2nd August 2009, 00:11 | #4321 | Link | |
2nd August 2009, 02:05 | #4322 | Link |
i didnt change any of the settings, im sorry but i dont know what DTS or AC3 is, what difference would it make if i reencoded to AC3? if you could briefly explain that would be great, i did full backup to bd25, and movie only backop to bd9 and both had exact same issues, used beta 25.04, running windows 7
2nd August 2009, 08:05 | #4323 | Link | ||||
Movie = Day After Tomorrow Any Ideas what may have caused this ] - Quote:
2nd August 2009, 08:45 | #4324 | Link |
@jdobbs
DB-RB v0.26.01 If the field-based interlaced or hybrid VC-1 video is small enough i.e. not requiring compression to fit on the target, it is copied intact. The .mkv intermediate step is then apparently skipped and playback fails. In such case the .mkv step should be forced -- if my interpretation of the cause of the playback failure is correct. Last edited by Sharc; 2nd August 2009 at 08:50. |
2nd August 2009, 09:59 | #4325 | Link |
@jdobbs
Latest beta's exe is recognized by McAfee as Artemis Malware. Just FYI For all of the users of McAfee I'd hotly recommend these links: https://kc.mcafee.com/corporate/inde...ent&id=KB53735 https://kc.mcafee.com/corporate/inde...=1249204244621 there are some levels of Artemis protection... L0 Sets "Very Low" on OAS, ODS and Email scan L1 Sets "Low" on OAS, ODS and Email scan And so on (read above pages). In my Viruscan Plus environment you can tweak the settings by opening the Register Editor and pointing at HKEY_LOCAL_MACHINE\SOFTWARE\McAfee\VirusScan\Artemis You just need to tweak OAS, because running BD_Rebuilder won't be done from email NOTE: this hint is only for advanced users knowing their stuff. That's why I'm not going into a step by step guide Last edited by daberti; 2nd August 2009 at 10:23. |
2nd August 2009, 10:15 | #4326 | Link |
Installed 3 Different version of FFDShow(not sure in which order I believe 64Bit, 32Bit,& then a multithread version [ffdshow_rev3048_20090731_clsid_icl10] & Then ran the Win7DSFilterTweaker_1.4). I dont know how or why but I am back in business and Watchmen Full Disc appears to be working. Thanks for that post suggestion JDobbs! And again for all your efforts!
2nd August 2009, 14:14 | #4328 | Link | |
2nd August 2009, 14:29 | #4330 | Link |
Interesting that I downloaded BD-RBV02601 and ran a full movie backup last night, it completed successfully, and then auto shutdown. This morning I boot up, and open BD-RB, and McAfee goes off. I did not even see an update from McAfee. This can get a bit frustrating, speaking calmly.
2nd August 2009, 14:39 | #4331 | Link | |
What disc are you working? |
2nd August 2009, 14:42 | #4332 | Link | |
2nd August 2009, 15:20 | #4333 | Link |
@jdobbs;
I have been checking a recent BD-RB PiP backup of Batman Begins with the original with CLIPINF Editor, and I have noticed a difference in the way it sees the Stream PID of the original versus BD-RB. It appears normal audio tracks have a Stream PID of 1100, 1101, 1102 etc..., while secondary audio has 1A00. Video is 1B00. On my BD-RB backup, secondary audio is seen as 1102, the two audio tracks I kept, 1100 and 1101, plus the secondary PiP audio 1102. This backup does seem to work fine, so you have adjusted the secondary audio to the correct track number. But does Blu-Ray compliance need to follow a certain standard ? |
2nd August 2009, 15:26 | #4334 | Link | |
Thanks for that! |
2nd August 2009, 15:59 | #4336 | Link | |
[14:17:10] BD Rebuilder v0.25.04 (beta) - Source: FAST_AND_FURIOUS - Input BD size: 45.34 GB - Approximate total content: [02:24:40.004] - Target BD size: 22.46 GB - Resuming from previously started job. [14:17:11] PHASE ONE, Encoding - [14:17:11] Collecting video information [00010] - Video: 1920x1080, 23.976fps, 153,744 frames - Bitrate: 3,357 Kbs - [14:17:11] Reencoding: VID_00010, Pass 1 of 2 - [16:00:40] Reencoding: VID_00010, Pass 2 of 2 - [18:59:43] Video Encode complete - [18:59:43] Reencoding audio tracks (if req'd) - [18:59:43] Multiplexing M2TS - [19:03:09] Extracting A/V streams [VID_00050] - [19:03:11] Collecting video information [00050] - Audio/PGS sizing issue. Continued... - Video: 1920x1080, 23.976fps, 1,465 frames - [02:04:16] Reencoding: VID_00050, Pass 1 of 1 - [02:04:16] Reencoding: VID_00050 (2 of 15) - [02:05:10] Video Encode complete - [02:05:10] Reencoding audio tracks (if req'd) - [02:05:10] Multiplexing M2TS - [02:05:12] Extracting A/V streams [VID_00061] - [02:05:14] Collecting video information [00061] - Audio/PGS sizing issue. Continued... - Video: 1920x1080, 23.976fps, 1,296 frames - [02:05:19] Reencoding: VID_00061, Pass 1 of 1 - [02:05:19] Reencoding: VID_00061 (3 of 15) - [02:06:05] Video Encode complete - [02:06:05] Reencoding audio tracks (if req'd) - [02:06:05] Multiplexing M2TS - [02:06:06] Extracting A/V streams [VID_00062] - [02:06:09] Collecting video information [00062] - Audio/PGS sizing issue. Continued... - Video: 1920x1080, 23.976fps, 1,560 frames - [02:06:13] Reencoding: VID_00062, Pass 1 of 1 - [02:06:13] Reencoding: VID_00062 (4 of 15) - [02:07:12] Video Encode complete - [02:07:12] Reencoding audio tracks (if req'd) - [02:07:12] Multiplexing M2TS - [02:07:14] Extracting A/V streams [VID_00064] - [02:07:17] Collecting video information [00064] - Audio/PGS sizing issue. Continued... - Video: 1920x1080, 23.976fps, 1,978 frames - [02:07:21] Reencoding: VID_00064, Pass 1 of 1 - [02:07:21] Reencoding: VID_00064 (5 of 15) - [02:08:33] Video Encode complete - [02:08:33] Reencoding audio tracks (if req'd) - [02:08:33] Multiplexing M2TS - [02:08:35] Extracting A/V streams [VID_00078] - [02:08:38] Collecting video information [00078] - Audio/PGS sizing issue. Continued... - Video: 1920x1080, 23.976fps, 1,128 frames - [02:08:42] Reencoding: VID_00078, Pass 1 of 1 - [02:08:42] Reencoding: VID_00078 (6 of 15) - [02:09:21] Video Encode complete - [02:09:21] Reencoding audio tracks (if req'd) - [02:09:21] Multiplexing M2TS - [02:09:23] Extracting A/V streams [VID_00202] - [02:09:28] Collecting video information [00202] - Audio/PGS sizing issue. Continued... - Video: 1920x1080, 23.976fps, 2,616 frames - [02:09:29] Reencoding: VID_00202, Pass 1 of 1 - [02:09:29] Reencoding: VID_00202 (7 of 15) - [02:11:06] Video Encode complete - [02:11:06] Reencoding audio tracks (if req'd) - [02:11:06] Multiplexing M2TS - [03:22:02] Extracting A/V streams [VID_00238] - [03:22:03] Collecting video information [00238] - Video: 1920x1080, 23.976fps, 191 frames - Bitrate: 500 Kbs - [03:22:03] Reencoding: VID_00238, Pass 1 of 2 - [03:22:09] Reencoding: VID_00238, Pass 2 of 2 - [03:22:14] Video Encode complete - [03:22:14] Reencoding audio tracks (if req'd) - [03:22:14] Multiplexing M2TS [03:22:15]PHASE ONE complete [03:22:15]PHASE TWO - Rebuild Started - [03:22:15] Rebuilding BD file Structure [03:26:12] - Encode and Rebuild complete - WORKFILES folder removed. [03:26:12]JOB: FAST_AND_FURIOUS finished. |
2nd August 2009, 16:02 | #4337 | Link | |
You are right of course that copying the m2ts file intact should have no playback issues on a standalone player. The problem I have is with SW player (mpc-hc, vlc) which cannot play the sample clips (VC-1, field-based interlaced, or hybrid interlaced - progressive) which I posted/uploaded earlier -- the samples are excerpts from Extras of Hulk 2 Region B. http://forum.doom9.org/showthread.ph...81#post1310481 However, when I make a blu-ray structure from these sample clips using tsMuxeR and force a re-encode with v0.26.02 the re-encoded .m2ts (AVC) can be played back with VLC (and with mpc-hc but audio/video desynched). So after all it may be just a SW player/decoder issue and nothing to really worry about. Last edited by Sharc; 2nd August 2009 at 16:27. |
2nd August 2009, 17:40 | #4338 | Link |
Banned
i did watchmen and it ran fine but it doesnt play the movie nor / title scenes or anything else, but the disc is full is it a bdr issue? and yes i tried it on my sony s350 player and computer using powerdvd and total media theatre 3 platinum, it plays the blu ray title scenes at the beginning / trailer scene etc
2nd August 2009, 17:41 | #4339 | Link | |
