15th April 2014, 15:54 | #2141 | Link |
ffx264/ffhevc author
Not necessarily. Compiling both MPlayer and x264 is a fairly easy job. Just make sure to use --disable-vdpau when configuring MPlayer and make sure you have yasm installed when compiling x264
(I mention --disable-vdpau because I don't know how Hybrid works. If you try to encode directly with MEncoder which has vdpau enabled, it will error out as it doesn't support it) |
15th April 2014, 15:56 | #2142 | Link | |||
ffmpeg, mplayer, mediainfo, mkvinfo and sox to analyse normal file input (all essential) lsdvd is needed for dvd input (essential) mkvmerge is needed for mkv cutting and muxing (essential for mkv output) mkvextract is needed to extract timecodes and streams in general from mkv input (essential for mkv handling in general) delaycut is needed to fix audio streams and fix their delay (essential) tsMuxeR is needed to handle transportstreams (not essential if an up-to-date ffmpeg version with libbluray is used) NeroAacEnc is needed for aac audio encoding (not essential) oggenc is needed for vorbis audio encoding (not essential) aften is needed for ac3 audio encoding (not essential) frameCounter is needed for raw video input (essential) FLVExtractCL is needed for flv input (essential) MP4Box is needed for mp4 handling (essential) dcaenc is needed for dts encoding (not essential) mp4fpsmod is needed for mp4 timecode handling (essential) telxcc is needed for teletext subtitle handling (not essential) vpxenc is needed for vp8/vp9 video encoding (not essential) mencoder is needed for audio handling and xvid encoding (essential) flac is needed for flac audio encoding (not essential) x265 is needed for HEVC video encoding (not essential) Kvazaar is needed for HEVC video encoding (not essential) x264 is needed for AVC video encoding (not essential) Qt runtime 4.6 or newer (essential) -> in general I would recommend to: a. keep the tools up-to-date b. install all optional tools Quote:
Also it works fine here on Ubuntu 10.04 and newer. -> Why should it be useless? Quote:
Cu Selur |
15th April 2014, 16:40 | #2143 | Link | ||
ffmpeg, mplayer, mediainfo, mkvinfo and sox to analyse normal file input (all essential) lsdvd is needed for dvd input (essential) mkvmerge is needed for mkv cutting and muxing (essential for mkv output) mkvextract is needed to extract timecodes and streams in general from mkv input (essential for mkv handling in general) delaycut is needed to fix audio streams and fix their delay (essential) NeroAacEnc is needed for aac audio encoding (not essential) frameCounter is needed for raw video input (essential) FLVExtractCL is needed for flv input (essential) <- why? since all of files i encoded are in .mkv extension. MP4Box is needed for mp4 handling (essential) mp4fpsmod is needed for mp4 timecode handling (essential) mencoder is needed for audio handling and xvid encoding (essential) x265 is needed for HEVC video encoding (not essential) x264 is needed for AVC video encoding (not essential) Qt runtime 4.6 or newer (essential) <-can you tell me where can i find Qt runtime 4.6? Quote:
15th April 2014, 16:44 | #2144 | Link | ||
16th April 2014, 09:53 | #2146 | Link |
selur, how can i compile mplayer with bluray support? because my compiled Mplayer doesn't include bluray option...
root@norvin-Lenovo-IdeaPad-Z400:~# mplayer -bluray-device Error parsing option on the command line: -bluray-device MPlayer SVN-r37152-4.8 (C) 2000-2014 MPlayer Team root@norvin-Lenovo-IdeaPad-Z400:~# mplayer -v MPlayer SVN-r37152-4.8 (C) 2000-2014 MPlayer Team CPU vendor name: GenuineIntel max cpuid level: 13 CPU: Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz (Family: 6, Model: 58, Stepping: 9) extended cpuid-level: 8 extended cache-info: 16801856 Detected cache-line size is 64 bytes CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNowExt: 0 SSE: 1 SSE2: 1 SSE3: 1 SSSE3: 1 SSE4: 1 SSE4.2: 1 AVX: 1 Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2 SSE3 SSSE3 SSE4 SSE4.2 AVX CMOV get_path('codecs.conf') -> '/root/.mplayer/codecs.conf' Reading optional codecs config file /root/.mplayer/codecs.conf: No such file or directory Reading optional codecs config file /usr/local/etc/mplayer/codecs.conf: No such file or directory Using built-in default codecs.conf. init_freetype Using MMX (with tiny bit MMX2) Optimized OnScreenDisplay get_path('fonts') -> '/root/.mplayer/fonts' Usage: mplayer [options] [url|path/]filename Basic options: (complete list in the man page) -vo <drv> select video output driver ('-vo help' for a list) -ao <drv> select audio output driver ('-ao help' for a list) vcd://<trackno> play (S)VCD (Super Video CD) track (raw device, no mount) dvd://<titleno> play DVD title from device instead of plain file -alang/-slang select DVD audio/subtitle language (by 2-char country code) -ss <position> seek to given (seconds or hh:mm:ss) position -nosound do not play sound -fs fullscreen playback (or -vm, -zoom, details in the man page) -x <x> -y <y> set display resolution (for use with -vm or -zoom) -sub <file> specify subtitle file to use (also see -subfps, -subdelay) -playlist <file> specify playlist file -vid x -aid y select video (x) and audio (y) stream to play -fps x -srate y change video (x fps) and audio (y Hz) rate -pp <quality> enable postprocessing filter (details in the man page) -framedrop enable frame dropping (for slow machines) Basic keys: (complete list in the man page, also check input.conf) <- or -> seek backward/forward 10 seconds down or up seek backward/forward 1 minute pgdown or pgup seek backward/forward 10 minutes < or > step backward/forward in playlist p or SPACE pause movie (press any key to continue) q or ESC stop playing and quit program + or - adjust audio delay by +/- 0.1 second o cycle OSD mode: none / seekbar / seekbar + timer * or / increase or decrease PCM volume x or z adjust subtitle delay by +/- 0.1 second r or t adjust subtitle position up/down, also see -vf expand * * * SEE THE MAN PAGE FOR DETAILS, FURTHER (ADVANCED) OPTIONS AND KEYS * * * |
16th April 2014, 10:01 | #2148 | Link |
The problem with the call above: Code:
"home/norvin/mplayer" -v br:// -blu-ray-device Testing |
16th April 2014, 12:56 | #2149 | Link | |
is it possible to share it to me? |
16th April 2014, 13:06 | #2150 | Link | |
Yes, Hybrid does work on Ubuntu. The version for 64bit Ubuntu 13.10 would be the normal "Hybrid Linux64bit"-download.
Sharing binaries like mplayer&co isn't that easy on Linux since most tools can't really be compiled totally static, so they will only work with a specific distribution. Most of the tools required should be available through the normal: Code:
sudo apt-get install nameoftool Quote:
a. some tools wouldn't work b. some tools are not freely distributable in binary form |
17th April 2014, 17:33 | #2152 | Link | |
The a program does not respond to a call can have a lot of reasons some serious like some trojan running wild a simple one like a hdd that takes to long to spin up.
Normally it's just a buggy build of the tool called (or some unfinished update which removed some libraries the tool depends on). So keeping a working background tools normally is a good idea. (especially in the case of x265, some build work fine and other simply crash on some machines and not others) Side note: if you change out tools, clear the tool cache in Hybrid (Config->Tools), so that Hybrid will rescan for the tools and their versions. Quote:
19th April 2014, 02:19 | #2153 | Link |
so, i found out why Hybrid got an error in my laptop : it's also check my Home folder that also has same name folder (ffmpeg, neroaac, also mplayer).
seriously, why Hybrid also check my Home folder if most of the tools can be find on /usr/bin or local folder? anyway, i got stuck when Hybrid exracted fonts from my mkv file. does it use mkvextract? because when i use it in root, it extracted smoothly. Last edited by xkinn123; 19th April 2014 at 05:05. |
19th April 2014, 05:53 | #2154 | Link | |
Hybrid uses 'which' to find the tools, in example it calls: 'which mplayer' and then uses the first path it get's.
-> manually setting the paths to the tools under Config->Tools and saving the new paths as defaults should solve that Quote:
-> can't really say more without a debugoutput. (read: http://www.selur.de/support) Cu Selur |
19th April 2014, 11:32 | #2155 | Link |
selur, can you fix this one?
it's about minimizing to the system tray. when i tried to minimize it, it went to system tray. but, when i tried to unminimize it, i can't. it looked like this . i kept click it but it has no response. OS: Ubuntu 14.04 Last edited by xkinn123; 20th April 2014 at 15:37. |
20th April 2014, 18:20 | #2160 | Link |
Only real restriction regarding A/V handling I see with the home is it's restriction to 16GB RAM, when having 4k resolutions in mind.
http://www.zdnet.com/blog/bott/do-you-need-more-than-windows-7-home-premium/1128 might be interesting |
