20th October 2009, 22:56 | #5981 | Link |
Hey. My CPU is a 3.33ghz dual (intel). It worked before, but right now it does the job, it happen like 2-4 time that is say complet after 3 min. But right now its working. If i have more trouble, i'll right more detail. tks
21st October 2009, 00:19 | #5982 | Link |
First of all, great app.
But I have a problem. It goes through all the normal stuff, and then it freezes at Muxing. If i try to combine the .264 file and the audio file in the temp directory with tsMuxer, it doesn't work either. Specs: Win 7 x64 Pro RTM 9800GTX+ Tried with 3 different files, all going to BD-25, and they all get the same error. |
21st October 2009, 06:18 | #5983 | Link |
Output splitting
Would it be possible to enable creation of multiple videos from one source buy inputting start and end timecodes, posssibly from the chapters file.
For example I'd like to backup a series I have on BluRay but eac3to indexes the 4 episodes on a disc to 1 input video and audio track, now I can spit the resultant Mp4 after it's creation with Yamb but it would be much neater and quicker to do at the creation stage. Great tool BTW, nothing else comes close...
Q6600 @ 3.2Ghz -Asus P5Q-Pro 4Gb DD2, GTX260 core 216 Win 7 64bit Home Premium |
21st October 2009, 12:23 | #5984 | Link |
HD-Fan
Not that I don't like your default settings, I just wanted to test my preferred settings that I am using all the time and see which one is better between the two. Lol But I am looking forward to a feature that'll let me do just that thuogh
21st October 2009, 12:52 | #5985 | Link | ||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 21st October 2009 at 12:55. |
21st October 2009, 22:45 | #5986 | Link |
Hi Atak,
Ripbot264 1.14.5 on Windows Vista x64 ultimate; ffdshow clsid 3109, avisynth 2.5.8; program are freeze at "Muxing..." from this morning to now and the movie are done and are complete. Job1.avs Code:
#MT #VideoSource video=DirectShowSource("D:\--= Complete =--\movieBD.mkv",audio=false).ConvertToYV12() #Deinterlace #Decimate #Crop #Resize video=Spline36Resize(video,1280,544).Sharpen(0.2).AddBorders(0,88,0,88) #Colors #Denoise #Subtitles #AudioSource LoadPlugin("Z:\--= Softwares =--\Ripbot264 1.14.5\tools\AviSynth plugins\NicAudio\NicAudio.dll") audio=NicDTSSource("E:\Temp\RipBot264temp\job1\audio.1.dts") audio=ResampleAudio(audio,48000) #DownMix Import("Z:\--= Softwares =--\Ripbot264 1.14.5\Tools\AviSynth plugins\Scripts\DownMixAudio.avs") audio=DownMix2Stereo(audio) #Delay audio=DelayAudio(audio,0) #Tempo video=AssumeFPS(video,"ntsc_film") audio=TimeStretch(audio,tempo=(24/1.001)/(24/1.001)*100) #Normalize #AudioDub audio=ConvertAudioTo16bit(audio) AudioDub(video,audio) #Triming #AVSameLength Trim(0,212985) #ColorSpace Code:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --avchd --vbr --auto-chapters=5 --vbv-len=500 V_MPEG4/ISO/AVC, "E:\Temp\RipBot264temp\video.264", fps=23.976, insertSEI, contSPS A_DTS, "E:\Temp\RipBot264temp\job1\audio.1.dts", timeshift=0, lang=fra
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 21st October 2009 at 22:50. |
21st October 2009, 22:56 | #5987 | Link |
What happens if you execute manually job1_MuxFiles.cmd?
22nd October 2009, 00:33 | #5988 | Link |
unfortunatly i've erased files because i need to try another one movie to be converted. If other movie make the same, i will test it the command and let you know. Or if you really need to know the result, i can convert it again.
EDIT: i've put the same movie conversion in queue2. The conversion of this morning has only one queue. So after the other movie conversion, i will check if error happen again and test that. Thanks!
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 22nd October 2009 at 00:43. |
22nd October 2009, 05:31 | #5989 | Link |
I really dont understand what happen!
I've got an x264_x64.exe crash and the end of the second pass. after click "OK" at the crash application, muxing was done completly. Audio and video was sync (one good news). The second movie in conversion was the one from this morning. I will know tomorrow morning is muxing will be freeze again. For the x264_x64.exe, did you think i need to bypass the 64bit coding will resolve my trouble? I really dont care about the difference in conversion with my new quad cores amd phenom II, performance are still awesome. I will wait for recommandations before making or apply any changes. thanks ataK!
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 22nd October 2009 at 05:46. |
22nd October 2009, 16:18 | #5990 | Link | |
Imagine you have a small box that's 1280x720 in size. Then you add marbles into the bottom of that box until it's full. The entire bottom is filled with marbles side by side. The marbles now symbolize your bitrate. If you now create a new box measuring 1920x1080 and move the same marbles from the first box into the second box they would not cover the bottom, right? So, what does this tell us? Well, bitrate decides the size of your end file but higher resolutions need higher bitrate (more marbles) to cover the bottom. So, for your 1280x720 box you need less marbles than you do for your 1920x1080 box meaning you need lower bitrate for the lower resolution = smaller filesize. The discussion about what bitrate you would need for different resolutions I won't even try to get into since folks have very different opinions about that but at least this could help some people understand bitrate vs resolution better. |
22nd October 2009, 19:23 | #5991 | Link |
I've been using RB for a long time now, and it's a great program, and also the developer continues to fix and enhance.
I'd like to request two enhancements for consideration 1. When working with Custom Resize, would it be possible to either allow manual input of the values, or allow for steps of 2 instead of 4 ? My rationale for asking is that with a lot of DVB-S/T stuff, you have to crop quite a lot to get rid of dead areas (and also some OSG), and in doing so, when you want to resize back to say 1.85:1 with 640x346, you can only get to 640x348 or x344. I can mitigate this by setting it close, then editing the AVS, and the encoding CMD files (if 2-pass obviously). But it would be nicer to not have to (and I understand that multiples of 2 is not ideal, but when working with MKV, you don't really need to worry about this multiples of 8 or 16 any more). 2. Is there anyway to provide a default additional set of lines to be added to the jobx.avs file ? Rationale here is to add fade support. I always add this for TV encodes, or when creating multiples that I'll eventually mux together into one. If not, perhaps an option in the GUI to specify the number of seconds to fade to black at start/end, and then use the FPS of the source to put this in automatically Of course both of these things I can and do get around manually, but they're quite useful additions with over-complicating the product (which I really like for it's ease of use). Any chance of the above ? |
22nd October 2009, 20:03 | #5992 | Link |
First and foremost - thanks to Atak for advancing an making Ripbot a valuable tool. My question is that I am stuck; I cant get it to work. I have installed all current versions (and played with older versions) of RB, ffdshow, avisynth, etc. I have a clean install of WM11. All goes well until MPC (getinfo.avs) opens and then the screen stays black and and the status bar appears to have a seizure.
I am trying to rip and encode my own Blu-Ray library (of my own DVDs) for streaming throughout the house. I use AnyDVD to rip the file to the HDD and then RB to try and complete the rest. I am new to blu-ray encoding, but have been successful with standard DVD conversion to MP4. System info Win XP Quad-core - Q8200 GeForce 9500 GT Any help would be most appreciated. |
22nd October 2009, 20:14 | #5993 | Link | |
22nd October 2009, 20:56 | #5994 | Link |
Been using this to rip my Blurays...
Problem is, why are you using "down16" command in eac3to on 24bit lossless audio tracks!!!!? What on earth is the point in that, it makes using FLAC a complete wastre of time surely? I'm using AAC-LC 5.1 320kbps personally, was also a little curious on why there aren't higher bitrate profiles for AAC-LC 5.1 would be useful when you have a lossless TrueHD\DTSMA track to begin with. Excuse my ignorance, I'm sure there are very good reasons like the encoders might not accept 24bit audio etc? Thanks for the work |
22nd October 2009, 22:25 | #5995 | Link |
Hi Atak;
Update: after trying two conversion (different movies), x264_x64.exe was crashed again (ripbot are freeze at 1 Pass 00:00:00) after 1pass done, click OK of the crashed application, ripbot264 muxing the project in queue (the one crashed). It bring me an idea; did it could be the fast first pass make the application crash? What you recommand me. Thanks. Hope thoes informations will help you.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
22nd October 2009, 22:54 | #5997 | Link | ||
@8ternity try with x264_x86.exe (edit ripbot264.ini)
22nd October 2009, 23:10 | #5998 | Link |
I found the mpc.ini file and pasted here. Is this what you are looking for? 1 of 2
[Settings] LastUsedPage=0 HideCaptionMenu=0 ControlState=19 DefaultVideoFrame=4 KeepAspectRatio=1 CompMonDeskARDiff=0 Volume=52 Balance=0 Mute=0 LoopNum=1 Loop=1 Rewind=1 Zoom=1 AllowMultipleInstances=0 TitleBarTextStyle=1 OnTop=0 TrayIcon=0 AutoZoom=1 FullScreenCtrls=1 FullScreenCtrlsTimeOut=0 FullscreenRes=AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA ExitFullscreenAtTheEnd=0 RememberWindowPos=0 RememberWindowSize=0 SnapToDesktopEdges=1 LastWindowRect=AAAAAAAAMICAAAAABHDAAAAACAEAAAAA LastWindowType=0 AspectRatioX=0 AspectRatioY=0 KeepHistory=1 DSVidRen=0 RMVidRen=0 QTVidRen=0 APSurfaceUsage=0 VMRSyncFix=0 DX9Resizer=1 VMR9MixerMode=0 AudioRendererType= AutoloadAudio=0 AutoloadSubtitles=0 EnableWorkerThreadForOpening=1 ReportFailedPins=1 DVDPath= UseDVDPath=0 MenuLang=1033 AudioLang=1033 SubtitlesLang=1033 AutoSpeakerConf=1 SPDefaultStyle=20,20,20,20,2,0,2.000000,3.000000,0xffffff,0x00ffff,0x000000,0x000000,0x00,0x00,0x00,0x80,1,Arial,18.000000,100.000000,100.000000,0.000000,700,0,0,0,0,0.000000,0.000000,0.000000,2 SPOverridePlacement=0 SPHorPos=50 SPVerPos=90 SPCSize=3 SPCMaxRes=2 SPCPow2Tex=1 EnableSubtitles=1 EnableAudioSwitcher=0 EnableAudioTimeShift=0 AudioTimeShift=0 DownSampleTo441=0 CustomChannelMapping=0 SpeakerToChannelMapping=BAAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAACAAAAAAAAAAAAAAAAAAAAAAAEAAAAAAAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAAAAAAAAAIAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJAAAAAAAKAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAAAAAAAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAAAAAAEAAAAAAAIAAAAAAAABAAAAAAACAAA AudioNormalize=0 AudioNormalizeRecover=1 AudioBoost=1 IntRealMedia=0 RealMediaFPS=1103626240 UseWinLirc=0 WinLircAddr=127.0.0.1:8765 UseUICE=0 UICEAddr=127.0.0.1:1234 DisableXPToolbars=0 UseWMASFReader=1 JumpDistS=1000 JumpDistM=5000 JumpDistL=20000 FreeWindowResizing=1 NotifyMSN2=0 NotifyGTSdll=0 LogoFile= LogoID2=206 LogoExt=0 HideCDROMsSubMenu=0 Priority=32768 LaunchFullScreen=0 EnableWebServer=0 WebServerPort=13579 WebServerPrintDebugIfo=0 WebServerUseCompression=1 WebServerLocalhostOnly=1 WebRoot=*./webroot WebDefIndex=index.html;index.php WebServerCGI= SnapShotPath=C:\Users\Dawid\Desktop SnapShotExt=.bmp ThumbRows=4 ThumbCols=4 ThumbWidth=1024 ISDb=isdb.go.dyndns.org fps=30.000 gotoluf=1 [Internal Filters] SrcFilters=-2097152 TraFilters=-2048 [ToolBars\Subresync] Visible=0 DockState=59419 [ToolBars\Subresync\State-SCBar-0] sizeHorzCX=200 sizeHorzCY=200 sizeVertCX=200 sizeVertCY=200 sizeFloatCX=200 sizeFloatCY=200 [ToolBars\Playlist] Visible=0 DockState=59422 [ToolBars\Playlist\State-SCBar-0] sizeHorzCX=200 sizeHorzCY=100 sizeVertCX=200 sizeVertCY=100 sizeFloatCX=200 sizeFloatCY=100 [ToolBars\Capture Settings] Visible=0 DockState=59420 [ToolBars\Capture Settings\State-SCBar-0] sizeHorzCX=191 sizeHorzCY=470 sizeVertCX=191 sizeVertCY=470 sizeFloatCX=191 sizeFloatCY=470 [ToolBars\Shader Editor] Visible=0 DockState=59419 [ToolBars\Shader Editor\State-SCBar-0] sizeHorzCX=1428 sizeHorzCY=115 sizeVertCX=297 sizeVertCY=115 sizeFloatCX=297 sizeFloatCY=115 [Capture] VidOutput=1 AudOutput=1 VidPreview=1 AudPreview=1 FileFormat=0 FileName=.avi SepAudio=1 [Recent Dub List] Dub1=c:\RipBot264temp\job1\job1 MPA PID 814 DELAY -221ms.mpa Dub2=c:\RipBot264temp\job1\job1 MPA PID 814 DELAY -242ms.mpa Dub3=c:\RipBot264temp\job2\job2 MPA PID 814 DELAY -221ms.mpa Dub4=c:\RipBot264temp\job1\job1 T01 DELAY 0ms.mpa Dub5=c:\RipBot264temp\job1\job1 PID 025 T01 3_2ch 448Kbps DELAY 0ms.ac3 Dub6=c:\RipBot264temp\job1\job1 MPA PID 814 DELAY 0ms.mpa Dub7=c:\RipBot264temp\job1\job1 T01 48K 16bit 2ch.wav Dub8=c:\RipBot264temp\job1\job1 PID 032 T01 2_0ch 384Kbps DELAY -6ms.ac3 Dub9=c:\RipBot264temp\job1\job1 MPA PID 814 DELAY -217ms.mpa Dub10=c:\RipBot264temp\job1\job1 MPA PID 814 DELAY -231ms.mpa Dub11=c:\RipBot264temp\job1\job1 MPA PID 814 DELAY -224ms.mpa Dub12=c:\RipBot264temp\job1\job1 MPA PID 814 DELAY -240ms.mpa Dub13=c:\RipBot264temp\job1\job1 MPA PID 814 DELAY -188ms.mpa Dub14=c:\RipBot264temp\job2\job2 MPA PID 814 DELAY -242ms.mpa Dub15=c:\RipBot264temp\job1\job1 T01 3_2ch 448Kbps DELAY -168ms.ac3 Dub16=c:\RipBot264temp\job1\job1 T01 3_2ch 448Kbps DELAY 0ms.ac3 Dub17=c:\RipBot264temp\job2\job2 MPA PID 814 DELAY -224ms.mpa Dub18=c:\RipBot264temp\job1\job1 MPA PID 814 DELAY -229ms.mpa Dub19=c:\RipBot264temp\job3\job3 MPA PID 814 DELAY -221ms.mpa Dub20=c:\RipBot264temp\job1\job1 T01 2_0ch 192Kbps DELAY 583032ms.ac3 |
22nd October 2009, 23:11 | #5999 | Link |
2 of 2
[Recent File List] File1=L:\temp\RipBot264temp\job1\getinfo.avs File2=E:\temp\RipBot264temp\job2\job2_preview.avs File3=E:\temp\RipBot264temp\job1\job1_preview.avs File4=E:\temp\RipBot264temp\job3\job3_preview.avs File5=E:\temp\RipBot264temp\job7\job7_preview.avs File6=E:\temp\RipBot264temp\job6\job6_preview.avs File7=E:\temp\RipBot264temp\job5\job5_preview.avs File8=E:\temp\RipBot264temp\job4\job4_preview.avs File9=E:\temp\RipBot264temp\job1\getinfo.avs File10=C:\temp\RipBot264temp\job5\job5_preview.avs File11=C:\temp\RipBot264temp\job4\job4_preview.avs File12=C:\temp\RipBot264temp\job3\job3_preview.avs File13=C:\temp\RipBot264temp\job2\job2_preview.avs File14=C:\temp\RipBot264temp\job1\job1_preview.avs File15=C:\temp\RipBot264temp\job7\job7_preview.avs File16=C:\temp\RipBot264temp\job6\job6_preview.avs File17=C:\temp\RipBot264temp\job1\getinfo.avs File18=D:\temp\RipBot264temp\job4\job4_preview.avs File19=D:\temp\RipBot264temp\job3\job3_preview.avs File20=D:\temp\RipBot264temp\job2\job2_preview.avs [Settings\PnSPresets] Preset0=Scale to 16:9 TV,0.500,0.500,1.000,1.333 Preset1=Zoom To Widescreen,0.500,0.500,1.333,1.333 Preset2=Zoom To Ultra-Widescreen,0.500,0.500,1.763,1.763 [FileFormats] RtspHandler=1 RtspFileExtFirst=1 Windows Media file=wmv wmp wm asf \0 Windows Media Audio file=wma \0 Video file=avi \0 Audio file=wav \0 MPEG Media file=mpg mpeg mpe m1v m2v mpv2 mp2v dat ts tp tpr pva pss \0 MPEG Audio file=mpa mp2 m1a m2a \0 DVD file=vob ifo \0 DVD Audio file=ac3 dts \0 MP3 Format Sound=mp3 \0 MIDI file=mid midi rmi \0 Indeo Video file=ivf \0 AIFF Format Sound=aif aifc aiff \0 AU Format Sound=au snd \0 Ogg Media file=ogm \0 Ogg Vorbis Audio file=ogg \0 CD Audio Track=cda \0 FLIC file=fli flc flic \0 DVD2AVI Project file=d2v \0 MPEG4 file=mp4 m4v m4p m4b 3gp 3gpp 3g2 3gp2 \0 MPEG4 Audio file=m4a aac \0 Matroska Media file=mkv \0 Matroska Audio file=mka \0 Smacker/Bink Media file=smk bik \0 ratdvd file=ratdvd \0 RoQ Media file=roq \0 Real Media file=rm ram rmvb rpm \0 Real Audio file=ra \0 Real Script file=rt rp smi smil \1 Dirac Video file=drc \0 DirectShow Media file=dsm dsv dsa dss \0 Musepack file=mpc \0 Flash Video file=flv \0 Shockwave Flash file=swf \3 Quicktime file=mov qt amr \2 Image file=jpeg jpg bmp gif pic png dib tiff tif \0 Playlist file=asx m3u pls wvx wax wmx mpcpl \0 Other=divx vp6 \0 [Shaders] Initialized=1 Combine= 0=emboss|ps_2_0|sampler s0 : register(s0);\nfloat4 p0 : register(c0);\nfloat4 p1 : register(c1);\n\n#define width (p0[0])\n#define height (p0[1])\n#define counter (p0[2])\n#define clock (p0[3])\n#define one_over_width (p1[0])\n#define one_over_height (p1[1])\n\n#define PI acos(-1)\n\nfloat4 main(float2 tex : TEXCOORD0) : COLOR\n{\n\tfloat dx = 1/width;\n\tfloat dy = 1/height;\n\t\n\tfloat4 c1 = tex2D(s0, tex + float2(-dx,-dy));\n\tfloat4 c2 = tex2D(s0, tex + float2(0,-dy));\n\tfloat4 c4 = tex2D(s0, tex + float2(-dx,0));\n\tfloat4 c6 = tex2D(s0, tex + float2(dx,0));\n\tfloat4 c8 = tex2D(s0, tex + float2(0,dy));\n\tfloat4 c9 = tex2D(s0, tex + float2(dx,dy));\n\t\n\tfloat4 c0 = (-c1-c2-c4+c6+c8+c9);\n\tc0 = (c0.r+c0.g+c0.b)/3 + 0.5;\n\t\n\treturn c0;\n}\n 1=spotlight|ps_2_0|sampler s0 : register(s0);\nfloat4 p0 : register(c0);\nfloat4 p1 : register(c1);\n\n#define width (p0[0])\n#define height (p0[1])\n#define counter (p0[2])\n#define clock (p0[3])\n#define one_over_width (p1[0])\n#define one_over_height (p1[1])\n\n#define PI acos(-1)\n\nfloat4 main(float2 tex : TEXCOORD0) : COLOR\n{\n\tfloat4 c0 = tex2D(s0, tex);\n\tfloat3 lightsrc = float3(sin(clock*PI/1.5)/2+0.5,cos(clock*PI)/2+0.5,1);\n\tfloat3 light = normalize(lightsrc - float3(tex.x,tex.y,0));\n\tc0 *= pow(dot(light, float3(0,0,1)), 50);\n\t\n\treturn c0;\n}\n 2=deinterlace (blend)|ps_2_0|sampler s0 : register(s0);\nfloat4 p0 : register(c0);\nfloat4 p1 : register(c1);\n\n#define width (p0[0])\n#define height (p0[1])\n#define counter (p0[2])\n#define clock (p0[3])\n#define one_over_width (p1[0])\n#define one_over_height (p1[1])\n\n#define PI acos(-1)\n\nfloat4 main(float2 tex : TEXCOORD0) : COLOR\n{\n\tfloat4 c0 = tex2D(s0, tex);\n\t\n\tfloat2 h = float2(0, 1/height);\n\tfloat4 c1 = tex2D(s0, tex-h);\n\tfloat4 c2 = tex2D(s0, tex+h);\n\tc0 = (c0*2+c1+c2)/4;\n\t\n\treturn c0;\n} 3=invert|ps_2_0|sampler s0 : register(s0);\nfloat4 p0 : register(c0);\nfloat4 p1 : register(c1);\n\n#define width (p0[0])\n#define height (p0[1])\n#define counter (p0[2])\n#define clock (p0[3])\n#define one_over_width (p1[0])\n#define one_over_height (p1[1])\n\n#define PI acos(-1)\n\nfloat4 main(float2 tex : TEXCOORD0) : COLOR\n{\n\tfloat4 c0 = float4(1, 1, 1, 1) - tex2D(s0, tex);\n\t\n\treturn c0;\n}\n 4=procamp|ps_2_0|sampler s0 : register(s0);\nfloat4 p0 : register(c0);\nfloat4 p1 : register(c1);\n\n#define width (p0[0])\n#define height (p0[1])\n#define counter (p0[2])\n#define clock (p0[3])\n#define one_over_width (p1[0])\n#define one_over_height (p1[1])\n\n#define PI acos(-1)\n\nstatic float4x4 r2y =\n{\n\t0.299, 0.587, 0.114, 0,\n\t-0.147, -0.289, 0.437, 0,\n\t0.615, -0.515, -0.100, 0,\n\t0, 0, 0, 0\n};\n\nstatic float4x4 y2r =\n{\n\t1.0, 0.0, 1.140, 0, \n\t1.0, -0.394, -0.581, 0,\n\t1.0, 2.028, 0.0, 0, \n\t0, 0, 0, 0\n};\n\n#define ymin (16.0/255)\n#define ymax (235.0/255)\n\n// Brightness: -1.0 to 1.0, default 0.0\n// Contrast: 0.0 to 10.0, default 1.0\n// Hue: -180.0 to +180.0, default 0.0\n// Saturation: 0.0 to 10.0, default 1.0\n\n#define Brightness 0.0\n#define Contrast 1.0\n#define Hue 0.0\n#define Saturation 1.0\n\n// tv -> pc scale\n// #define Brightness (-ymin)\n// #define Contrast (1.0/(ymax-ymin))\n\nstatic float2x2 HueMatrix =\n{\n\tcos(Hue * PI / 180), sin(Hue * PI / 180),\n\t-sin(Hue * PI / 180), cos(Hue * PI / 180)\n};\n\nfloat4 main(float2 tex : TEXCOORD0) : COLOR\n{\n\tfloat4 c0 = tex2D(s0, tex);\n\tc0 = mul(r2y, c0);\n\tc0.r = Contrast * (c0.r - ymin) + ymin + Brightness;\n\tc0.gb = mul(HueMatrix, c0.gb) * Saturation;\n\tc0 = mul(y2r, c0);\n\treturn c0; \n}\n 5=contour|ps_2_0|sampler s0 : register(s0);\nfloat4 p0 : register(c0);\nfloat4 p1 : register(c1);\n\n#define width (p0[0])\n#define height (p0[1])\n#define counter (p0[2])\n#define clock (p0[3])\n#define one_over_width (p1[0])\n#define one_over_height (p1[1])\n\n#define PI acos(-1)\n\nfloat4 main(float2 tex : TEXCOORD0) : COLOR\n{\n\tfloat dx = 4/width;\n\tfloat dy = 4/height;\n\t\n\tfloat4 c2 = tex2D(s0, tex + float2(0,-dy));\n\tfloat4 c4 = tex2D(s0, tex + float2(-dx,0));\n\tfloat4 c5 = tex2D(s0, tex + float2(0,0));\n\tfloat4 c6 = tex2D(s0, tex + float2(dx,0));\n\tfloat4 c8 = tex2D(s0, tex + float2(0,dy));\n\t\n\tfloat4 c0 = (-c2-c4+c5*4-c6-c8);\n\tif(length(c0) < 1.0) c0 = float4(0,0,0,0);\n\telse c0 = float4(1,1,1,0);\n\t\n\treturn c0;\n}\n 6=letterbox|ps_2_0|sampler s0 : register(s0);\nfloat4 p0 : register(c0);\nfloat4 p1 : register(c1);\n\n#define width (p0[0])\n#define height (p0[1])\n#define counter (p0[2])\n#define clock (p0[3])\n#define one_over_width (p1[0])\n#define one_over_height (p1[1])\n\n#define PI acos(-1)\n\nfloat4 main(float2 tex : TEXCOORD0) : COLOR\n{\n\tfloat4 c0 = 0;\n\t\n\tfloat2 ar = float2(16, 9);\n\tfloat h = (1 - width/height * ar.y/ar.x) / 2;\n\t\n\tif(tex.y >= h && tex.y <= 1-h)\n\t\tc0 = tex2D(s0, tex);\n\t\n\treturn c0;\n} 7=wave|ps_2_0|sampler s0 : register(s0);\nfloat4 p0 : register(c0);\nfloat4 p1 : register(c1);\n\n#define width (p0[0])\n#define height (p0[1])\n#define counter (p0[2])\n#define clock (p0[3])\n#define one_over_width (p1[0])\n#define one_over_height (p1[1])\n\n#define PI acos(-1)\n\nfloat4 main(float2 tex : TEXCOORD0) : COLOR\n{\n\t// don't look at this for too long, you'll get dizzy \n\t\n\tfloat4 c0 = 0;\n\t\n\ttex.x += sin(tex.x+clock/0.3)/20;\n\ttex.y += sin(tex.x+clock/0.3)/20;\n\t\n\tif(tex.x >= 0 && tex.x <= 1 && tex.y >= 0 && tex.y <= 1)\n\t{\n\t\tc0 = tex2D(s0, tex);\n\t}\n\t\n\treturn c0;\n}\n 8=sharpen|ps_2_0|sampler s0 : register(s0); \nfloat4 p0 : register(c0); \nfloat4 p1 : register(c1); \n \n#define effect_width (1.6) \n#define val0 (2.0) \n#define val1 (-0.125) \n\n#define width (p0[0]) \n#define height (p0[1]) \n \nfloat4 main(float2 tex : TEXCOORD0) : COLOR \n{ \n\tfloat dx = effect_width/width; \n\tfloat dy = effect_width/height; \n \n\tfloat4 c1 = tex2D(s0, tex + float2(-dx,-dy)) * val1; \n\tfloat4 c2 = tex2D(s0, tex + float2(0,-dy)) * val1; \n\tfloat4 c3 = tex2D(s0, tex + float2(-dx,0)) * val1; \n\tfloat4 c4 = tex2D(s0, tex + float2(dx,0)) * val1; \n\tfloat4 c5 = tex2D(s0, tex + float2(0,dy)) * val1; \n\tfloat4 c6 = tex2D(s0, tex + float2(dx,dy)) * val1; \n\tfloat4 c7 = tex2D(s0, tex + float2(-dx,+dy)) * val1; \n\tfloat4 c8 = tex2D(s0, tex + float2(+dx,-dy)) * val1; \n\tfloat4 c9 = tex2D(s0, tex) * val0; \n\t\n\tfloat4 c0 = (c1 + c2 + c3 + c4 + c5 + c6 + c7 + c8 +c9); \n\t\n\treturn c0; \n} 9=sphere|ps_2_0|sampler s0 : register(s0);\nfloat4 p0 : register(c0);\nfloat4 p1 : register(c1);\n\n#define width (p0[0])\n#define height (p0[1])\n#define counter (p0[2])\n#define clock (p0[3])\n#define one_over_width (p1[0])\n#define one_over_height (p1[1])\n\n#define PI acos(-1)\n\nfloat4 main(float2 tex : TEXCOORD0) : COLOR\n{\n\t// - this is a very simple raytracer, one sphere only\n\t// - no reflection or refraction, yet (my ati 9800 has a 64 + 32 instruction limit...)\n\t\n\tfloat3 pl = float3(3,-3,-4); // light pos\n\tfloat4 cl = 0.4; // light color\n\t\n\tfloat3 pc = float3(0,0,-1); // cam pos\n\tfloat3 ps = float3(0,0,0.5); // sphere pos\n\tfloat r = 0.65; // sphere radius\n\t\n\tfloat3 pd = normalize(float3(tex.x-0.5, tex.y-0.5, 0) - pc);\n\t\n\tfloat A = 1;\n\tfloat B = 2*dot(pd, pc - ps);\n\tfloat C = dot(pc - ps, pc - ps) - r*r;\n\tfloat D = B*B - 4*A*C;\n\t\n\tfloat4 c0 = 0;\n\t\n\tif(D >= 0)\n\t{\n\t\t// t2 is the smaller, obviously...\n\t\t// float t1 = (-B + sqrt(D)) / (2*A);\n\t\t// float t2 = (-B - sqrt(D)) / (2*A);\n\t\t// float t = min(t1, t2); \n\t\t\n\t\tfloat t = (-B - sqrt(D)) / (2*A);\n\t\t\n\t\t// intersection data\n\t\tfloat3 p = pc + pd*t;\n\t\tfloat3 n = normalize(p - ps);\n\t\tfloat3 l = normalize(pl - p);\n\t\t\n\t\t// mapping the image onto the sphere\n\t\ttex = acos(-n)/PI; \n\t\t\n\t\t// rotate it\n\t\ttex.x = frac(tex.x + frac(clock/10));\n\t\t\n\t\t// diffuse + specular\n\t\tc0 = tex2D(s0, tex) * dot(n, l) + cl * pow(max(dot(l, reflect(pd, n)), 0), 50);\n\t}\n\t\n\treturn c0;\n}\n 10=grayscale|ps_2_0|sampler s0 : register(s0);\nfloat4 p0 : register(c0);\nfloat4 p1 : register(c1);\n\n#define width (p0[0])\n#define height (p0[1])\n#define counter (p0[2])\n#define clock (p0[3])\n#define one_over_width (p1[0])\n#define one_over_height (p1[1])\n\n#define PI acos(-1)\n\nfloat4 main(float2 tex : TEXCOORD0) : COLOR\n{\n\tfloat c0 = dot(tex2D(s0, tex), float4(0.299, 0.587, 0.114, 0));\n\t\n\treturn c0;\n}\n |
23rd October 2009, 00:26 | #6000 | Link |
Next time put all your script in a code:
ex: (eraser *, if i dont put * your will not see script) ex: [*code] and at the end of your script [*/code] you will see that : Code:
code embered in a window
