26th January 2014, 12:28 | #21921 | Link | |
But changing to film mode with refresh change (86.11) crashes mpc-hc.exe, But 87.1b only blackens the image which is better. Madshi, Its an OLD bug. Overall, 87.1b is more stable and faster with my system.
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410. Last edited by James Freeman; 26th January 2014 at 12:51. |
26th January 2014, 12:30 | #21922 | Link | ||
Try the 871a or 871b test build. |
26th January 2014, 12:42 | #21924 | Link | |
87.1b works much faster than even 86.11.
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410. |
26th January 2014, 13:03 | #21925 | Link | |
Anyway, NVIDIA GTX 660Ti, Win 7 64bit. |
26th January 2014, 13:05 | #21926 | Link | |
@madshi: 0.87.1b doesn't fix the issue. When Smooth Motion is off the only difference between 0.86.11 and 0.87.1b is that "split" takes ~50% more time. With Smooth Motion on though, "split", "deinterlace", and "rendering" all take ~100% more time, and "present" takes ~200% more time.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
26th January 2014, 13:07 | #21929 | Link |
DragonQ, your GT 430 is quite old by now, maybe thats where the big difference comes from.
26th January 2014, 13:12 | #21930 | Link |
These numbers look unrealistic. I seriously doubt their accuracy.
26th January 2014, 13:15 | #21931 | Link | |
Bad news - the 87.1b version breaks the previous fixed build. Fullscreening to second display is now broken again. This is without nnedi3 ticked of course. |
26th January 2014, 13:17 | #21932 | Link | |||
Kid for Today
Well, I left "ITC Processing" enabled in the HD7850 drivers and that would supposedly do a lot of wonderful things on FS videos...maybe that's my problem, will run more tests.
Yep, either flavor of DXVA2 seems equally flaky and checking "use OpenCL to process DXVA2" in mVR doesn't help. Quote:
Yep, I've seen that and I think I really like the new error diffusion dithering Quote:
so I can use Intel's Quicksync for video decoding and output its result on the HD7850? Neato, will give it a shot. Last edited by leeperry; 26th January 2014 at 13:46. |
26th January 2014, 13:26 | #21933 | Link | ||
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410. Last edited by James Freeman; 26th January 2014 at 14:10. |
26th January 2014, 13:27 | #21934 | Link |
testing the ayaka MSSL12.ts clip for performance (mpeg2, 1440x1080 upscaled to 1080p; 29,97 fps), 0.871b is a little faster for me than 0.8611
0.8611: without deinterlacing: 17.20ms with deinterlacing: 17.50ms + deint: 3.30ms 0.871b: without deinterlacing: 16.00ms with deinterlacing: 16.90ms + deint: 2.95ms
26th January 2014, 13:28 | #21935 | Link | |
these are all screens from 86.11
ivtc doesn't really care about queues but deinterlacing... how to judge performance this way. even if amd in this case is changing the deinterlacing mode because the number of buffered frames is to low why are the rendertimes affected? Quote:
26th January 2014, 13:29 | #21936 | Link |
Just tested 87.1b on AMD HD4550 (quite old, quite slow). Everything is working fine so far. I didnīt test everything (e.g. deinterlacing), but for my typical usage scenario everything works. No black or bluescreens, freezes, stuttering or other unwanted behaviour. I unticked every box in trade quality, ticked the opencl stuff. I tried NNEDI3 for chroma upscaling, it works. I only play 720p without scaling on a projector, by using software decoding, debanding (works great!), involving a 3DLUT and using Bicubic AR chroma upscaling without the need of smoothmotion (I have accurate refresh rates by custom Powerstrip resolutions) I get 70% GPU usage. So ALL features of recent madvr version concerning quality are still usable on my good old GPU. Clearly there is no more headroom left for playing back 1080p or scaling other than native resolution, but for my needs itīs great!
Great work madshi, I had to give a positive feedback right at this time, when 9 out of 10 users report problems at the moment. Forget about NVIDIA, just define AMD or Intel as a system requirement for using madvr |
26th January 2014, 13:36 | #21937 | Link | |
On my system, I am not able to see any performance improvement with 871b for interlaced videos. Last edited by omarank; 26th January 2014 at 13:41. |
26th January 2014, 13:59 | #21938 | Link |
madshi:
With my VC1 1080i test file, .87b makes substantial perf gains for deint: DXVA Native (FSE Mode): .86: ~7.3ms, full queues, perfect playback .871: ~18.2ms, starved render/backbuffer, many drops .871b: ~4.10ms, full queues, perfect playback DXVA CB (FSE Mode): .871: ~7.5ms, full queues, perfect playback .871b: ~2.75ms, full queues, perfect playback HD6570 |
26th January 2014, 14:13 | #21939 | Link | |
One way to fix the problem is to use CUVID (on my NVS 5200M), since that handles the deinterlacing and then all MadVR has to do is mix frames and downscale on the HD4000 (75% load, same as with 0.86.11). I imagine the hugely increased stat times I'm seeing is due to the GPU being maxed out and thus not doing everything asked of it quickly enough when deinterlacing and smooth motion are both being used. The problem is likely a smaller performance regression that pushes the load from 85-90% (0.86.11) to above 100% (0.87.1b). I can't imagine the fact I have Optimus is an issue, since when the decoder is set to anything but CUVID the nVidia card has 0% load (and thus is presumably asleep).
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 Last edited by DragonQ; 26th January 2014 at 14:39. |
26th January 2014, 14:42 | #21940 | Link | |
87.1b normal(high) queue settings low queue settings for 86.11 see above edit i have a watch at the hd4000 later maybe a intel only problem? |
