17th September 2005, 18:01 | #102 | Link | |
clueless n00b
18th September 2005, 02:29 | #103 | Link |
結城有紀
Hey, did anyone test my sample?
and i met more problems now: i compressed a lot of avi files, simply using avisource. x264 just compressed about half of the file, and stopped and said successfully compressed but the result file is obviously completely broken. all jobs failed except only one works....... see attachment for avs&log |
18th September 2005, 03:54 | #104 | Link | |
retired developer
+ EBML head + Segment, size 108949416 |+ Seek head (subentries will be skipped) |+ EbmlVoid (size: 4027) |+ Segment information | + Timecode scale: 1000000 | + Muxing application: libebml v0.7.5 + libmatroska v0.7.7 | + Writing application: mkvmerge v1.5.6 ('Breathe me') built on Sep 7 2005 18:18:22 | + Duration: 1731.512s (00:28:51.512000000) | + Date: Sat Sep 17 10:39:14 2005 UTC | + Segment UID: 0xa2 0xd9 0x45 0x6c 0xef 0x5e 0xe8 0x01 0xbb 0x3a 0x2c 0xa9 0xd 9 0xef 0x62 0xc9 |+ Segment tracks | + A track | + Track number: 1 | + Track UID: 905473676 | + Track type: video | + Default flag: 1 | + Forced flag: 0 | + Lacing flag: 0 | + MinCache: 1 | + Timecode scale: 1.000000 | + Max BlockAddition ID: 0 | + Codec ID: V_MPEG4/ISO/AVC | + CodecPrivate, length 38 | + Default duration: 10.347ms (96.646 fps for a video track) | + Language: und | + Video track | + Pixel width: 704 | + Pixel height: 400 | + Display width: 704 | + Display height: 400 | + A track | + Track number: 2 | + Track UID: 3167492503 | + Track type: audio | + Default flag: 1 | + Forced flag: 0 | + Lacing flag: 1 | + MinCache: 0 | + Timecode scale: 1.000000 | + Max BlockAddition ID: 0 | + Codec ID: A_AAC/MPEG4/LC/SBR | + Default duration: 46.440ms (21.533 fps for a video track) | + Language: und | + Audio track | + Sampling frequency: 22050.000000 | + Channels: 2 | + Output sampling frequency: 44100.000000 |+ EbmlVoid (size: 1024) |+ Cluster
Detritus Software |
18th September 2005, 04:02 | #105 | Link |
retired developer
MP4 in MKV, it seems that it's libavcodec.dll that crash.
Detritus Software |
18th September 2005, 10:29 | #106 | Link |
gone
@Meteorain:
Yes, it crashes here too in both mplayer (latest CVS) and DirectShow. So it is either a bug in x264 or libav. Of course this raises the question: what settings did you use?(AVS scipt and commandline) (Don't post them as attachment please) |
18th September 2005, 17:59 | #107 | Link |
Member
We had reports of borked libavcodec_dec.dll with similar troubles in the last CCCP, solved my going to the latest CVS non-dec version.
@Sirber, I think it has to be something at your end...I just used 292A to complete your (x264 --> mp4) --> mkv test as well. |
18th September 2005, 18:06 | #108 | Link |
retired developer
Where could I get such a build?
Detritus Software |
19th September 2005, 10:24 | #109 | Link | ||||
結城有紀
@stephanV
let me just post the avs and log for another sample (meet exact the same problem i bet) Quote:
And an OK sample: Quote:
19th September 2005, 10:37 | #110 | Link |
gone
Well... you're settings are a bit ackward, but that should never cause a crash of course...
Maybe its the combination of many b-frames and b-pyramid that libav doesnt like... do you have the Nero decoder to test? (I guess not) |
19th September 2005, 12:57 | #112 | Link |
gone
Haali is obviously better at guessing than me
http://savefile.com/files/2005757 <--- test file AVS script: Code:
Avisource("test.avi") assumefps(3.142) Code:
x264 -o test.mp4 test.avs You probably can use any weird non-integer frame rate to emulate the problem (just make sure you use enough frames too). |
19th September 2005, 19:05 | #116 | Link |
retired developer
All my files are use "non-integer fps" and are "b0rked", unless I use RAW. I think we are on the path of bug killing
Detritus Software |
19th September 2005, 20:09 | #117 | Link | |
clueless n00b
So it's not so much about non integer FPS streams, but possibly those that have weird dwScale (and dwRate?) values. Here's what I get if I add assumefps(3.142) to a perfectly working 23.976 fps script: dwRate = 13178503, dwScale = 4194304. I'm encoding now to see what the results are (I used that same script without assumefps and successfully created a properly working mp4 and mkv (that can be remuxed) from it)) Those that can debug MeGUI.. open a script, set a breakpoint in AviReader.cs at the line framerate = (double)streamInfo.dwRate/(double)streamInfo.dwScale; and check out dwRate and dwScale for clips that don't work.
19th September 2005, 20:27 | #118 | Link | |
gone
19th September 2005, 21:35 | #120 | Link | |
clueless n00b
1001 is used on DVD (probably stems from the fact that film is 24fps and if you do 3:2 pulldown you have to use drop frames so it'll be 29.97) VFW seems to be using the more straightforward values.
Either way, not surprisingly my mp4 ended up being corrupt as well and mkvmerge complained upon importing: Quote:
