17th January 2004, 07:29 | #1201 | Link | |
I am more of a DIVX over XVID kinda person purely for compatibility issues, but this post intrigued me.
17th January 2004, 08:56 | #1202 | Link |
Hi-
The panning scenes in cartoons are the biggest problem I have when ripping. What are you asking about? The slight jerkiness during a panning scene of a cartoon or anime? If so, then that's a result of cartoons/anime frequently being drawn at 8 or 12fps. If it's something else, then here's a discussion of what cartoon mode does: http://forum.doom9.org/showthread.ph...t=cartoon+mode |
17th January 2004, 17:10 | #1204 | Link | |
17th January 2004, 17:28 | #1205 | Link |
@len0x
Can you put, like you made for CD, in the comboBox of the output size / Predifined Size options to 1/4, 1/3 and 1/2 DVD (1 dvd = 4700MB)i think many people are buying or thinking to buy dvd burners (i am ) and this will be a cool option ...and simple to implement, i think... Thanks... Last edited by pixolex; 17th January 2004 at 18:37. |
17th January 2004, 17:51 | #1206 | Link | |
Posts: n/a
Sorry for not responding sooner. I tried extracting 1.5b24 into the besweet directory and it still crashes midway through mp3 encoding. This happens with both vbr and cbr encoding. No, the audio file is not 4Gb in size. Yes, the resulting MP3 plays fine, but is too small because besweet crashes midway through. Here's a logfile I just got with 0.86 alpha: [1/17/2004 10:12:12 AM] Input dir: G:\PEARL_HARBOR_DSC1\VIDEO_TS [1/17/2004 10:12:12 AM] Output file: G:\PEARL_HARBOR_DSC1\VIDEO_TS\Pearl_Harbor.avi [1/17/2004 10:12:12 AM] Audio: English [1/17/2004 10:12:12 AM] Subtitles: none [1/17/2004 10:12:12 AM] Codec: DivX [1/17/2004 10:12:12 AM] Target size: 1050Mb [1/17/2004 10:12:12 AM] Custom audio settings: CBR MP3 with bitrate: 128Kbps [1/17/2004 10:12:12 AM] Started encoding. [1/17/2004 10:12:12 AM] Demuxing and indexing. [1/17/2004 10:29:17 AM] Source seems to be pure FILM. [1/17/2004 10:29:17 AM] Found 185387 frames [1/17/2004 10:29:17 AM] Encoding audio. [1/17/2004 10:38:19 AM] Audio size: 4,294,967,295 bytes (4096.00 Mb) [1/17/2004 10:38:19 AM] Overhead: 6,746,368 bytes (6.43 Mb) ************************************* EXCEPTION: Audio and overhead size is more than target video size! ************************************* [1/17/2004 10:38:19 AM] Job finished. Audio log: BeSweet v1.5b24 by DSPguru. -------------------------- Using azid.dll v1.9 (b922) by Midas (midas@egon.gyaloglo.hu). Using lame_enc.dll v1.32 (8/8/2003), Engine 3.90 <http://www.mp3dev.org/>. Logging start : 01/17/04 , 10:29:18. C:\PROGRA~1\AutoGK\BeSweet\BeSweet.exe -core( -input G:\PEARL_HARBOR_DSC1\VIDEO_TS\gk_tmp\PEARL_HARBOR AC3 T01 3_2ch 448Kbps DELAY 0ms.ac3 -output G:\PEARL_HARBOR_DSC1\VIDEO_TS\gk_tmp\PEARL_HARBOR AC3 T01 3_2ch 448Kbps DELAY 0ms.mp3 -logfile G:\PEARL_HARBOR_DSC1\VIDEO_TS\gk_tmp\PEARL_HARBOR AC3 T01 3_2ch 448Kbps DELAY 0ms.log ) -ota( -hybridgain ) -azid( -L -3db -c normal ) -lame( -h --cbr -b 128 ) -profile( AutoGK ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : G:\PEARL_HARBOR_DSC1\VIDEO_TS\gk_tmp\PEARL_HARBOR AC3 T01 3_2ch 448Kbps DELAY 0ms.ac3 [00:00:00:000] | Output: G:\PEARL_HARBOR_DSC1\VIDEO_TS\gk_tmp\PEARL_HARBOR AC3 T01 3_2ch 448Kbps DELAY 0ms.mp3 [00:00:00:000] | Floating-Point Process: Yes [00:00:00:000] | PostGain normalize to : 0.97 [00:00:00:000] +-------- AZID ------- [00:00:00:000] | Input Channels Mode: 3/2, Bitrate: 448kbps [00:00:00:000] | Output Stereo mode: Dolby surround compatible [00:00:00:000] | Total Gain: 10.000dB, Compression: Normal [00:00:00:000] | LFE levels: To LR -3.0dB, To LFE 0.0dB [00:00:00:000] | Center mix level: BSI [00:00:00:000] | Surround mix level: BSI [00:00:00:000] | Dialog normalization: Yes [00:00:00:000] | Rear channels filtering: No [00:00:00:000] | Source Sample-Rate: 48.0KHz [00:00:00:000] +-------- LAME ------- [00:00:00:000] | Bitrate method : CBR [00:00:00:000] | MP3 bitrate : 128 [00:00:00:000] | Channels Mode : Joint Stereo [00:00:00:000] | Error Protection: No [00:00:00:000] +--------------------- |
17th January 2004, 18:38 | #1207 | Link |
noise is all around us...
i got this error-message when using the latest alpha:
[17.01.2004 18:37:33] Input dir: M:\DVD\Rips\ArizonaDream [17.01.2004 18:37:33] Output file: M:\DVD\Rips\ArizonaDream\AD.avi [17.01.2004 18:37:33] Audio: English [17.01.2004 18:37:33] Subtitles: none [17.01.2004 18:37:33] Codec: XviD [17.01.2004 18:37:33] Target size: 1295Mb [17.01.2004 18:37:33] Custom audio settings: AC3 [17.01.2004 18:37:33] Started encoding. [17.01.2004 18:37:33] Demuxing and indexing. [17.01.2004 18:42:15] Analyzing source. ************************************* EXCEPTION: Invalid floating point operation ************************************* [17.01.2004 18:42:17] Job finished. i can't see anything wrong here. usually everything worked fine with previous versions. so no queue for me i will try and downgrade now. hold on.. yrx! - same result with that one. now i can't encode nomore with autogk.
((( atom ))) |
17th January 2004, 23:55 | #1208 | Link |
Divide by zero error
I received:
************************************* EXCEPTION: Divide by zero error ************************************* between the first and second pass using 0.86a with XVid Beta 3 on Win2000. EDIT 1-20-2004: My appologies for not reading the tutorial, which clearly states XVid 1.0 betas are not supported yet. Definately looking forward to this in the future though. Last edited by alfredska; 20th January 2004 at 20:28. |
18th January 2004, 06:14 | #1210 | Link |
alfredska: I've gotten that same error, and I can't get rid of it no matter what material I convert (different sources) or what settings I use (I tried all auto, and a few others).
If anyone else has reached a workaround, I'd love to know it. |
18th January 2004, 12:56 | #1212 | Link | |
I'm afraid we've to stop
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ |
18th January 2004, 13:01 | #1213 | Link | |
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ Last edited by len0x; 18th January 2004 at 13:06. |
18th January 2004, 17:02 | #1214 | Link | |
((( atom ))) |
18th January 2004, 17:45 | #1215 | Link | |
18th January 2004, 21:10 | #1216 | Link |
quality based mode for xvid fixed
I found a problem and you will never believe but it was caused by chroma optimizer option turned on for xvid. Without it I'm having perfect changes of size like r2d6 was experiencing before (thanks to him for mentioning that it was working at some point - that's why I went and looked what was changed in codec settings).
New beta will be out tomorrow.
18th January 2004, 21:41 | #1217 | Link | |
http://forum.doom9.org/showthread.ph...&pagenumber=57 http://forum.doom9.org/showthread.ph...&pagenumber=58 I recommend using your favorite DVD authoring software to first author a DVD from a random mpeg2 file. Then use the VIDEO_TS subdirectory as a universal template and simply paste new mpeg2 files into it and rename as a vob. Sometimes shortcuts named "VTS_01_1.VOB" help. Although, not exactly a guide , you should be able to figure out a good method from my posts. If the default cropping threshold of 35 doesn't work for you, you can change it to something else (60 works for me) and finish the job with GKnot. Or just live with the mis-cropped video...or wait for threshold to be included in an upcoming AutoGK config file feature. |
19th January 2004, 10:56 | #1218 | Link |
subtitles
hi sorry I don't know if someone already asked this question. I'm french, I would like to learn english so I want my XVID movie to be in english with english subtitles in the video, I don't want the subtitles to be in another file, I want the subtitles to be in the video for good so I can play the movie with subtitles anywhere I want (like my DVD player)
I tried to encode with the english subtitles by selecting english in subtitle track, I went in preview and the video was great with subtitles, BUT when I did the job and got the final movie I didn't get the subtitles the video is great with good sound but the subtitles are missing I don't understand why, did I miss something, I noticed Winrar is mentionned, do I really need it (I use powerarchiver) Please Help me I'm lost Thank you so much Otherwise your software is great , thank you so much to help newbies like me Patrica |
19th January 2004, 14:14 | #1219 | Link |
Hi irnbru and welcome to the forum.
Go into the Advanced Settings and see if "Use external subtitles" is checked. If it is checked, uncheck it (still choosing the English Subs in the Main Screen), and then the subs should be embedded or "burned" into the video. That's about the only thing I can think of that might cause what you describe. Maybe len0x has a better idea. And, no, you don't need Winrar unless you want separate (external) subtitles. I think your English is darn near perfect already. I saw only one small thing that told me you weren't a native English speaker. |
19th January 2004, 15:01 | #1220 | Link |
thank for your help :) another question
hey manono thank you for helping me, you can call me Patricia, irnbru is my favorite soft drink made in scotland even better than Coke!
I have two questions : - you told me I made one wee bit mistake in my english, where lol - I realised that I checked in the option "display only forced subtitles", it may be a problem to get the subtitles burned in the movie right? Because forced subtitles are the subtitles you find already in the movie like when they speak in chinese or something, the forced subtitles are not the subtitle stream from the DVD right. If I just select the english subtitles stream in the tracks, and I leave both options "display forced subtitles" "external subtitles" unchecked , it should work right? thanks for helping me I hope your co worker in the project will help me too Kisses Patricia |
