8th January 2018, 20:53 | #48121 | Link |
With NVidia, FSE needs to be enabled for 3D.
When I used custom resolutions in the past, the timing was perfect but I noticed everything was playing in 8bit. I deleted the custom resolution and playback was once again 10bit. Might have been some bad coincidence on my end or indeed custom resolutions affect bit depth. Comments? Rick, sometimes HDR does not engage properly without starting and stopping the title a couple times. Have you tried this? Also I don't think BT.2020>DCI-P3 is telling us anything is getting converted. I think it is telling us what display calibration it was mastered on and/or the content is limited to DCI-P3.
HOW TO-Kodi 2D-3D-UHD (4k) HDR Guide Internal & External Players W11 Pro 23H2 GTX960-4GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit KODI 21 MPC-HC/BE 82" Q90R Denon S720W Last edited by brazen1; 8th January 2018 at 21:40. Reason: addition |
8th January 2018, 21:46 | #48122 | Link |
we've discussed this many times Brazen1, only AMD cards required FSE for MVC 3D, look back further in the posts, the problem is 3D keeps getting turned off and disabled, a bath file has been created to run before you start your movie which works 100% of the time apparently.
I havent had chance to test it myself yet on my spare 1050, my RX 550 is working ok at the moment and i'm just getting around to watching some stuff i've been putting off for a while. here is the batch file details again to save you reading back. REM Change a registry key and values with Regedit.exe REM and a temporary .reg file. Self contained script. REM REM For magic keyboard numbers go here: REM http://3dvision-blog.com/3053-modify...s-as-you-need/ REM Necessary header for importing .reg file. > "%temp%\Update3DSettings.reg" ECHO Windows Registry Editor Version 5.00 >> "%temp%\Update3DSettings.reg" ECHO. REM Decide which CPU architecture- to set the proper registry keys for x86 and x64. REM Using GOTO instead of IF THEN ELSE because of better compatibility. REM Assume x86 as the architecture. SET "KEY=[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\Global\Stereo3D]" REM Reset the key if that's not right. IF "%PROCESSOR_ARCHITECTURE%"=="x86" GOTO EchoKey SET "KEY=[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\NVIDIA Corporation\Global\Stereo3D]" :EchoKey >> "%temp%\Update3DSettings.reg" ECHO %KEY% REM Now the series of registry dwords for that \Stereo3D key. REM Let's auto-enable 3D, without going through the test. REM Bypass the Medical Test >> "%temp%\Update3DSettings.reg" ECHO "StereoVisionConfirmed"=dword:00000001 REM Reset from Discover >> "%temp%\Update3DSettings.reg" ECHO "StereoViewerType"=dword:00000001 REM Now let's import registry file REM /s is used to avoid an "Are you sure" prompt regedit.exe /s "%temp%\Update3DSettings.reg" REM -- No registry key for Enable stereoscopic 3D checkbox, so we'll directly REM call the activation tool. Change path if this is not correct. REM We call for both 32 bit and 64 bit. If one fails it's not a problem. CALL "C:\Program Files\NVIDIA Corporation\3D Vision\nvstlink.exe" /enable CALL "C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvstlink.exe" /enable |
8th January 2018, 22:18 | #48123 | Link |
@mclingo: I'm looking for a cheap gfx card for my older machine that can do all the 4K, HDR, mostly MPC-HC/MadVR and YT VP9 profile 2 stuff...how is rx 550 in this regard?
8th January 2018, 23:00 | #48124 | Link | |
I'm on win7. |
8th January 2018, 23:52 | #48125 | Link | |
sorry i cant speak for vp9 buts everything else is fine, however if you just want a no frills 4k card which supports 4k/HDR/HEVC the Nvidia 1030 is the cheapest on the market right now unless you go for a used RX 460. |
9th January 2018, 00:02 | #48126 | Link | |
for VP9 profile 2 you need a 1050 ti |
9th January 2018, 00:27 | #48127 | Link |
I dont watch much on youtube really so I hadnt noticed it wasnt working, a quick view of the AMD threads confirm no VP9 in polaris, or at least there doesnt seems to be, there are workarounds which were broken by creators and AMD drivers, not sure what the current situation is.
looks like NVIDIA is the best bet. |
9th January 2018, 00:37 | #48128 | Link | |
P.S. just found this screenshot posted way earlier on this forum: http://jpegshare.net/d2/3a/d23a630cf...5056c.jpg.html seem like profile 2 is covered as well...seems like quite a little beast Last edited by mytbyte; 9th January 2018 at 00:46. |
9th January 2018, 00:42 | #48129 | Link |
1030-1050 ti and the 1080 TI have profile 2 but you are not going to have fun with a 2GB card if you want to output UHD.
polaris has a 8 bit hybrid decoder which stresses the GPU notable and AFAIK it only works in chrome. hybrid decoder are generally not worth the time. |
9th January 2018, 01:05 | #48130 | Link | |
I apologize for spamming the thread...thanks |
9th January 2018, 01:14 | #48131 | Link |
VP9 profile 2 is HDR not SDR on YT (they may change that in the future and please correct if the did already)
so your GPU needs to be able to run the HDR-> SDR conversation in madVR which takes quite some processing power. i have no clue if a 1030 or 1050 can do that. 2GB should be totally fine for 1080p output. because you may care about downscaling. so you may like to know that bicubic 150 is terrible in my eyes for downscaling and SSIM is the only god tier downscaler in madVR. the problem of bicubic 150 is not a single frame it can be seen in motion where it >can< look like NN. |
9th January 2018, 01:40 | #48132 | Link |
question - up scaling 1080p to 4k on my RX 550, which makes the most PQ difference, chroma up scaling or image up scaling, is it best to put all your gpu eggs into the up scaling basket, chroma , or a balance of the two. I am currently using NGU sharp medium for upscale and lanczos for chroma upscale.
thoughts anyone? |
9th January 2018, 01:58 | #48133 | Link | ||
Currently for 24P I let it use the edid info like so: Which is different than what madVR is finally reporting so not sure what would cause that but can't get any closer than that. It's a Sony XE9305 but will try a power cycle, also tried the same files on my Apple TV 4K using the Infuse app there and springs to HDR right away so know the files have the needed metadata at least. Quote:
Will just wait a bit as it seems HDR and Windows is just buggy, seen this in games as well where AC: Origins works perfectly in HDR but Andromeda just fails. Last edited by Rick164; 9th January 2018 at 02:05. |
9th January 2018, 02:12 | #48134 | Link |
Don't get the 1030, it's too slow. My 960 handles hdr only just.. 60fps is no go.. Plus no extra image processing and lower end chroma options.. If you're taking 4K/HDR seriously it's 1060+ otherwise 1050ti minimum imo. 950/960/1050 great for 480-1080p on the cheap.
9th January 2018, 02:48 | #48137 | Link | |
Hello my friend, and thanks alot for helping me. Ill try to explain the best i can. I want to watch 4K videos/movies, and make the look the best possible with GTX750 ti/1050 ti/GTX960/GT1030. The monitor is 1080p, and the clips are in 4K in the format i posted previously. I need to know, if i "max out" the madVR settings, will any of this card be able to play the 4K clips which i provided the format/codecs/info for without issues? for example you select all the best looking - processing/renderer settings in madVR panel, and get the best image quality out of the videos? i understand this is called downscaling? also for future X265 formats, for the same kind of usage, when the S9 will be released. I got this option now for (USED) and some new cards, GTX750 ti 4GB - 80$, GTX960 4GB - 140$, GTX 1050 2GB (new) 2GB - 160$, GT1030 2GB (new) 90$ I will be also connecting them with mu U2414h, would some of the madVR modes require, a special HDMI/DP standards? and as a final note, would 960 or 1050 offer anything at all more compared to the 750 ti 4gb, and will it worth to pay double for them? would the 2gb be bottleneck for youtube 4k/8k60? on the 1050 or for madVR? thanks. P.S. I'm not from USA, where i live, those are the prices i can get for new/used cards. Last edited by psyside; 9th January 2018 at 02:54. |
9th January 2018, 02:57 | #48138 | Link | |
HOW TO-Kodi 2D-3D-UHD (4k) HDR Guide Internal & External Players W11 Pro 23H2 GTX960-4GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit KODI 21 MPC-HC/BE 82" Q90R Denon S720W |
9th January 2018, 03:05 | #48139 | Link | |
9th January 2018, 03:31 | #48140 | Link | |
