Old 10th August 2018, 23:25   #61  |  Link
~ VEGETA ~
The cult of personality
~ VEGETA ~'s Avatar
i try to install a certain package like "mv" but it doesn't do a thing... cli doesn't change after my command "python vsrepo install mv" for so long. what is the problem?
I have python 3.6 and x64-bit and I am using your latest github script.
~ VEGETA ~ is offline   Reply With Quote
Old 11th August 2018, 00:50   #62  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
You probably need to male it vsrepo.PY for ot to work
Myrsloik is offline   Reply With Quote
Old 11th August 2018, 01:40   #63  |  Link
~ VEGETA ~
~ VEGETA ~'s Avatar
Actually I put it .py but didn't write it properly here
Old 11th August 2018, 04:13   #64  |  Link
~ VEGETA ~
~ VEGETA ~'s Avatar
Now works good but I couldn't find lsmas here. My python is 64 bit thus plugins32 in VS directory probably won't be used? so I need lsmas for x64?
Old 11th August 2018, 08:34   #65  |  Link
ChaosKing
Yes, everything (except scripts) needs to be 64bit to work together.
lsmas is not available in vsrepo yet.
Old 13th August 2018, 22:18   #66  |  Link
Myrsloik
Myrsloik's Avatar
Speaking of that. I wish someone would adopt lsmas and the orphaned scripts without proper github repos. I really can't go around adding random dropbox links to stuff.
This is especially easy to do for scripts and would only require minimal effort in case someone submits a pull request.
hint hint wink wink
Old 13th August 2018, 23:22   #67  |  Link
ChaosKing
Are there many orphaned scripts? I could only find 1-2 ...
//Edit
But I guess every script would need its own git repo!? A collection wouldn't work with your git update logic, correct?
Old 13th August 2018, 23:23   #68  |  Link
Myrsloik
Myrsloik's Avatar
Maybe only 1-2. That's still 1-2 too many.
Old 14th August 2018, 08:57   #69  |  Link
Myrsloik
Myrsloik's Avatar
//Edit
Yes, they'd need a separate repo. You could just lump all the orphaned scripts into one repo too. Basically it needs to show up on the github releases tab or it won't be picked up automatically. (I also think pastebin-like things are bad places to store things that should be permanent)
Old 18th August 2018, 00:37   #70  |  Link
lansing
I got a "HTTP Error 404: Not Found" trying to install hnwvsfunc
Old 18th August 2018, 01:02   #71  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
You should run the update script first (if it works). Since I only keep the latest release, it will fail if you try to get the older release.
Sorry for the inconvenience.
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
Old 18th August 2018, 07:46   #72  |  Link
Myrsloik
Myrsloik's Avatar
It's because wolfberry deletes old releases just to annoy people. Didn't have time to properly fix vsrupdate to handle it yet.
Old 19th August 2018, 17:20   #73  |  Link
Myrsloik
Myrsloik's Avatar
I've updated the packages and fixed vsupdate so it doesn't barf when releases are removed.
Now only people who completely rename files between releases need to die
Old 20th August 2018, 03:55   #74  |  Link
lansing
Does the update file have logic to update itself once vapoursynth got updated to use newer python version like 3.7?
Old 20th August 2018, 06:26   #75  |  Link
Myrsloik
Myrsloik's Avatar
The python version doesn't matter. The only quirk is that you need to install all scripts in the python site packages dir again or move them between the major python updates. No logic needed there.
Old 23rd August 2018, 12:50   #76  |  Link
Yrosma
missing dependecy havsfunc.Deblock_QED after install using vsrepo
I was trying to setup portable edition of vapoursynth and run into a missing dependecy after installing havsfunc using vsrepo.
In my test script I'm using Deblock_QED from havsfunc and got the error it was missing the namespace dctf.
I found it here:
https://github.com/HomeOfVapourSynth...ilter/releases
After adding this one it was working again.
Is there a reason why this one was left out and shouldn't I be using this one?
Or was this one just forgotten?
Yrosma is offline   Reply With Quote
Old 23rd August 2018, 12:54   #77  |  Link
Myrsloik
Myrsloik's Avatar
I found it here:
I think nobody got around to creating a package for it yet. Somebody *hint* *hint* will probably do it soon though since you pointed it out. I actually thought havsfunc had all its dependencies done already.
Old 23rd August 2018, 13:59   #78  |  Link
Myrsloik
Myrsloik's Avatar
And it's added.
Old 6th September 2018, 19:35   #79  |  Link
Myrsloik
Myrsloik's Avatar
I've now updated the packages again. It took a little longer than usual since I had to add a published date to every release as well (in order to always properly preserve the release order when releases are deleted).
Old 6th September 2018, 20:12   #80  |  Link
Myrsloik
Myrsloik's Avatar
I've released RC2. It performs slightly more input validation before starting operations and has a new package definitions.
The unsharpmask and xsharpen functions are also added as WarpSharpSupport (wss) for those of you who want to install it conveniently.
