Old 10th December 2008, 11:19   #5581  |  Link
haruhiko_yamagata
Originally Posted by LoRd_MuldeR View Post
No, looks like this:
Avisynth Yadif doesn't work either in latest builds. I'm now back at "ffdshow_rev2347_20081123-mt.exe", which seems to work good (internal Yadif and Greedy 2 Frame).
Something must have been broken after that build
I have no idea where to start. Could you send me the debug output again?
[ Download ffdshow | Wiki ]
haruhiko_yamagata is offline   Reply With Quote
Old 10th December 2008, 11:21   #5582  |  Link
tetsuo55
MPC-HC Project Manager
Just rechecked it and you need to enable "automatic quality control"
Ps its build 2364
Cannot get a screenshot right now.
All settings at default
Output set to "RGB32" HQ checked
Using libvacodec
Postproccessing checked
-Presets bulleted
--Automatic quality control checked
--mplayer checked
Unchecking automatic quality control brings the cpu usage back down
PS
What does the level fix thing do and why do we need it?
tetsuo55 is offline   Reply With Quote
Old 10th December 2008, 13:07   #5583  |  Link
haruhiko_yamagata
I still can't reproduce.
Windows GUI is very slow. If you leave the dialog open, it will use a lot of CPU.
Old 10th December 2008, 13:37   #5584  |  Link
leeperry
Kid for Today
Originally Posted by avivahl View Post
cool! thanks for the heads up
there's no >2456 ICL10 version from clsid yet(or MT version from XXL), so I'll try the generic builds to see how the jitter goes in HR w/ Reclock
Old 10th December 2008, 14:04   #5585  |  Link
tetsuo55
Found out what was wrong.
there isn't really a 100% cpu usage.
I enabled the OSD and added to the default selection "CPU LOAD"
When automatic quality control is enabled, the OSD displays 100% and sporadically displays 0%.
The slider is constantly changing position and real CPU usage is only about 30%
Looks like the CPU load calulcation is breaking or something
Old 10th December 2008, 14:22   #5586  |  Link
STaRGaZeR
4:2:0 hater
The actual frame rate has been always the same, only the calculation shown in Info & CPU changed
Specs, GTX970 - PLS 1440p@96Hz
Originally Posted by Manao View Post
That way, you have xxxx[p|i]yyy, where xxxx is the vertical resolution, yyy is the temporal resolution, and 'i' says the image has been irremediably destroyed.
STaRGaZeR is offline   Reply With Quote
Old 10th December 2008, 14:26   #5587  |  Link
leeperry
Kid for Today
well ?
that tells me otherwise : "After seeking several frames may have inaccurate timestamps."
if you throw frames w/ wrong timestamps to HR, its jitter is gonna go nuts
Old 10th December 2008, 14:27   #5588  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
I do when I get home tomorrow...
Old 10th December 2008, 14:30   #5589  |  Link
haruhiko_yamagata
Then it's a bug, ffdshow probably reads and clear the CPU usage twice per frame. Not very important though.
Old 10th December 2008, 15:07   #5590  |  Link
STaRGaZeR
4:2:0 hater
well ?
How about the rest?
frame rate calculation: fix compatibility issue with some splitters (matroska, flv)
Matroska and flv splitters round timestamps to milli-seconds. Thus frame rate calculation based on these timestamps has some error.
But go test it, you'll see how everything is the same.
Old 10th December 2008, 15:36   #5591  |  Link
clsid
@all
What are the remaining important bugs and regressions that need to be fixed for beta6?
MPC-HC 2.2.1
Old 10th December 2008, 16:05   #5592  |  Link
whurlston
@all
Would you mind adding this? http://forum.doom9.org/showpost.php?...postcount=5579
whurlston is offline   Reply With Quote
Old 10th December 2008, 16:28   #5593  |  Link
tetsuo55
It's actually more important than it seems.
Because if the miss-read CPU LOAD ffdshow is lowering the postproccessing settings for nothing
Old 10th December 2008, 16:40   #5594  |  Link
clsid
Originally Posted by whurlston View Post
Sure. Have you tested if ffdshow decodes correctly when connected to that splitter?
MPC-HC 2.2.1
Old 10th December 2008, 16:50   #5595  |  Link
whurlston
Sure.
Yup. It decodes the DTS-Core only it seems but I expected that. It works using both libdts and libavcodec.
Old 10th December 2008, 20:21   #5596  |  Link
MatMaul
this one is still here but it is perhaps not a priority :
http://sourceforge.net/tracker/index...41&atid=867360
EDIT : and here is a patch to enable 32bits output for flac when the bitdepth is superior to 16 (encoded from a bluray by eac3to for example)
Index: src/ffmpeg/libavcodec/flac.c
--- src/ffmpeg/libavcodec/flac.c	(revision 2461)
+++ src/ffmpeg/libavcodec/flac.c	(working copy)
@@ -611,7 +611,7 @@
                             const uint8_t *buf, int buf_size)
     FLACContext *s = avctx->priv_data;
-    int tmp = 0, i, j = 0, input_buf_size = 0;
+    int tmp = 0, i, j = 0, input_buf_size = 0, shift, offset_per_sample;
     int16_t *samples = data;
     int alloc_data_size= *data_size;
@@ -712,14 +712,31 @@
 #else
+    avctx->bits_per_raw_sample = s->bps;
+    if (s->bps > 16)
+        offset_per_sample = 2;
+        avctx->sample_fmt = SAMPLE_FMT_S32;
+        shift = 32 - s->bps;
+    else
+        offset_per_sample = 1;
+        avctx->sample_fmt = SAMPLE_FMT_S16;
+        shift = 16 - s->bps;
 #define DECORRELATE(left, right)\
             assert(s->channels == 2);\
             for (i = 0; i < s->blocksize; i++)\
                 int a= s->decoded[0][i];\
                 int b= s->decoded[1][i];\
-                *samples++ = ((left)  << (24 - s->bps)) >> 8;\
-                *samples++ = ((right) << (24 - s->bps)) >> 8;\
+                *(int32_t *)samples = (left)  << shift;\
+                samples += offset_per_sample;\
+                *(int32_t *)samples = (right) << shift;\
             break;
@@ -729,7 +746,10 @@
             for (j = 0; j < s->blocksize; j++)
                 for (i = 0; i < s->channels; i++)
-                    *samples++ = (s->decoded[i][j] << (24 - s->bps)) >> 8;
+                    *(int32_t *)samples = s->decoded[i][j] << shift;
             break;
         case LEFT_SIDE:
MatMaul is offline   Reply With Quote
Old 10th December 2008, 21:35   #5597  |  Link
tal.aloni
DRC Slider
I have commited the "DRC based on presets" patch as rev. 2467,
please note that AFAIK, DRC is not supported when working with DTS, both with libdts and libavcodec, I have tested AC3 successfully with both libraries.
there is another patch I have ready:
+ DRC slider added, this will allow to use dynamic range compression level between 0% to 100%.
two notes:
1. I had to patch liba52 to add this feature. (libavcodec have native support for custom DRC level)
2. although it sounds right, I'm not 100% sure about the accuracy of my method to calculate partial DRC in liba52.
here is the relevant line: (based on what I saw in libavcodec)
-		state->dynrng = state->level * range;
+		state->dynrng = state->level * ((range - 1.0) * state->dynrngclevel + 1.0); //ffdshow custom code
patch:
http://iknowu.net/files/public/ffdsh...C_Slider.patch
build:
http://iknowu.net/files/public/ffdsh...r_20081210.exe
tal.aloni is offline   Reply With Quote
Old 11th December 2008, 00:06   #5598  |  Link
haruhiko_yamagata
Only if both OSD-"CPU Load" and postprocessing "Automatic quality control" is enabled.
I'm afraid I can't fix all bugs. I have limited time.
Old 11th December 2008, 00:46   #5599  |  Link
fastplayer
Will Beta 6 be 32-bit only? Or: How complete are 64-bit builds currently?
fastplayer is offline   Reply With Quote
Old 11th December 2008, 14:52   #5600  |  Link
haruhiko_yamagata
I'm not sure but perhaps 32-bit only.
64-bit builds are still experimental.
