4th March 2012, 13:25 | #21 | Link | |
4th March 2012, 13:36 | #22 | Link |
Just start pushing samples at 40ms apart as soon as the graph is run, starting from time 0. If there is no subpic, just send empty frames. That's basically how my subtitle renderer works. You just gotta watch out when the user seeks in the graph as it resets the times. You don't even need to time it manually, GetDeliveryBuffer will block until its ready to receive again.
4th March 2012, 14:18 | #23 | Link | ||
This way you will not have to post a build for testing every time you change something and also maybe someone else can help
Intel UHD Graphics 750; Win 10 22H2 |
4th March 2012, 15:44 | #24 | Link | |
I want to show the animate but not only the last image. The demo_player is copy from MS's DShow sample code "dshowplayer", I'm afraid it has copyright isseue, so I do not put it on SVN. Ok I will upload it soon. |
4th March 2012, 16:22 | #25 | Link | |
4th March 2012, 21:15 | #27 | Link | |
5th March 2012, 09:54 | #29 | Link |
You're welcome
Can you add to svn a text file with a guide of how to build ? ( cause I'm missing some dll after building the solution and the jar ) P.S. any chance for a x64 version too ?
5th March 2012, 10:13 | #30 | Link | |
copy the cvmi.dll, jdwp.dll, dt_socket.dll and the lib dir. to your binary dir. Phoneme is hard to build, just use it. libbluray.jar is the bdj lib, copy it unless you want to rebuild it from java source in libbluray\src\libbluray\bdj\java donot foget to register the ax and dll you build. x64 not available now because phoneme have not be port to x64. Last edited by cb2000; 5th March 2012 at 11:21. |
5th March 2012, 10:23 | #31 | Link |
I had try empty frame then, but because u don't decode the stream, u don not know when it stop and when empty frame should start, none successful. And I had a conclusion that only if the decoder is included in the source filter, the custom mixer is not needed.
5th March 2012, 10:44 | #32 | Link | |
Also on a first build I'm getting 1 failed Code:
LINK : fatal error LNK1181: cannot open input file 'BaseClasses.lib' EDIT I see you've edit your post about the rest of the dll so OK I'll copy them but what about libbluray.jar should I copy that too?
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 5th March 2012 at 10:49. |
6th March 2012, 00:31 | #33 | Link |
cb2000, I tried using your filter in my video player. It works with EVR, but I can't get it to work using EVR and my custom presenter. I see in my logs it asks for MR_VIDEO_RENDER_SERVICE, about 100 times. For which I
*ppv = m_pDeviceManager; m_pDeviceManager->AddRef(); then return S_OK any ideas ? |
6th March 2012, 02:15 | #34 | Link | |
6th March 2012, 11:56 | #35 | Link |
It does
When the class is create it creates the D3D device and does // Reset the D3DDeviceManager with the new device hr = m_pDeviceManager->ResetDevice(pDevice, m_DeviceResetToken); It also does it again when the user sets SetVideoWindow(HWND) |
8th March 2012, 03:52 | #36 | Link |
Now that Slysoft have added a simple HDMV based menu option to AnyDVD HD (Speed Menu), it would be great if there was a navigator filter available to permit a PC to become a functional player.
I'm not sure if your navigator filter supports this, but it would have to be easier to implement than Java as a first step. |
12th March 2012, 13:04 | #37 | Link | |
I think i should implement most common used funtion of BDJ first. |
12th March 2012, 16:18 | #38 | Link | |
Case 1 Code:
c:\dslibbluray\libbluray\src\libbluray\bluray.c:848: libbluray version 0.2.2 c:\dslibbluray\libbluray\src\libbluray\bluray.c:564: AACS/Unit_Key_RO.inf not fo und. No AACS protection (052235C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:690: BDSVM/00000.svm not found. No BD+ protection (052235C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:871: BLURAY initialized! (052235 C8) c:\dslibbluray\libbluray\src\libbluray\register.c:391: bd_psr_write(): PSR16 ( AUDIO_LANG) 0xffffff -> 0x656e67 c:\dslibbluray\libbluray\src\libbluray\register.c:391: bd_psr_write(): PSR17 ( PG_AND_SUB_LANG) 0xffffff -> 0x656e67 c:\dslibbluray\libbluray\src\libbluray\register.c:391: bd_psr_write(): PSR18 ( PSR_MENU_LANG) 0xffffff -> 0x656e67 c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr3 = 1 (0522 35C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr4 = 65535 ( 052235C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr0 = 1 (0522 35C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr1 = 255 (05 2235C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr2 = 2683740 15 (052235C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr14 = 65535 (052235C8) c:\dslibbluray\libbluray\src\libbluray\register.c:389: bd_psr_write(4, 65535): n o change in value c:\dslibbluray\libbluray\src\libbluray\bluray.c:2043: PSR write: psr4 = 65535 (0 52235C8) ERROR: transport error 202: connect failed: Connection refused ERROR: JDWP Transport dt_socket failed to initialize, TRANSPORT_INIT(510) c:\dslibbluray\libbluray\src\libbluray\register.c:389: bd_psr_write(4, 65535): n o change in value c:\dslibbluray\libbluray\src\libbluray\bluray.c:2043: PSR write: psr4 = 65535 (0 52235C8) 800 java.lang.VerifyError: (class: title.AfricanCatsXletUSA, method: h(Lbj;)Lig;)Wro ng return type in function at java.lang.Class.getConstructor0(Native Method) at org.videolan.BDJAppProxy.doLoad(Compiled Method)(BDJAppProxy.java:132 ) at org.videolan.BDJAppProxy.doInit(Compiled Method)(BDJAppProxy.java:144 ) at org.videolan.BDJAppProxy.doStart(Compiled Method)(BDJAppProxy.java:16 4) at org.videolan.BDJAppProxy.run(Compiled Method)(BDJAppProxy.java:279) at java.lang.Thread.run(Compiled Method)(Thread.java:714) at java.lang.Thread.startup(Compiled Method)(Thread.java:785) java.lang.Error: Not implemented at org.bluray.storage.StorageManager.getInstance(Compiled Method)(Storag eManager.java:25) at net.rcdb.bdlive.client.BDLiveClientXlet.u(Compiled Method)(SourceFile :2874) at net.rcdb.bdlive.client.BDLiveClientXlet.onThreadInit(Compiled Method) (SourceFile:273) at com.javelindvd.bluray.xlet.BDJXlet.run(Compiled Method)(SourceFile:18 5) at java.lang.Thread.run(Compiled Method)(Thread.java:714) at java.lang.Thread.startup(Compiled Method)(Thread.java:785) Code:
c:\dslibbluray\libbluray\src\libbluray\bluray.c:848: libbluray version 0.2.2 c:\dslibbluray\libbluray\src\libbluray\bluray.c:564: AACS/Unit_Key_RO.inf not fo und. No AACS protection (069835C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:690: BDSVM/00000.svm not found. No BD+ protection (069835C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:871: BLURAY initialized! (069835 C8) c:\dslibbluray\libbluray\src\libbluray\register.c:391: bd_psr_write(): PSR16 ( AUDIO_LANG) 0xffffff -> 0x656e67 c:\dslibbluray\libbluray\src\libbluray\register.c:391: bd_psr_write(): PSR17 ( PG_AND_SUB_LANG) 0xffffff -> 0x656e67 c:\dslibbluray\libbluray\src\libbluray\register.c:391: bd_psr_write(): PSR18 ( PSR_MENU_LANG) 0xffffff -> 0x656e67 c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr3 = 1 (0698 35C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr4 = 65535 ( 069835C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr0 = 1 (0698 35C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr1 = 255 (06 9835C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr2 = 2683740 15 (069835C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr14 = 65535 (069835C8) c:\dslibbluray\libbluray\src\libbluray\register.c:389: bd_psr_write(4, 65535): n o change in value c:\dslibbluray\libbluray\src\libbluray\bluray.c:2043: PSR write: psr4 = 65535 (0 69835C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2346: HDMV event: 7 0 c:\dslibbluray\libbluray\src\libbluray\bluray.c:2346: HDMV event: 3 17 c:\dslibbluray\libbluray\src\libbluray\register.c:391: bd_psr_write(): PSR4 ( TITLE_NUMBER) 0xffff -> 0x11 c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr4 = 17 (069 835C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2346: HDMV event: 7 0 c:\dslibbluray\libbluray\src\libbluray\bluray.c:2346: HDMV event: 4 97 c:\dslibbluray\libbluray\src\libbluray\register.c:391: bd_psr_write(): PSR6 ( PLAYLIST) 0x0 -> 0x61 c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr6 = 97 (069 835C8) c:\dslibbluray\libbluray\src\libbluray\register.c:389: bd_psr_write(3, 1): no ch ange in value c:\dslibbluray\libbluray\src\libbluray\bluray.c:2043: PSR write: psr3 = 1 (06983 5C8) c:\dslibbluray\libbluray\src\libbluray\register.c:391: bd_psr_write(): PSR5 ( CHAPTER) 0xffff -> 0x1 c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr5 = 1 (0698 35C8) c:\dslibbluray\libbluray\src\libbluray\register.c:389: bd_psr_write(7, 0): no ch ange in value c:\dslibbluray\libbluray\src\libbluray\bluray.c:2043: PSR write: psr7 = 0 (06983 5C8) c:\dslibbluray\libbluray\src\libbluray\register.c:391: bd_psr_write(): PSR8 ( TIME) 0x0 -> 0x7fff8 c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr8 = 524280 (069835C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:190: Selected stream 0 c:\dslibbluray\libbluray\src\libbluray\register.c:391: bd_psr_write(): PSR1 ( PRIMARY_AUDIO_ID) 0xff -> 0x1 c:\dslibbluray\libbluray\src\libbluray\bluray.c:2074: PSR change: psr1 = 1 (0698 35C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:190: Selected stream 0 c:\dslibbluray\libbluray\src\libbluray\register.c:389: bd_psr_write(2, 268374015 ): no change in value c:\dslibbluray\libbluray\src\libbluray\bluray.c:2043: PSR write: psr2 = 26837401 5 (069835C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:1590: Title 00097.mpls selected! (069835C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:1524: Playback rate change to 1. 000000 ! (069835C8)
