9th March 2009, 00:17 | #1901 | Link | |
Aging Video Hobbyist
But, I'm speaking in terms of tsMuxeR.exe standalone, and not in the context BD-RB which I have only tried a handful of times. |
9th March 2009, 00:33 | #1902 | Link | |
x264 developer
9th March 2009, 00:44 | #1903 | Link |
according to this site http://www.blu-ray.com/faq/
max bitrate for blu-ray is 40 mbps but for unknown reason BD-RD uses only 25Mbps
9th March 2009, 00:46 | #1904 | Link | |
x264 developer
9th March 2009, 00:53 | #1905 | Link | |
http://forum.blu-ray.com/showpost.ph...4&postcount=16
9th March 2009, 01:08 | #1906 | Link | |
x264 developer
9th March 2009, 01:08 | #1907 | Link |
I tried to compress Few Good Men and the audio extraction worked fine but this is what i got for video. For some reason, my encoding doesn't start. I have the latest ffdshow with all video decoder config set as needed.
----------------------- [19:59:47] BD Rebuilder v0.20.03 (beta) - Source: 35990120_FEWGOODMEN - Input BD size: 36.83 GB - Approximate total content: [02:18:01.272] - Target BD size: 4.27 GB - MOVIE-ONLY mode enabled - Resuming from previously started job. [19:59:48] PHASE ONE, Encoding - [19:59:48] Reencoding: VID_00141 (1 of 1) - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [19:59:51] - Failed video encode, aborted what am i missing? |
9th March 2009, 02:35 | #1909 | Link |
Error
LOG:
[20:49:27] BD Rebuilder v0.20.03 (beta) - Source: BANGKOK_DANGEROUS - Input BD size: 38.48 GB - Approximate total content: [02:30:50.708] - Target BD size: 22.90 GB [20:49:33] PHASE ONE, Encoding - [20:49:33] Extracting audio/subs [VID_00028] - [20:49:38] Reencoding: VID_00028 (1 of 11) - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [20:49:54] - Failed video encode, aborted Config: [Options] MODE=0 QUICK_EXTRAS=1 PRIORITY_CLASS=0 RESIZE=0 TARGET_SIZE=23450 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all TRELLIS=1 COLOR_BOOST=1 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=1 AC3_640=0 AVCHD=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 [Paths] SOURCE_PATH=C:\BANG\BANGKOK_DANGEROUS\ WORKING_PATH=C:\BD_RB WORK\ |
9th March 2009, 02:52 | #1910 | Link | |
Okay i think i have fixed this issue that might have been my fault...I went into ffdshow video decoder & enable mpeg2.Now its working so far....Thxs |
9th March 2009, 03:15 | #1911 | Link |
^ mine is already enabled. Still having the same error.
[22:13:37] BD Rebuilder v0.20.03 (beta) - Source: 35990120_FEWGOODMEN - Input BD size: 36.83 GB - Approximate total content: [02:18:01.272] - Target BD size: 4.27 GB - MOVIE-ONLY mode enabled - Resuming from previously started job. [22:13:38] PHASE ONE, Encoding - [22:13:38] Reencoding: VID_00141 (1 of 1) - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [22:13:41] - Failed video encode, aborted [Options] MODE=1 QUICK_EXTRAS=0 PRIORITY_CLASS=1 RESIZE=0 TARGET_SIZE=4369 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; TRELLIS=1 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=0 AVCHD=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 ENCODER=0 VERBOSE_STATUS=0 [Paths] SOURCE_PATH=E:\FGM\35990120_FEWGOODMEN\ WORKING_PATH=E:\WORKING\ |
9th March 2009, 04:52 | #1912 | Link | |
the one on the right is the original rip of the extended edition playlist, the one on the left is the BD-RB rip of the same playlist. as you can see, there are differences in the IN Time and OUT Time of the Playlist and PlaylistMark headings. not sure if they are supposed to be different. and just for clarification, there are two menus on the BD. one is for the theatrical version, one for the extended version. you can only play the extended version, from the correct main menu. and you can switch back and forth between the theatrical edition menu, and the extended edition menu. as of right now, i am making another rip, this time including all audio and subtitles to see if it makes any difference. Last edited by rmeyers; 9th March 2009 at 05:12. |
9th March 2009, 06:34 | #1913 | Link |
Looks like the " CorrectMPLS() 00009 5" problem on rebuild was corrected with the new version BD-RBV02003, but a new issue has developed. The burned disc does play, but I now hear a "seeking/cycling" sound from my Sony BDP-BX1 while playing, as if it is struggling to play. So if I try to fast forward the player freezes for several seconds, and if I change chapters, the same happens but then the player does not recover from the still image/freeze. I then have to press stop just to get the player to respond.
This was a full movie backup to BD-5, resize to 720P, default audio re-encode to 448kbps on Nights In Rodanthe. |
9th March 2009, 11:38 | #1914 | Link | |
9th March 2009, 11:42 | #1915 | Link | |
9th March 2009, 11:44 | #1916 | Link | |
9th March 2009, 12:05 | #1917 | Link | |
[Edit] I've noticed, though, that if someone uses splitting in TSMUXER the packet count issue is still there. Last edited by jdobbs; 9th March 2009 at 14:44. |
9th March 2009, 14:46 | #1918 | Link | |
I suppose tho if some folks are burning BD-5/9 as booktype DVD-ROM, and their SAP plays it but refuses to spin at >1x, this could cause stops & starts huh. P.S. I've used 25000/25000 and then 17500/14745 and now the other day I encountered "buffer underflows" in x264 for the first time. Changing to 25000 fixed that and I'm going to leave it there as at least my player works great w/25000/25000. Last edited by laserfan; 9th March 2009 at 14:49. |
9th March 2009, 14:48 | #1919 | Link |
@rmeyers
The BDEdit displays you are showing are correct. TSMUXER uses a fixed PTS starting value (00:10:00.000) that may be (and usually is) different than the original. Most commercial discs use a value of 00:00:11.650. BD Rebuilder updates the CLPI and MPLS so the values match the new PTS values. The fact that it shows in the tables of BDEdit is just proof that they have been correctly updated. The alternative is to scan through the M2TS and change all the clock values, but it takes too much time that way, and you reach the same result either way. You just have to make sure the M2TS and CLPI/MPLS combinations match. Actually BD Rebuilder does do the scan/correction of DTS/PTS and other clock values in the M2TS stream for certain types of files, but they are typically much smaller. Last edited by jdobbs; 9th March 2009 at 14:56. |
9th March 2009, 14:52 | #1920 | Link | |
Oh, my--you were typing the answer as I was typing my question! |
