Old 15th February 2013, 11:57   #14181  |  Link
NikosD
Impressive video from today's meteor attack in Russia, Chelyabinsk.
https://www.dropbox.com/s/xt6t6zbbav6tmak/Russia%20%281%29-HD.mp4
But it's not playable in DXVA mode (ATI hardware on signature system).
Not DXVA-compliant or ATI hardware/drivers ?
Win 10 x64 (18363.720) - Core i3-9100F - nVidia 1660 (442.74)
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 15th February 2013, 12:34   #14182  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
Height > 1080 (or 1088, depends on how it's checked). Won't get played with most of current DXVA implementations I'd guess, especially ATi/AMD :P
[I'm human, no debug]
JEEB is offline   Reply With Quote
Old 15th February 2013, 12:38   #14183  |  Link
detmek
Plays fine with MPC-BE internal DXVA decoder, Nvidia 9500GT (VP2) and Windows 7.
detmek is offline   Reply With Quote
Old 15th February 2013, 12:53   #14184  |  Link
nevcairiel
You'll have to enable UHD/4K decoding in LAVs options because it only checks based on height. It'll then probe the hardware for support for this resolution, if it works or not, i don't know. NVIDIA supports "rotated" resolutions like this, i think, not sure about AMD.
Old 15th February 2013, 15:27   #14185  |  Link
wanezhiling
LAV blacklist 4K DXVA on AMD, the resolution is limited to 1920x1200 even you enable UHD/4K decoding in LAVs options.
Here are some resolution-limit-test samples, made by mpc-be team, I think you will like them.
h264_dxva_width_limit_test
h264_dxva_height_limit_test
h264_dxva_macroblocks_limit_test
h264_dxva_square_limit_test
PS: Use latest mpc-hc or PotPlayer for the accurate result.
Old 15th February 2013, 16:22   #14186  |  Link
NikosD
From the above 3, wanezhiling was right.
I did the test using Radeon 3650 and my 5750 with MPC decoder, LAV Video and PotPlayer.
MPC decoder and PotPlayer if you force it to always use DXVA regardless resolution, can actually play in DXVA mode that "rotated" 720 x 1280 clip.
So AMD supports those "rotated" resolutions, too - even in very old hardware like Radeon 3650.
On the other hand, LAV Video doesn't support it even in newer hardware like 5750 and even if you enable UHD/4K decoding.
So, Nevcairiel if you have time you can check again the UHD/4K option with AMD hardware.
Old 15th February 2013, 16:47   #14187  |  Link
nevcairiel
They are not very common, so its not a big thing, but i can probably make the check smarter to allow them.
Old 16th February 2013, 03:43   #14188  |  Link
Tornado15550
Hi nevcairiel. First off, I'd like to thank you for creating LAV filters.
They are amazing!
I have a feature request for the LAV Splitter, if you don't mind. This feature is the only thing keeping me from switching over from Haali.
Haali has an option called "Use custom media type for H.264". This option enables me to watch 10 bit video (Hi10P) on Windows Media Player & Windows Media Center.
I was wondering if you could implement this feature in the LAV Splitter.
Thanks!
Tornado15550 is offline   Reply With Quote
Old 16th February 2013, 07:16   #14189  |  Link
nevcairiel
No, i cannot implement a stupid option like this.
There are plenty tools to configure which decoder is used in WMP, you don't need to use a wrong solution like this.
Old 16th February 2013, 18:06   #14190  |  Link
Tornado15550
Ok, could you recommend a tool that will allow me to configure which decoder I can use?
Old 16th February 2013, 20:25   #14191  |  Link
Superb
http://codecguide.com/windows7_preferred_filter_tweaker.htm
Superb is offline   Reply With Quote
Old 16th February 2013, 21:59   #14192  |  Link
zerowalker
Could you add a status tab so you can see what bitrates itīs using and such?
As sometimes that features is just so helpful
zerowalker is offline   Reply With Quote
Old 17th February 2013, 12:22   #14193  |  Link
DragonQ
I have an interlaced VC-1 file that doesn't deinterlace properly with WMV9 DMO (using either MadVR or EVR). It plays properly using CUVID. I assume it's a problem with the codec but what do I know, it might be fixable. Sample is here.
It's a 1080i/25 video that was converted (pretty badly) to 1080i/30 for BD so it's never gonna look properly smooth. You can tell when it's not being deinterlaced properly by the combing though.
HTPC Hardware: Intel Celeron G530; nVidia GT 430
HTPC Software: Windows 7; MediaPortal 1.19.0; Kodi DSPlayer 17.6; LAV Filters (DXVA2); MadVR
TV Setup: LG OLED55B7V; Onkyo TX-NR515; Minix U9-H
Old 17th February 2013, 12:30   #14194  |  Link
nevcairiel
Looks fine here. All frames are marked as interlaced, so from the decoders point of view, everything is fine. And i also see no combing. EVR deinterlaces it to 60p
PS:
Blu-ray supports 25i just fine, whats with the conversion crap? :d
Old 17th February 2013, 12:50   #14195  |  Link
DragonQ
Hmmmmm EVR says ~30 fps for me and I get combing, unless I turn on CUVID. :/
PS:
It's so that they can have one international BD master that can be released everywhere I guess. Total bullshit considering the majority of the market is in the UK and they already have the 1080i/25 master that they used for HDTV.
Old 17th February 2013, 13:30   #14196  |  Link
mcr
Are there plans to incorporate support for Matroska file segments?
The last reference about segments I was able to find is from 2011, so I hope you don't mind me bringing this up again.
mcr is offline   Reply With Quote
Old 17th February 2013, 14:34   #14197  |  Link
wanezhiling
http://forum.doom9.org/showthread.ph...75#post1608775
Old 18th February 2013, 12:14   #14198  |  Link
balkerman
Hi, could someone explain how I install and use the symbols to help debug. Also using madvr... Thanks!
Also when using 32bit mpc-hc on 64bit windows, which symbols do I use?
balkerman is offline   Reply With Quote
Old 18th February 2013, 12:29   #14199  |  Link
cyberbeing
Broadband Junkie
Use the 32bit symbols and place them in the same directory as the matching x86 LAV components were installed to.
Old 18th February 2013, 17:01   #14200  |  Link
Owyn
nevcairiel, Hi again, I got answer back from KMPlayer forum about KMPlayer + LAV problem, they ask if you could "implement a feature like in AV Splitter. It's called 'Single Output pin'. Its disabling makes it possible to switch audio tracks with KMP hotkeys.", can\would you?
Owyn is offline   Reply With Quote
