4th May 2012, 02:44 | #13082 | Link |
How to activate tearing test? I cant seem to do it with the hotkey and its not available in the context menu. I'm getting tearing between scene transitions, at least i think its tearing. Pixelated vertical lines halfway for a split second with interlaced video forced into film mode. But it could be the video's fault I pretty much get the same thing with wmp. Is there anyway to get rid of it? Oh and im using old path, since the normal one gets glitches.
4th May 2012, 12:20 | #13083 | Link | |
Chroma Upscaling: Mitchell-Netravali. This is objectively better than all other scaling algorithms in most test cases. The other option would be Bicubic 75, which handles fine details better, but can exhibit ringing. Luma Upscaling: This is based on personal preference. My preference is to have as little ringing or aliasing as possible, which I feel is doubly important with animated content. So personally, I use SoftCubic 80. It is soft, but it avoids exaggerating any artefacts in the source, or adding any of its own. From softest to sharpest, I would say that the viable options are:
For a more detailed comparison with example images, see this post. (it was done before Bicubic 100 was introduced, but there's far too much ringing with it) |
4th May 2012, 18:00 | #13084 | Link |
6233638, if the scenario would be upsampling 720p to a 46" screen at 1920x1080 would your recommendations be the same? The content would be movies and not anime, in this case.
Thanks Bat
Win 11 x64, Geforce RTX 4060 Ti 16GB, TV Sony KD-55X8509C HDMI, Denon AVR-X2700H, Core i7-9700K, 32GB DDR4, Creative Labs Gigaworks S750 7.1 speakers MPC Home-Cinema madVR LAV Filters |
4th May 2012, 18:24 | #13085 | Link | |
At the end of the day though, scaling algorithms are all down to personal preference, but any of the options that haven't been listed in my previous post, are objectively worse and shouldn't be used in my opinion. (because there are better options that give you a similar look with less negative effects) |
4th May 2012, 20:58 | #13086 | Link | |
Most people like the sharpness and do not notice the ringing from the sharper resizes but I do agree that once you start noticing ringing it is very unpleasant, especially with animated content. A 3 tap spline doesn't ring too much and I like the sharpness but it is also pretty close to Mitchell-Netravali or bicubic 75. All the resizers offer tradeoffs and there really isn't an "objectively better" one. |
4th May 2012, 22:43 | #13087 | Link |
Custom presenter
Is it possible somehow to use madVR by feeding it with a custom presenter interface?
Or at least register some callbacks which get called with the new surface for each frame? A quick look at the interfaces seem not to have anything. It actually impedes me from using madVR in my player which presents surfaces on a Direct3D image used as a imagesource in WPF. WPF is part of .NET (managed world), so to transparently feed it with video while preserving speed surfaces are passed for drawing to the GPU through the native-managed barrier. For VMR and EVR this is not a problem (allocator/custom presenter)... For the EVR presenter I'm using feeding the renderer with the following callback: Code:
public int PresentSurfaceCB(IntPtr pSurface) Right now I can use it only with it popping out his own window / no integration with the player |
5th May 2012, 02:41 | #13088 | Link | |
I fully expect most people to dislike SoftCubic 70/80 for Luma scaling, but it avoids adding any ringing to the source, or exaggerating compression artefacts, without blurring detail. After watching content for a while with it, I don't notice the softness, but rather, I can focus on the image. with other scaling algorithms, I am always noticing ringing or aliasing which is distracting me from watching the content itself. If you prefer sharpness but can tolerate some aliasing, Mitchell-Netravali would be my recommendation for scaling, or if you want sharpness without aliasing, and can tolerate some ringing, then it would be Bicubic 75. Anything sharper (Spline 3 or Lanczos 3) adds considerable ringing for little benefit in my opinion. (there is no more detail to be brought out from the source, you're just exaggerating the edges) I have to disagree. Any of the other options have similar levels of sharpness, aliasing or ringing to one of the algorithms on my shortlist, but are considerably worse in one (or more) of the three. Catmull-Rom is a poor choice due to (if I remember correctly) high levels of aliasing and quite a bit of ringing. Bicubic 75 or Mitchell-Netravali are objectively better due to similar levels of sharpness, but considerably less aliasing, or ringing, respectively. |
5th May 2012, 09:20 | #13090 | Link | |
I than sought an alternative for softcubic 70/80, that introduced as less artifacts as possible, but was sharper. I ended up with M-N for both chroma and luma, just as you description. But a question though: Do you use the 'scale in linear light' parameter ? |
6th May 2012, 02:50 | #13093 | Link | |
And despite decent upscaling being *a must*, the renderer is still useless. Guess you can never watch movies then. Just saying, you have some weird first posts on this site... |
6th May 2012, 09:03 | #13094 | Link |
Finally got my 3570K working (Asus forgot to put a jumper in RTC Clock reset, made me unable to power it up. Spend half a day before I tried put one from an old hdd.)
From my initial test, Intel HD4000 handle madVR (chroma: softcubic, luma: spline 3 taps) just fine. I tried 1920x1080@23.976p to 2560x1600@60Hz and having no problem. Now I have no need for discrete graphic aside from gaming. Idle power consumption drop from ~75w to 40w as well. This is nice.
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. Last edited by Hypernova; 6th May 2012 at 18:37. Reason: typo |
6th May 2012, 12:18 | #13095 | Link | |
__________________ System: Intel Core i5-6500, 16GB RAM, GTX1060, 75" Sony ZD9, Focal speakers, OS Win10 Pro, Playback: madvr/JRiver |
6th May 2012, 13:35 | #13096 | Link | |
can you please try some high bitrate 720p 60Hz content both in software and quick sync decode modes? Is the HD4000 enough? btw which Asus board are you using? I plan to rebuild my bedroom HTPC and was hoping to avoid the need for a standalone graphics card.
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V Win 10 64bit 1803 + Zoom Player v14 |
6th May 2012, 13:41 | #13097 | Link |
720p60 content works, as long as you don't use the QuickSync decoder. Combining it with madVR is too much for the GPU.
6th May 2012, 18:34 | #13098 | Link | |
I use P8Z77-V LK, since it's the cheapest Z77 board with DisplayPort available when I shop. Edit: I tried the Avatar60p clip from the other thread (1080p) and indeed as nevcairiel said, if you use QS+madVR I got drop frames. Not sure if overclocking GPU+Ram will help.
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. Last edited by Hypernova; 6th May 2012 at 21:18. |
6th May 2012, 22:09 | #13099 | Link |
I use QS+madVR just fine on a i72600K-3000 with 50/60fps material under Exclusive Mode with just two changes:
- Scaling: Mtichell-Netravali look agread and are less resource intensive than the tap based ones - Exxclusive mode settings: "run presentation in a seperate thread" Not dropped frame in sight! |
6th May 2012, 22:21 | #13100 | Link | |
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. |
