Old 3rd December 2020, 02:09   #1181  |  Link
benwaggoner
Originally Posted by utack View Post
Is Google now actively killing 8k VP9?
A lot of videos only have AV1 as 8k option available, and I found reference to one a year back in a forum that clearly showed VP9 was still available at the time.
The bigger challenge is that reality is killing 8K video because of the limits of human perception. I challenge you to find video content that looks better encoded at native 8K than downscaled to 4K at the same bitrate when viewed at enough distances that the edges of the screen are at a minimally acceptable viewing angle. No one in Hollywood is doing any post production in 8K. Heck, most visual effects are still being done in 2K for cost/speed reasons, and because 2K looks just fine if there's some motion blur and/or grain.
And with everyone working from home, even experimenting in 8K is nigh impossible. There literally aren't any monitors that are 8K, HDR, and have DisplayPort. Monitoring 8K HDR means using a (WAY too big for a desk) TV and a $3K AJA Kona 5 with experimental and finicky HDMI 2.1 firmware.
Ben Waggoner
My Compression Book
Old 10th January 2021, 12:44   #1182  |  Link
takla
With libvpx-vp9 v1.9.0 auto-alt-ref only works in 2pass. was this changed or was this always the case?
takla is offline   Reply With Quote
Old 11th January 2021, 14:56   #1183  |  Link
Beelzebubu
Yes (sadly).
[edit]
At --cpu-used=4 using VBR, it works also in one-pass mode in some cases. But at other speeds or in CRF, it works in 2-pass only.
See this code.
Beelzebubu is offline   Reply With Quote
Old 12th January 2021, 06:20   #1184  |  Link
takla
Originally Posted by Beelzebubu View Post
Yes (sadly).
[edit]
See this code.
Thanks for clarifying. But I'm confused. Why was it changed? Was it not working correctly before?
Old 12th January 2021, 14:21   #1185  |  Link
Beelzebubu
I meant: yes, it was always the case. Sorry for the confusing answer.
Old 12th January 2021, 14:45   #1186  |  Link
takla
Ah alright then. Thanks.
Old 17th February 2021, 12:40   #1187  |  Link
LigH
LigH's Avatar
New upload (MSYS2; MinGW32 / MinGW64: GCC 10.2.0):
VPx v1.9.0-156-g24bd0733e
New German Gleitz board
Old 18th May 2021, 20:49   #1188  |  Link
LigH
LigH's Avatar
New upload (MSYS2; MinGW32 / MinGW64: GCC 10.3.0):
VPx v1.10.0-61-g4808d831d
Old 22nd October 2021, 01:03   #1189  |  Link
takla
2021-09-27
v1.11.0 "Smew Duck"
This maintenance release adds support for VBR mode in VP9 rate control
interface, new codec controls to get quantization parameters and loop filter
levels, and includes several improvements to NEON and numerous bug fixes.
- Upgrading:
New codec control is added to get quantization parameters and loop filter
levels.
VBR mode is supported in VP9 rate control library.
- Enhancement:
Numerous improvements for Neon optimizations.
Code clean-up and refactoring.
Calculation of rd multiplier is changed with BDRATE gains.
- Bug fixes:
Fix to overflow on duration.
Fix to several instances of -Wunused-but-set-variable.
Fix to avoid chroma resampling for 420mpeg2 input.
Fix to overflow in calc_iframe_target_size.
Fix to disallow skipping transform and quantization.
Fix some -Wsign-compare warnings in simple_encode.
Fix input file path in simple_encode_test.
Fix valid range for under/over_shoot pct.
Source
Old 28th May 2022, 22:41   #1190  |  Link
LigH
LigH's Avatar
New upload (MSYS2; MinGW32 / MinGW64: GCC 12.1.0):
VPx v1.11.0-218-g9f1329f8a
Old 30th July 2022, 19:50   #1191  |  Link
LigH
LigH's Avatar
VPx v1.12.0-72-g59acf6739
SVT-VP9 0.3.0-d9ef3cc
Old 10th September 2022, 11:08   #1192  |  Link
LigH
LigH's Avatar
New upload (MSYS2; MinGW32 / MinGW64: GCC 12.2.0):
VPx v1.12.0-153-ga46ca4b6b
Old 28th October 2022, 11:53   #1193  |  Link
LigH
LigH's Avatar
VPx v1.12.0-214-gddca3dec3
Old 28th November 2022, 18:41   #1194  |  Link
LigH
LigH's Avatar
VPx v1.12.0-228-gd998bd823
Old 17th July 2023, 21:45   #1195  |  Link
LigH
LigH's Avatar
New upload (MSYS2; MinGW32 / MinGW64: GCC 13.1.0):
VPx v1.13.0-398-g9ad950a9c
Old 29th October 2023, 19:32   #1196  |  Link
oibaf
Some (not so) recent news:
2023-09-29 v1.13.1 "Ugly Duckling"
This release contains two security related fixes. One each for VP8 and VP9.
- Upgrading:
This release is ABI compatible with the previous release.
- Bug fixes:
https://crbug.com/1486441 (CVE-2023-5217)
Fix to a crash related to VP9 encoding (#1642)
2023-01-31 v1.13.0 "Ugly Duckling"
This release includes more Neon and AVX2 optimizations, adds a new codec
control to set per frame QP, upgrades GoogleTest to v1.12.1, and includes
numerous bug fixes.
- Upgrading:
This release is ABI incompatible with the previous release.
New codec control VP9E_SET_QUANTIZER_ONE_PASS to set per frame QP.
GoogleTest is upgraded to v1.12.1.
.clang-format is upgraded to clang-format-11.
VPX_EXT_RATECTRL_ABI_VERSION was bumped due to incompatible changes to the
feature of using external rate control models for vp9.
- Enhancement:
Numerous improvements on Neon optimizations.
Numerous improvements on AVX2 optimizations.
Additional ARM targets added for Visual Studio.
- Bug fixes:
Fix to calculating internal stats when frame dropped.
Fix to segfault for external resize test in vp9.
Fix to build system with replacing egrep with grep -E.
Fix to a few bugs with external RTC rate control library.
Fix to make SVC work with VBR.
Fix to key frame setting in VP9 external RC.
Fix to -Wimplicit-int (Clang 16).
Fix to VP8 external RC for buffer levels.
Fix to VP8 external RC for dynamic update of layers.
Fix to VP9 auto level.
Fix to off-by-one error of max w/h in validate_config.
Fix to make SVC work for Profile 1.
2022-06-17 v1.12.0 "Torrent Duck"
This release adds optimizations for Loongarch, adds support for vp8 in the
real-time rate control library, upgrades GoogleTest to v1.11.0, updates
libwebm to libwebm-1.0.0.28-20-g206d268, and includes numerous bug fixes.
- Upgrading:
vp8 support in the real-time rate control library.
New codec control VP8E_SET_RTC_EXTERNAL_RATECTRL is added.
Configure support for darwin21 is added.
GoogleTest is upgraded to v1.11.0.
libwebm is updated to libwebm-1.0.0.28-20-g206d268.
Allow SimpleEncode environment to take target level as input to match
the level conformance in vp9.
- Enhancement:
Numerous improvements on checking memory allocations.
Optimizations for Loongarch.
Code clean-up.
- Bug fixes:
Fix to a crash related to {vp8/vp9}_set_roi_map.
Fix to compiling failure with -Wformat-nonliteral.
Fix to integer overflow with vp9 with high resolution content.
Fix to AddNoiseTest failure with ARMv7.
Fix to libvpx Null-dereference READ in vp8.
oibaf is offline   Reply With Quote
Old 30th October 2023, 16:56   #1197  |  Link
benwaggoner
Sounds like meaningful development wrapped up around January? I wonder if many of the contributors moved on to SVT-AV1.
Kind of funny that per-frame QP control took that long to implement.
Ben Waggoner
My Compression Book
Old 1st November 2023, 13:23   #1198  |  Link
oibaf
There are still lot of commits in libvpx after 1.13: https://chromium.googlesource.com/webm/libvpx/+log
Also for classic AV1 libaom: https://aomedia.googlesource.com/aom/+log
Much more than on SVT-AV1 https://gitlab.com/AOMediaCodec/SVT-...ref_type=HEADS
Old 3rd November 2023, 02:20   #1199  |  Link
benwaggoner
Yeah, no doubt that work continues apace on AV1 encoders, open source and proprietary.
Ben Waggoner
My Compression Book
Old 23rd January 2024, 23:01   #1200  |  Link
takla
https://chromium.googlesource.com/we...s/tags/v1.14.0
Release v1.14.0 Venetian Duck
2024-01-18 v1.14.0 "Venetian Duck"
This release drops support for old C compilers, such as Visual Studio 2012
and older, that disallow mixing variable declarations and statements (a C99
feature). It adds support for run-time CPU feature detection for Arm
platforms, as well as support for darwin23 (macOS 14).
- Upgrading:
Various new features for rate control library for real-time: SVC parallel
encoding, loopfilter level, support for frame dropping, and screen content.
New callback function send_tpl_gop_stats for vp9 external rate control
library, which can be used to transmit TPL stats for a group of pictures. A
public header vpx_tpl.h is added for the definition of TPL stats used in
this callback.
libwebm is upgraded to libwebm-1.0.0.29-9-g1930e3c.
- Enhancement:
Improvements on Neon optimizations: VoD: 12-35% speed up for bitdepth 8,
68%-151% speed up for high bitdepth.
Improvements on AVX2 and SSE optimizations.
Improvements on LSX optimizations for LoongArch.
42-49% speedup on speed 0 VoD encoding.
Android API level predicates.
- Bug fixes:
Fix to missing prototypes from the rtcd header.
Fix to segfault when total size is enlarged but width is smaller.
Fix to the build for arm64ec using MSVC.
Fix to copy BLOCK_8X8's mi to PICK_MODE_CONTEXT::mic.
Fix to -Wshadow warnings.
Fix to heap overflow in vpx_get4x4sse_cs_neon.
Fix to buffer overrun in highbd Neon subpel variance filters.
Added bitexact encode test script.
Fix to -Wl,-z,defs with Clang's sanitizers.
Fix to decoder stability after error & continued decoding.
Fix to mismatch of VP9 encode with NEON intrinsics with C only version.
Fix to Arm64 MSVC compile vpx_highbd_fdct4x4_neon.
Fix to fragments count before use.
Fix to a case where target bandwidth is 0 for SVC.
Fix mask in vp9_quantize_avx2,highbd_get_max_lane_eob.
Fix to int overflow in vp9_calc_pframe_target_size_one_pass_cbr.
Fix to integer overflow in vp8,ratectrl.c.
Fix to interger overflow in vp9 svc.
Fix to avg_frame_bandwidth overflow.
Fix to per frame qp for temporal layers.
Fix to unsigned integer overflow in sse computation.
Fix to uninitialized mesh feature for BEST mode.
Fix to overflow in highbd temporal_filter.
Fix to unaligned loads w/w==4 in vpx_convolve_copy_neon.
Skip arm64_neon.h workaround w/VS >= 2019.
Fix to c vs avx mismatch of diamond_search_sad().
Fix to c vs intrinsic mismatch of vpx_hadamard_32x32() function.
Fix to a bug in vpx_hadamard_32x32_neon().
Fix to Clang -Wunreachable-code-aggressive warnings.
Fix to a bug in vpx_highbd_hadamard_32x32_neon().
Fix to -Wunreachable-code in mfqe_partition.
Force mode search on 64x64 if no mode is selected.
Fix to ubsan failure caused by left shift of negative.
Fix to integer overflow in calc_pframe_target_size.
Fix to float-cast-overflow in vp8_change_config().
Fix to a null ptr before use.
Conditionally skip using inter frames in speed features.
Remove invalid reference frames.
Disable intra mode search speed features conditionally.
Set nonrd keyframe under dynamic change of deadline for rtc.
Fix to scaled reference offsets.
Set skip_recode=0 in nonrd_pick_sb_modes.
Fix to an edge case when downsizing to one.
Fix to a bug in frame scaling.
Fix to pred buffer stride.
Fix to a bug in simple motion search.
Update frame size in actual encoding.
google, ngov, vp8, vp9, vpx, webm
