29th April 2012, 23:52 | #11041 | Link | |
i have 100/10 meg broadband btw :-) shame i cannot utilise distributed on the linux server, if anyone can get it to work please pm me :-) Last edited by Zorro70; 29th April 2012 at 23:55. |
30th April 2012, 08:22 | #11043 | Link |
rc71
lol answer to your bug report is on previous page regarding mediainfo . i just made graphic interface. zenitram is a creator of mediainfo.dll
30th April 2012, 08:28 | #11044 | Link |
DVD Subtitle Problem
Hey Atak,
Thanks for this awesome update of Ripbot264. The dvd subtitle extraction was about the only thing i was missing in it. Now onto the error or bug. When I load Copycat into ripbot and it starts extraccting the subtitles i get and error. java.lang.NullPointerException deadbeef.Tools.ToolBox.getWord(ToolBox.java:215) deadbeef.SupTools.SubDVD.readSubFram(SubDVD.java:991) deadbeef.SupTools.SubDVD.(SubDVD.java:143) deadbeef.SupTools.Core.readDVDSubstream(Core.java:1323) deadbeef.SupTools.Core.readVobSub(Core.java:1283) BDSup2Sub.main(BDSup2Sub.java:823) I get this error a few times and i click ok and it finishes extracting the rest of the subtitles. I've tried both the original SeperateDVDSubs.exe and your updated one. Don't know if it's RipBot or some other culprit in this case. Cheers Trayman |
30th April 2012, 08:28 | #11045 | Link |
problem with m2ts is that it requires user's interaction. you have to select correct playlist , audio.
30th April 2012, 08:31 | #11046 | Link |
trayman
send me subtitles.idx and subtitles.sub
30th April 2012, 08:55 | #11047 | Link | |
30th April 2012, 09:59 | #11048 | Link | |
My DVD rip doesn't have idx files. Only ifo, bup and vob files. I'm lost now. Last edited by rc71; 30th April 2012 at 10:11. |
30th April 2012, 11:23 | #11050 | Link |
post mediainfo report of original file.
30th April 2012, 12:11 | #11051 | Link |
General
Unique ID : 314448056959441085166052319083888028048 (0xEC907E2DBA6BD056186AEB00E116A990) Complete name : F:\video.mkv Format : Matroska Format version : Version 1 File size : 12.3 GiB Duration : 1h 38mn Overall bit rate mode : Variable Overall bit rate : 18.0 Mbps Encoded date : UTC 2012-04-30 08:28:22 Writing application : eac3to Writing library : Haali DirectShow Matroska Muxer 1.11.288.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Muxing mode : Container profile=Unknown@0.0 Codec ID : V_MPEG4/ISO/AVC Duration : 1h 38mn Bit rate mode : Variable Bit rate : 17.6 Mbps Maximum bit rate : 28.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 24.000 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.355 Stream size : 12.1 GiB (98%) Default : No Forced : No Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 |
30th April 2012, 12:25 | #11052 | Link |
and you say that ripbot264 reports that file as 25 fps? Show me screenshot.
30th April 2012, 13:15 | #11054 | Link |
That's odd. However you can easily force 24 fps in script
30th April 2012, 13:52 | #11055 | Link |
I got: video=DirectShowSource("F:\video.mkv",audio=false).ConvertToYV12()
do I have to change it to: video=DirectShowSource("F:\video.mkv",audio=false,fps=24).ConvertToYV12() ? Resloved. The fps is chaning automatically after changing it from script. Thanks. Last edited by Gabes; 30th April 2012 at 13:57. |
30th April 2012, 15:50 | #11057 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 30th April 2012 at 15:59. |
30th April 2012, 19:51 | #11059 | Link |
I didn't like the result (wasn't exactly 16/9) so I auto-cropped and streched the video to 1920x1080 (job was loaded yesterday). When I exited that menu, I got that error.
No distirbuted encoding was used. I edited last night's job. When I reloaded the movie today and did exactly the same steps, there were no errors. I'll try and reproduce the error, tomorrow (after compression) to write you exactly what it said. Last edited by slalom; 30th April 2012 at 19:53. |
30th April 2012, 20:35 | #11060 | Link |
that job was created with older version 1.17.0?
