Old 23rd July 2017, 15:13   #3561  |  Link
edcrfv94
Maybe auto one processes for each C/C++ filter(auto switch 32bit if 64bit not available) and auto adjustment prefetch and keep frames cache, can temporarily solve the multi-threaded problem until a new method appears.
colorbars(width = 1920, height = 1080, pixel_type = "yv12")
src = last
mcdn = src.kf_MCDegrainN(clip c, int "tr")
rfs(src, mcdn, mappings="[1000 2000] [3000 4000]") #Remap Frames
function kf_MCDegrainN(clip c, int "tr")
	tr       = default(tr,          6)
	super  = MSuper(levels=0)
	multi_vec = MAnalyse(super, multi=true, delta=tr)
	c.MDeGrainN(super, multi_vec, tr)
	return last
src = last
#1 processes prefetch 16 keep 14
#export last, src
#pass
		tr       = default(tr,          6)
		#2 processes prefetch 14 keep 12
		#export super
		#pass last, c
		#3 processes prefetch 12 keep 10
		#export multi_vec
		#pass last, c, super
		#4 processes prefetch 10 keep 8
		#export last
		#pass
		return last
#5 processes prefetch 8 keep 6
#export last
MP_Pipeline cann't pass audio, just for example.
MP_Pipeline("""
	SetMemoryMax(500)
	src = last
### export clip:src
### prefetch: 14,12
	SetMemoryMax(500)
	c = src
### export clip:c, super
### pass clip:src
### prefetch: 12,10
	SetMemoryMax(500)
### export clip:multi_vec
### pass clip:src, c, super
### prefetch: 10,8
	SetMemoryMax(500)
	mcdn = c.MDeGrainN(super, multi_vec, tr)
### export clip:mcdn
### pass clip:src
### prefetch: 8,6
	SetMemoryMax(500)
edcrfv94 is offline   Reply With Quote
Old 23rd July 2017, 15:31   #3562  |  Link
real.finder
yes, Unfortunately
I wish someone did these changes https://github.com/SAPikachu/MP_Pipe...ment-269108878
My Avisynth Stuff
Old 13th August 2017, 05:18   #3563  |  Link
real.finder
hi pinterf
when you back can you check this, I didn't note it before since I use mpp(MP_Pipeline) most of the time and by using mpp it seems to work!
edit: this one too https://forum.doom9.org/showpost.php...postcount=2709 since you will touch the autoload things
edit2: this one too https://forum.doom9.org/showthread.p...12#post1814912
My Avisynth Stuff
Old 25th August 2017, 09:36   #3564  |  Link
junh1024
Really, how hard is it 2 make SSRC accept int16 in? Most of the audio tools (DAWs, VSTs, outside of avs) I use happily do format/bitdepth conversions silently.
junh1024 is offline   Reply With Quote
Old 1st September 2017, 12:02   #3565  |  Link
fenarinarsa
AddAutoLoadDir behavior changed
Hello everyone,
Since AVS+ 2502 the AddAutoLoadDir behavior changed.
Before this version, I could add 32bits and 64 bits DLLs (in two different folders) and AviSynth would load the correct ones depending on the environment it's working on. Because I currently must use an old x86 software and ffmpeg x64 at the same time from the same script.
Now it fires an error (cannot load DLL...) and stops there.
That a real issue for me since I generate an AVS+ script that should work in 32bits *and* 64bits and that I don't use the AVS+ default plugins dir (we have in-house developments).
In other word, this change in behavior breaks everything that was working quite well until now
I looked for a way of having conditionnal loading, but I couldn't find a variable that returns the current environment. Another way would be to add an optional argument to AddAutoLoadDir like "errors=false".
Am I missing something there ?
BTW I'm the technical director of a cable/DSL French TV channel and we've been using AviSynth and AVS+ for 9 years to generate our on-air & VOD/catch-up video graphics
I must say you're doing an awesome work. Last year I was thinking about ditching AVS because we had a lot of issues relating to memory management, HD, ffmpeg and QuickTime, but AVS+ saved it
demo => http://www.youtube.com/watch?v=ZbHMMxTcgec
fenarinarsa is offline   Reply With Quote
Old 1st September 2017, 12:21   #3566  |  Link
Groucho2004
I guess you can blame me for this since I suggested to pinterf to add a check for the correct bitness of plugins in the auto-load directories.
A possible solution for this could be to modify the AddAutoLoadDir() functionality so the bitness check is omitted on the script level. This way, only the "hard coded" auto-load directories to which the registry entries point will be checked.
Old 1st September 2017, 13:30   #3567  |  Link
pinterf
Sorry for the inconvenience.
From version r2487 there is a new script function:
int GetProcessInfo([int type = 0])
Without parameter or type==0 the current bitness of Avisynth DLL is returned (32 or 64)
With type=1 the function can return a bit more detailed info:
-1: error, can't establish
0: 32 bit DLL on 32 bit OS
1: 32 bit DLL on 64 bit OS (WoW64 process)
2: 64 bit DLL
Usage:
LoadPlugin(GetProcessInfo == 32 ? "This32.dll" : "This64.dll")
pinterf is offline   Reply With Quote
Old 1st September 2017, 13:54   #3568  |  Link
Groucho2004
Originally Posted by pinterf View Post
Usage:
I don't think this is exactly what he's looking for, he want's to use auto-load. However, something like this maybe:
(GetProcessInfo == 32) ? AddAutoLoadDir("32BitplugsDir") : AddAutoLoadDir("64BitplugsDir")
Old 1st September 2017, 15:05   #3569  |  Link
fenarinarsa
Thanks a lot! That's what I was looking for.
I read a few months ago that a function to return the bitness was added, but I couldn't find it in the documentation.
So it works now, time to deploy r2508
BTW I still didn't activate MT because I found some bugs. I suppose I can do bug reports here ? (it usually takes time because I do full reports with sample files)
Old 1st September 2017, 15:11   #3570  |  Link
pinterf
Yes, we all like well documented bug reports Thanks.
Old 2nd September 2017, 14:43   #3571  |  Link
tebasuna51
tebasuna51's Avatar
Last OT posts moved to https://forum.doom9.org/showthread.php?t=174847
Old 3rd September 2017, 17:25   #3572  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
I must be doing something wrong because I don't see any change with or without Prefetch(8). Speed,number of threads and memory consumption is identical.
script
#MT
Import("C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\AviSynth plugins\Scripts\MTmodes.avs")
#VideoSource
video=DirectShowSource("E:\_Video_Samples\mkv\drive_video_10min.mkv",audio=false).ConvertToYV12(matrix="rec709")
#Crop
video=Crop(video,0,140,-0,-140)
#Denoise
Loadplugin("C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\AviSynth plugins\mvtools\mvtools2.dll")
super=MSuper(video,pel=2)
fv1=MAnalyse(super,isb=false,delta=1,overlap=4)
bv1=MAnalyse(super,isb=true,delta=1,overlap=4)
fv2=MAnalyse(super,isb=false,delta=2,overlap=4)
bv2=MAnalyse(super,isb=true,delta=2,overlap=4)
video=MDegrain2(video,super,bv1,fv1,bv2,fv2,thSAD=400)
return video
prefetch(8)
AVSMeter 2.2.6 (x86)
AviSynth+ 0.1 (r2508, MT, i386) (0.1.0.0)
Loading script...
Number of frames:                14751
Length (hh:mm:ss.ms):     00:10:15.117
Frame width:                      1920
Frame height:                      800
Framerate:                      23.981 (10000/417)
Colorspace:                       YV12
Frame (current | last):         144 | 14750
FPS (cur | min | max | avg):    1.985 | 1.946 | 4.142 | 2.407
Memory usage (phys | virt):     287 | 336 MiB
Thread count:                   37
CPU usage (current | average):  8% | 6%
Time (elapsed | estimated):     00:01:00.231 | 01:42:07.361
without prefetch
Loading script...
Frame width:                      1920
Frame height:                      800
Colorspace:                       YV12
FPS (cur | min | max | avg):    1.981 | 1.945 | 4.097 | 2.401
Thread count:                   37
CPU usage (current | average):  7% | 6%
Time (elapsed | estimated):     00:01:00.384 | 01:42:22.926
Old 3rd September 2017, 17:36   #3573  |  Link
TheFluff
Excessively jovial fellow
You have "return video" above prefetch in the filter chain. I think prefetch actually kinda is a pseudo-filter of its own, so it might matter - not sure though.
Old 3rd September 2017, 17:41   #3574  |  Link
Atak_Snajpera
Yes! You are right! Prefetch acts like filter so this works now
#MT
#VideoSource
#Crop
#Denoise
video=prefetch(video,8)
return video
Old 4th September 2017, 10:07   #3575  |  Link
Groucho2004
@Mod
Posts #3576 and onwards should be moved to the fft3dfilter thread.
Old 4th September 2017, 20:42   #3576  |  Link
tebasuna51
tebasuna51's Avatar
Posts moved.
Old 5th September 2017, 05:54   #3577  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
With the latest version of Avisynth+, I'm still unable to open script files names containing international character in MPC-HC; but the same files open fine in VirtualDub.
I thought this had been solved? Here's an example of file name: おどるポンポコリン.mp4
MysteryX is offline   Reply With Quote
Old 5th September 2017, 07:20   #3578  |  Link
Groucho2004
Not sure why your example has a .mp4 extension but opening a script "おどるポンポコリン.avs" works fine in mpc-hc even without switching the locale to Japanese. This is on XP.
Old 5th September 2017, 15:20   #3579  |  Link
Atak_Snajpera
Source: 3840x2160 AVC
CPU: E5-2690 (8C/16T)
RAM: 64 GiB
OS: Win7 x64
Avisynth+: r2508 x86
#MT
#VideoSource
video=DirectShowSource("E:\_Video_Samples\mp4\UHD_0035.MP4",audio=false).ConvertToYV12(matrix="rec709")
#Resize
video=Spline36Resize(video,1920,1080).Sharpen(0.2)
#Denoise
#Prefetch
video=Prefetch(video,X)
#Return
return video
I wonder why performance drops so heavily when process uses more than 2000 MiB of memory?
8 Threads
Loading script...
Number of frames:                  420
Length (hh:mm:ss.ms):     00:00:14.014
Frame width:                      1920
Frame height:                     1080
Framerate:                      29.970 (5000000/166833)
Colorspace:                       YV12
Frames processed:               420 (0 - 419)
FPS (min | max | average):      0.581 | 472300 | 10.53
Memory usage (phys | virt):     1609 | 1800 MiB
Thread count:                   45
CPU usage (average):            52%
Time (elapsed):                 00:00:39.880
14 Threads
Loading script...
Frame width:                      1920
Frame height:                     1080
Colorspace:                       YV12
FPS (min | max | average):      0.181 | 566759 | 12.38
Memory usage (phys | virt):     1784 | 1984 MiB
Thread count:                   51
CPU usage (average):            89%
Time (elapsed):                 00:00:33.925
15 Threads
Loading script...
Frame width:                      1920
Frame height:                     1080
Colorspace:                       YV12
FPS (min | max | average):      0.196 | 472300 | 7.495
Memory usage (phys | virt):     1826 | 2016 MiB
Thread count:                   52
CPU usage (average):            57%
Time (elapsed):                 00:00:56.034
16 Threads
Loading script...
Frame width:                      1920
Frame height:                     1080
Colorspace:                       YV12
FPS (min | max | average):      0.170 | 566760 | 6.253
Memory usage (phys | virt):     1850 | 2045 MiB
Thread count:                   53
CPU usage (average):            39%
Time (elapsed):                 00:01:07.169
Old 5th September 2017, 16:17   #3580  |  Link
Atak_Snajpera,
What happens if you get virtual memory use over 2048MiB ?
