3rd May 2015, 17:43 | #1963 | Link |
When in fullscreen mode, if I bring up the menu by right-clicking and choose to exit the program, the program crashes. It doesn't matter if FSE mode is active or not and it happens even if playback is stopped.
This doesn't happen if I Alt-F4 instead. |
3rd May 2015, 20:37 | #1965 | Link |
I've tried to move to as generic settings as possible from my standard settings and still get the error. As of now my system/settings are:
Windows 8.1 64 bit/Radeon 270X Catalyst 15.3 beta Enable FSE is off (have tested both on/off) Presentation is D3D9Ex (have tested both 10.1 and 11) New windowed mode is off (Have tested on/off) Let DWM handle VSync is off Render scripts are none Dithering - No dithering (normally have set to random) Fluid Motion Off (normally have this on) I checked a bunch of old builds also (extracting them to an empty folder with no player extensions or renderscripts) and did find a build that didn't have this crash, but it was all they way back to 2.9.6 (build 2650) and I am missing all of the builds between there and 2.15.1 (build 2858) which has the crash, so I can't really narrow down where it broke (for me). :/ |
3rd May 2015, 21:50 | #1967 | Link | |
It's difficult to debug the error because the crash causes a black screen (a remnant of the fullscreen video playback) to stay on top of any active windows. |
3rd May 2015, 23:21 | #1968 | Link |
MPDN extensions have been updated again, some improvements to Super(Chroma)Res and also added a few hotkeys to modify chroma settings.
The changes to Super(Chroma)Res are: - Softness now has a slightly different effect, resulting in sharper edges (although "softening" still removes some detail). - Added softness to SuperRes, making it possible to achieve somewhat ridiculous levels of sharpness (not without risk though) - Changed the defaults to accomodate these changes, although the defaults could probably use some improvement, I didn't have time to check all possibilities - Setting a value to 0 disables the corresponding part of the code, so you can trade quality for performance. I've also added 2 hotkeys for controlling chroma: - Ctrl+Shift+L toggles the chroma levels - Ctrl+Shift+M switches the chroma matrix If something has been encoded well you shouldn't need to use either of them. |
4th May 2015, 08:08 | #1970 | Link |
Suptitle, MediaPlayer.NET
Did you have any extensions installed at all? Perhaps try it without the extensions and see if it still happens? I've tested it on the various systems I have here as well and they all closed properly without crashing.
4th May 2015, 17:35 | #1972 | Link | |
I'll keep poking away at it on my end to see if I can find something on my system that may be causing it to break. |
4th May 2015, 19:34 | #1973 | Link |
Have you checked your event logs for anything useful?
Try deleting ScriptAsmCache.(32 or 64) in %localappdata%\MediaPlayerDotNet. Maybe something got corrupted there? Heck, might aswell delete it all if that doesn't work and see if that helps. |
5th May 2015, 11:14 | #1975 | Link |
NNEDI3 OpenCL render script
Hi guys,
I've added an OpenCL version of the NNEDI3 render script. Since I don't have an AMD card, I've only tested it on Intel and Nvidia GPUs. It's now available on GitHub. Cheers. |
5th May 2015, 12:21 | #1979 | Link |
Can replicate it instantly. Have also informed Zach about the dark screen bug when switching from NNEDI3 to OpenCL NNEDI3.
Have found out the bug mentioned in my previous post doesn't require video to be playing either. |
direct3d, mpdn, nnedi3, opencl, reclock |
