9th December 2003, 03:37 | #61 | Link |
Hmm.. ChapterGrabber seems to not like it when there are more then one chapter set (I wouldn't either =P) Here's an example:
http://video.barnesandnoble.com/sear...5&VIEW=SCN#SCN CHAPTER01=00:00:00.000 CHAPTER01NAME=The Beginning CHAPTER02=00:00:57.302 CHAPTER02NAME=Music CHAPTER03=00:05:58.969 CHAPTER03NAME=Storyboards CHAPTER04=00:13:46.137 CHAPTER04NAME=Art Direction CHAPTER05=00:20:29.004 CHAPTER05NAME=Puppets CHAPTER06=00:25:51.805 CHAPTER06NAME=Animation CHAPTER07=00:30:19.639 CHAPTER07NAME="Jack's Obsession" CHAPTER08=00:35:09.974 CHAPTER08NAME="The Scheming Song" CHAPTER09=00:38:20.341 CHAPTER09NAME=Sally's Forewarning CHAPTER10=00:40:56.010 CHAPTER10NAME="Making Christmas" CHAPTER11=00:45:17.377 CHAPTER11NAME=Sandy Claws in Person CHAPTER12=00:48:10.512 CHAPTER12NAME="Oogie Boogie's Song" CHAPTER13=00:50:43.879 CHAPTER13NAME=Zero Lights the Way CHAPTER14=00:53:02.546 CHAPTER14NAME="Sally's Song" CHAPTER15=00:54:47.013 CHAPTER15NAME=Christmas Eve Montage CHAPTER16=00:59:47.680 CHAPTER16NAME=Shot out of the Sky CHAPTER17=01:01:36.347 CHAPTER17NAME="Poor Jack" CHAPTER18=01:04:38.682 CHAPTER18NAME=To the Rescue! CHAPTER19=01:08:49.516 CHAPTER19NAME="Finale/Reprise" CHAPTER20=01:11:25.516 CHAPTER20NAME=End Credits Seems to be a Commentary/Normal Audio issue. |
9th December 2003, 21:53 | #62 | Link |
suryc: use the import from clipboard feature
ChapterGrabber - add names to your chapters | AtomSite - open source AtomPub server |
26th March 2004, 06:31 | #63 | Link |
New version available with support for writing matroska chapter Xml files. Reading will be included in next version. Enjoy!
See top of thread for download link
26th March 2004, 15:32 | #64 | Link |
Little suggestion:
Put a menu with the links to the webs where the EANs or chapters can be found: http://video.barnesandnoble.com http://www.allmovie.com http://www.blockbuster.com ... ... Last edited by Palikrovol; 26th March 2004 at 15:44. |
19th April 2004, 07:13 | #66 | Link |
The textfile must have the ChapterXtractor OGG format.
Example: CHAPTER01=00:00:00.000 CHAPTER01NAME=Chapter 1 CHAPTER02=00:02:50.100 CHAPTER02NAME=Chapter 2 CHAPTER03=00:03:41.633 CHAPTER03NAME=Chapter 3 ...
::zulu's devpage:: |
19th April 2004, 17:37 | #67 | Link | |
------------- CHAPTER01=00:00:00.000 CHAPTER02=00:02:50.100 CHAPTER03=00:03:41.633 --------------- Or--would it actually read like your original quote at the top, although the names are not known yet--just calling them "Chapter 1", etc.? |
23rd April 2004, 14:38 | #68 | Link |
it would actually read like my original quote.
"Chapter n" is a standard chaptername chapterXtractor uses when creating ogg chapterfiles from an ifo as it can't get the original name from the ifo. so basically a chapter entry requires 2 lines: line a: timecode line b: chaptername (unimportant, will be overriden by chaptergrabber) regards, zulu
13th July 2004, 18:29 | #69 | Link |
i tried the .reg option for setting chapters in xvid's zones, but it didnt work, meaning the reg entries got added to the registry, but they didnt show up in xvid's gui itself
i am using winme (yeah i know )
15th July 2004, 03:02 | #70 | Link |
Try searching for where xvid stores the settings in your registry. Once you find the correct key change the value in the "ChapterGrabber.exe.config" file.
The default looks like: <add key="xvidreg" value="[HKEY_CURRENT_USER\Software\GNU\XviD]"/>
15th July 2004, 19:18 | #71 | Link |
it seems that the default one is the correct one here, at least there are a bunch of values stored already. and the chaptermarks are also listed there when using chaptergrabbers option, still they are not shown in the xvid gui
will check more deeply
26th September 2004, 02:22 | #72 | Link |
Hi!
Wonderfull tool, but I have a small problem here: The Star Wars trilogy comes in a box, when retrieving titles from the internet I just get the titles from the first DVD. If I want to set keyframes at the beginning of a chapter, adding the reg file to registry is all I have to do? Must I delete the changes by hand after the encoding? Thanks! Last edited by darkpepe; 26th September 2004 at 17:34. |
29th October 2004, 17:12 | #74 | Link | ||
So far it has been my experience that DVD chapter times aren't always as accurate as I'd like them to be. For example, sometimes a chaptertime doesn't correspond to the first frame of the scene as it should. I personally gave up on forcing keyframes and just go with jumping to the nearest keyframe. Works well enough.
ChapterGrabber - add names to your chapters | AtomSite - open source AtomPub server Last edited by Emp3r0r; 29th October 2004 at 17:14. |
31st October 2004, 14:41 | #75 | Link | |
4th November 2004, 23:21 | #76 | Link | |
21st April 2005, 09:15 | #78 | Link |
As in my opinion chapters is a must-have in my backups I heavily rely on your nifty little pogramme.
Haven't backed-up for a long time I recently discovered differences between data delivered by chapterXtractor (which are correct) and your programmes'. Timecodes AND frames are totally off, though framerate was set to 25fps/PAL accordingly... Ifo is from StarWars Ep.6 This is what the Grabber is showing: And here are the first lines from ChapterXtractor, both frames and corresponding timecodes (25fps): Code:
1=0 Chapter 1 2=500 Chapter 2 3=2778 Chapter 3 4=7192 Chapter 4 5=11771 Chapter 5 6=17801 Chapter 6 7=20669 Chapter 7 8=25320 Chapter 8 9=31893 Chapter 9 10=36165 Chapter 10 Code:
CHAPTER01=00:00:00.000 CHAPTER01NAME=Chapter 1 CHAPTER02=00:00:20.000 CHAPTER02NAME=Chapter 2 CHAPTER03=00:01:51.120 CHAPTER03NAME=Chapter 3 CHAPTER04=00:04:47.680 CHAPTER04NAME=Chapter 4 CHAPTER05=00:07:50.840 CHAPTER05NAME=Chapter 5 CHAPTER06=00:11:52.040 CHAPTER06NAME=Chapter 6 CHAPTER07=00:13:46.760 CHAPTER07NAME=Chapter 7 CHAPTER08=00:16:52.800 CHAPTER08NAME=Chapter 8 CHAPTER09=00:21:15.720 CHAPTER09NAME=Chapter 9 CHAPTER10=00:24:06.600 CHAPTER10NAME=Chapter 10 Can you fix this? Current workaround is to create chapterfile with ChapterXtractor and then load it into the Grabber.
I'm probably misconfused... |
21st September 2005, 04:13 | #80 | Link |
I've attached the latest version I've found. Sorry my website is down so you'll need to wait for the attachment to be approved.
