am trying to demux DD+ audio from m2ts file in order to decode it with eac3to, but I always get an error in eac3to saying Parsing of Dolby Digital headers failed. What am I doing wrong?
smekoslav is offline   Reply With Quote
