14th September 2017, 11:42 | #5601 | Link |
Example for your first file:
ffmpeg -i "input.mkv" -pix_fmt yuv420p10 -strict -1 -f yuv4mpegpipe - | x265 - --y4m --output-depth 10 --colorprim 9 --transfer 16 --colormatrix 9 --range limited --chromaloc 2 --max-cll "1000,96" --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15634,16450)L(10000000,50)" -o "output.265" (--chromalog 2 is usually used for 4K HDR so I have set it. But MediaInfo doesn't show this about your source.) remux with audio/subs from source: mkvmerge -o "output.mkv" "output.265" --no-video "input.mkv" You can find some more examples/discussion here: https://forum.doom9.org/showthread.php?t=174491 http://x265.readthedocs.io/en/defaul...mation-options Last edited by sneaker_ger; 14th September 2017 at 12:55. Reason: edited colorprim/transer/matrix to int values because of x265 cli change |
14th September 2017, 12:25 | #5602 | Link |
It's now --transfer smpte2084
edit: Can anybody provide a sample file which such HDR metadata?
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 14th September 2017 at 12:36. |
14th September 2017, 12:44 | #5603 | Link |
14th September 2017, 13:29 | #5604 | Link | |
so basically only --max-cll changes accordingly to the source? Is there a need/benefit using any of the uhd/hdr Options like "--hdr-opt"? You have some advice on the remaining regular settings for UHD? (preset, CRF value)? thanks! |
14th September 2017, 14:06 | #5605 | Link | |
Other parameters might change as well but it seems most of the sources floating around use the same parameters, mostly. It's your job to check.
Also, some sources have parameters that don't make much sense. Like your second file which has "Mastering display luminance : min: 0.0000 cd/m2, max: 1000.0000 cd/m2". Minimum luminance of 0? I don't think such a display is on the market. Quote:
--hdr-opt is supposed to increase compression for HDR but I haven't actually tested it nor see other comparisons. I suggest you read the thread I linked and look around a bit around the forum. It's subjective. Preset: as slow as you are willing to wait CRF: as low as you are willing to sacrifice HDD space |
14th September 2017, 14:59 | #5606 | Link |
@sneaker_ger
You can't really trust the documentation, it's not always in sync with the code, I would always use strings instead of integers for flags.
14th September 2017, 15:05 | #5607 | Link |
The integers should be the integers as they are stored in the bitstream, i.e. taken right out of the HEVC specs. I assume .. well .. hope they will never change. In this case I just chose them so it works with old and new x265 version.
14th September 2017, 15:12 | #5608 | Link |
I think if you compare with the console and online help you'll probably find more then one issue.
static const char * const x265_source_csp_names[] = { "i400", "i420", "i422", "i444", "nv12", "nv16", 0 }; static const char * const x265_video_format_names[] = { "component", "pal", "ntsc", "secam", "mac", "unknown", 0 }; static const char * const x265_fullrange_names[] = { "limited", "full", 0 }; static const char * const x265_colorprim_names[] = { "reserved", "bt709", "unknown", "reserved", "bt470m", "bt470bg", "smpte170m", "smpte240m", "film", "bt2020", "smpte428", "smpte431", "smpte432", 0 }; static const char * const x265_transfer_names[] = { "reserved", "bt709", "unknown", "reserved", "bt470m", "bt470bg", "smpte170m", "smpte240m", "linear", "log100", "log316", "iec61966-2-4", "bt1361e", "iec61966-2-1", "bt2020-10", "bt2020-12", "smpte2084", "smpte428", "arib-std-b67", 0 }; static const char * const x265_colmatrix_names[] = { "gbr", "bt709", "unknown", "", "fcc", "bt470bg", "smpte170m", "smpte240m", "ycgco", "bt2020nc", "bt2020c", "smpte2085", "chroma-derived-nc", "chroma-derived-c", "ictcp", 0 };
14th September 2017, 15:45 | #5610 | Link |
Maybe the order is correct, there are some incorrect names however like smpte-st-428 -> smpte428
18th September 2017, 18:22 | #5612 | Link | |
Artem S. Tashkinov
Besides there are over several dozen of ways to remove noise and artifacts depending on the source. |
18th September 2017, 18:28 | #5613 | Link |
Pig on the wing
There are the --nr-intra and --nr-inter options available. Also the dreaded --sao a.k.a. Smooth All Objects could be helpful in your case.
18th September 2017, 21:37 | #5614 | Link |
Artem S. Tashkinov
sao is enabled by default, the two other options are not meant for removing noise or smoothing backgrounds because they will as well smooth everything else. If one wants to remove noise, use avisynth filters for that.
2nd October 2017, 01:47 | #5617 | Link |
x265 v2.5+20-0967d0add97e (GCC 7.2.0, 32 & 64-bit 8/10/12bit Multilib Windows Binaries)
x265 [info]: HEVC encoder version 2.5+20-0967d0add97e x265 [info]: build info [Windows][GCC 7.2.0][32/64 bit] 8bit+10bit+12bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 Code:
https://bitbucket.org/multicoreware/x265/commits/branch/default |
3rd October 2017, 11:38 | #5618 | Link |
x265 2.5+22-8db95a1da9f8 (MSYS/MinGW, GCC 7.1.0) ... does XhmikosR still update?
Fixes for analysis load, WPP, bitstream payload size, VBV hanging; new (internal?) parameter for disabling lookahead; Windows DLL will export x265_encoder_ctu_info() |
6th October 2017, 19:40 | #5619 | Link | |
Of course it can also lose detail in moving areas as well. |
7th October 2017, 12:46 | #5620 | Link |
x265 v2.5+25-4b95f82c9fb1 (GCC 7.2.0, 32 & 64-bit 8/10/12bit Multilib Windows Binaries)
x265 [info]: HEVC encoder version 2.5+25-4b95f82c9fb1 x265 [info]: build info [Windows][GCC 7.2.0][32/64 bit] 8bit+10bit+12bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 Code:
