15th August 2009, 19:52 | #4642 | Link | |
nal-hrd is set by TSMUXER, so you don't have to worry about it in X264. If/when I finish my own muxer module it will do it as well. Last edited by jdobbs; 15th August 2009 at 19:54. |
15th August 2009, 21:55 | #4644 | Link | |
Very pleased, no stability issues. Fast. |
16th August 2009, 09:13 | #4646 | Link | |
Hi Jdobbs, i've got the same Problem with der_voleser. Every track was reencoded to Dolby Digital, even the normal DTS tracks.
Heres the mux_movie_only.meta where you will see the reencodinh to AC3: Quote:
16th August 2009, 13:28 | #4649 | Link | |
If the file has been modified/hacked in any way it might also cause that message. I'd suggest you do a virus scan on your system and then download again. Last edited by jdobbs; 16th August 2009 at 13:35. |
16th August 2009, 21:41 | #4651 | Link |
JDobbs, thanks for all the hard work. Love this app very much. W/the latest build, have been experiencing the same error when trying to rebuild a BD50 to BD25. I also now get this error w/earlier versions of BD-RB. I'm currently using Windows 7 Ultimate x64 w/a i920 & 6GB of triple channel memory. Have been able to rebuild a couple dozen movies before I started getting this error. I uninstalled Avisynth, Haali & ffdshow then reinstalled but I still get this error...can anyone help me?
----------------------- [11:18:36] BD Rebuilder v0.28.03 (beta) - Source: BLUE.THUNDER.1983.1080P.BLURAY.AVC.TRUEHD.5.1-HDC - Input BD size: 32.22 GB - Approximate total content: [02:56:00.616] - Target BD size: 22.90 GB [11:18:36] PHASE ONE, Encoding - [11:18:36] Extracting A/V streams [VID_00513] - [11:18:37] Reencoding: VID_00513 (1 of 11) - Error in attempt to multiplex: MUX_00513.meta - This is not an EBML file (id=0/440786851 [11:18:38] - Failed to build structure, aborted ----------------------- [13:26:08] BD Rebuilder v0.28.03 (beta) - Source: BLUE_THUNDER_-_BD - Input BD size: 32.22 GB - Approximate total content: [02:56:00.616] - Target BD size: 22.90 GB [13:26:10] PHASE ONE, Encoding - [13:26:10] Extracting A/V streams [VID_00513] - [13:26:10] Reencoding: VID_00513 (1 of 11) - Error in attempt to multiplex: MUX_00513.meta - This is not an EBML file (id=0/440786851 [13:26:11] - Failed to build structure, aborted ----------------------- [16:32:26] BD Rebuilder v0.28.03 (beta) - Source: THE_EMPIRE_STRIKES_BACK - Input BD size: 39.37 GB - Approximate total content: [02:17:29.991] - Target BD size: 22.90 GB [16:32:28] PHASE ONE, Encoding - [16:32:28] Extracting A/V streams [VID_00002] - [16:32:28] Reencoding: VID_00002 (1 of 5) - [16:32:29] Extracting A/V streams [VID_00006] - [16:32:30] Reencoding: VID_00006 (2 of 5) - Error in attempt to multiplex: MUX_00006.meta - This is not an EBML file (id=0/440786851 [16:32:30] - Failed to build structure, aborted |
16th August 2009, 22:19 | #4652 | Link | |
You want help with a pirated source? Furthermore, The Empire Strikes Back isn't even available on Bluray...I suggest you sling your hook and don't post. Just looked at your post history... BDRB is not for backing up your downloaded Blurays, home made blurays...Its for backing up UNMODIFIED store bought blurays. Last edited by Furiousflea; 16th August 2009 at 22:24. |
16th August 2009, 23:25 | #4654 | Link |
Hi. I love the program and rarely get errors. I have now, however run into a problem that I don't know how to solve and was wondering if you could help me. The source is 12 Monkeys US. Do you need any other information?
----------------------- [17:52:58] BD Rebuilder v0.28.03 (beta) - Source: 12_MONKEYS_G51_GLO - Input BD size: 39.53 GB - Approximate total content: [03:37:09.816] - Target BD size: 22.90 GB [17:53:02] PHASE ONE, Encoding - [17:53:02] Extracting A/V streams [VID_00009] - [18:03:39] Reencoding: VID_00009 (1 of 2) - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. |
16th August 2009, 23:29 | #4655 | Link | |
17th August 2009, 04:00 | #4656 | Link | |
If you've recently upgraded to Win7 -- search the thread. Last edited by jdobbs; 17th August 2009 at 20:39. |
17th August 2009, 13:20 | #4657 | Link | |
I didn't take this the wrong way as we all appreciate that problems caused from those who have downloaded corrupt versions. |
17th August 2009, 16:03 | #4658 | Link | |
17th August 2009, 20:07 | #4660 | Link | |
