7th February 2006, 09:25 | #221 | Link | |
clueless n00b
7th February 2006, 09:29 | #222 | Link | |
7th February 2006, 13:33 | #223 | Link |
BeHappy/MeGUI developer
Maybe we can add simplest MP4 WYSWYG authoring features? No complex animation, just menus?
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
7th February 2006, 19:59 | #224 | Link | |
Does it really matter?
8th February 2006, 07:43 | #226 | Link | |||
8th February 2006, 07:49 | #227 | Link |
Also, it would be nice to have a subtitle converter (ASS,SSA to Timed Text for MP4) because a lot of devices only support timed text. The only other way I could think to do it would be to add VSFilter in the AVISynth Script Creator and do the subs that way.
8th February 2006, 07:52 | #228 | Link | ||
8th February 2006, 07:56 | #229 | Link |
ASS (Advanced SubStation Alpha) and SSA (SubStation Alpha) are advanced subtitles that have crazy effects on them. They shouldn't be too hard to parse, but I'm not a programmer. You'd pretty much just have to remove the effects (karaoke, shaking stuff) and convert the timing to ttext.
8th February 2006, 12:21 | #230 | Link | |
9th February 2006, 09:30 | #232 | Link |
Please explain....
Do you mean being able to select input from DVD Decrypter's ripped files and encode in one step? That's what the One Click Encoder (part of MeGUI) is for. Do you mean that MeGUI should run DVD Decrypter? Doom9 said no. |
10th February 2006, 04:11 | #233 | Link |
Safe / Partial Profile Switching / Loading
I would like to propose an idea I would call "Safe Profile Switching" for the lack of a better name. The idea is that some of the information that might normally be read from a profile would be retained (not overwritten) when a new profile is loaded.
This could be implemented one of two ways. One would involve an option (checkbox) on the "Settings" windows which cause certain (predefined) elements in any profile to be ignored and the current values retained. Another way would also be enabled by an option (checkbox) in the Settings windows, but rather than having a predefined set of values to be retained, whatever isn't defined in the new profile would be retained. If the predefined list idea is implemented, I would suggest that these items be retained in a video profile if the option is selected: bitrate and zones (these are the same things that won't trigger the Safe Profile Alteration feature) plus perhaps the in-loop deblocking settings. I would also suggest the SAR settings, except that they aren't used, apparently. The other idea was to retain the last value of any setting when switching profiles if that setting isn't defined in the new profile (or if it exists, but contains a value of null). As it is now, if an element is missing from a profile, the element is added back into the profile using a default value that must be hard-coded somewhere (as far as I can tell). If the element exists, but contains an empty or null value where some information is required, MeGUI refuses to load the profile at all. For this idea to work well, it would probably be necessary to distinguish between an empty and a null element in some cases (such as CustomEncoderOptions, where the user might really want to blank out something already in that field). It would also be necessary to stop writing out completely specified profiles when MeGUI shuts down (or to write null values where the value isn't determined). (MeGUI currently overwrites every profile file when it shuts down.) On the other hand, this would provide the most flexibility to the user who doesn't mind writing his / her own profiles outside MeGUI, so this is the idea I would prefer. I am concentrating on video profiles. I don't know why this couldn't be extended to the other profiles; I just havn't given it much thought. |
12th February 2006, 03:18 | #234 | Link |
Load all settings of queued job when loading queued jobs / Save profiles immediately
First let me thank the people who have worked on MeGUI. I've certainly received far more than my money's worth! I want to make it clear, because as I argue for a change below, it may come across as if I don't appreciate what has already been done. I do!!! Also, I am writing this so that people who aren't that familiar with MeGUI can figure out what I'm saying. I don't want to come across as if I'm talking down to anyone if I'm explaining something that is inherently obvious to them.
I'm only worrying about the video profiles here, but would think that this would apply to any profile. As I mentioned in the previous item (I think) MeGUI reads every profile file when it starts, and writes every profile file when it is closed. If you create or change a profile, nothing is written until meGUI closes. That leads to at least one undesirable (IMO) "feature", and possibly more. I would prefer MeGUI would write out the new/changed profile as soon as it is created or whenever the user makes changes and clicks OK. (It probably wouldn't hurt if the profile is written anytime the user clicks OK, even if there are no changes). This seems (IMO) to be the "better" way to do this. It is my personal prejudice that you should write out data as quickly as possible after the user has indicated that he has finished creating something worth writing out. Clicking "OK" in the CODEC configuration window counts, IMO. I am less concerned about MeGUI trying to read all the profiles in when it starts, even though most won't be used, but even that can cause problems. In general, as I have used MeGUI, I have assumed that there was only one video profile it was concerned with at a time (so only one profile was in its memory at a time.) I assume most users have the same mindset. One theoretical problem the current system has is that if MeGUI crashes (which I haven't experienced), any changes to the profiles (and any new profiles) would be lost. The same would happen if the operating system is shut down without giving MeGUI time to save the profiles. Another semi-theoretical problem that I may or may not have encountered unintentionally, but which I can certainly duplicate intentionally, involves two instances of MeGUI running simultaneously. If two instances of MeGUI are started and used to change profiles, neither of them can know about the changes the other is making. Which ever instance shuts down last overwrites the profiles written by the other one. I definitely have accidentally had two instances of MeGUI running simultaneously several times just because I forgot about the first instance and it was hidden behind something and I'm scatterbrained. I'm not sure if I've lost profile changes because of this, but it would be natural to close the forgotten instance once I found it, thus loosing any changes made with it once the other instance is closed. A real issue I have had (but that could fall under "Don't mess with MeGUI's files outside MeGUI, especially if you don't know what you're doing") is that I've made changes to the XML files outside MeGUI, then had the changes overwritten when MeGUI closes, even if that profile wasn't selected inside MeGUI. Personally, I think it can be easier to deal with the XML files directly sometimes, especially if you are trying to troubleshoot something. What I have have been particularly frustrated with, however, and which strikes me as a bug (but that M$soft would call a "feature", I suppose), is that it is impossible (within MeGUI) to determine the encoder settings for a queued job. One would think (and I would bet most users don't know better) that if you selected the "Queue" tab and clicked on the "Load" button, you would load all of the settings for the queued job. Then, if you clicked on the "Input" tab and clicked on the CODEC "Config" button, you would see the original encoder settings there. Not so! The encoder settings aren't loaded. What you get is the current settings of whatever profile happened to be selected. Even if the correct profile was already selected, the current settings for that profile are displayed, rather than the settings that existed when the job was queued. This could be particularly confusing, because the user probably could recognize the wrong profile, but not necessarily the wrong settings in that profile. (AFAIK, the only way to see the original settings are to look in the XML file for the queued job.) As it is, there seems to be very little benefit in clicking on the "Load" button -- yes, it loads the file names (including the full paths), but that's only two rather trivial items. At first glance, it seems that it could do much more, so I assumed it did do much more. EDIT: OK, I see I wasn't quite correct about what the load button does. First of all, MeGUI doesn't "load" anything in the conventional sense, because it loads everything in the XML files for all jobs when it starts, and rewrites them all when it closes, just as it does with the profile files. But clicking on the "Load" button does seem to set some pointers to point to the the data for the selected job. But the data remains mostly inaccessable to the user. And this leads to a problem that definately qualifies as a bug! If you create a 2-pass job in the queue, then switch to a 1-pass profile, then load the second (for example) part of the original 2-pass job, then click on the "Queue" button, you wind up creating a corrupt job that is only the second part of a 2-pass job! I filed a bug report here. Of course, it's not trivial for MeGUI to show the original settings for a queued job, because loading the settings from the queued job would overwrite the settings for the whatever profile is selected. Even ensuring the correct profile was already selected wouldn't help, because the profile might have been changed in the meantime. Then if MeGUI were closed, the settings from the old queue job would be written out in the XML file for the profile. One way around this would be to create a new, special, (temporary?) video profile, load the queued job's settings into that, and select that profile when the "Load" button is clicked. That way loading everything from a queued job wouldn't overwrite anything, and the user could see his settings. Even if MeGUI had only one profile in memory at a time and changes to profiles are immediately written when "OK" is clicked (my preference), it probably would be a good idea to change to the the profile that was originally used (if necessary) or to change the profile name to something new. The old settings wouldn't be written out unless the user clicked OK. Actually, while I'm at it, I would prefer making it be more obvious that clicking "OK" will cause profile change to be saved, or even creating three ways to leave the configuration window: 1) Save and exit, 2) OK (don't save changes to the profile file, but remember the current settings until a different profile is selected) and 3) cancel (forget all about it). That to me would allow the least amount of confusion. There really are several ideas here, but they are all interrelated. Again, I hope I don't come across as being unappreciative or as if I'm talking down to someone. That's not my intent. Last edited by Schnoodledorfer; 12th February 2006 at 06:36. |
12th February 2006, 06:46 | #235 | Link | |||||
As to re-reading profiles.... the two reasons you say you want that are manual editing of the xml files, and running two copies of MeGUI. I can see no sane reason to edit the xml files, as MeGUI gives complete control over the codec settings. Also, in my opinion, multiple copies of MeGUI should not be run, and MeGUI should check if there is another instance of it running before opening. This would be annoying for some people, though, so I'm not sure about that. I still think that it's not too hard to see whether MeGUI is running, and if you are willing to run multiple copies, you should be responsible. EDIT: Perhaps a warning saying that another copy is running, and asking if you still want to have two copies open? Quote:
The user shouldn't care when the file is written (as in, it should be hidden). As far as distribution of profiles goes, I think that a 'export profile' option might even be the right way to go, so that the user doesn't have to search through MeGUI's program files, and risk stuffing something up. Last edited by berrinam; 12th February 2006 at 07:02. |
12th February 2006, 08:44 | #236 | Link | ||||||
As far as the two instances of MeGUI running, a warning would be nice. As I said, when I've done it, it's been accidental. I can't argue with your comment about there not being a sane reason to edit the XML files, but are you sure you want to make any assumptions about MeGUI users' sanity? Quote:
I think the real advantage of a GUI like MeGUI is that it can take care of everything at first (when the user doesn't know much yet), but the user can still see what's going on, and learn a lot while using it. So it would attract people who would be intimidated by having to learn too much up front, yet who would still want to know what's going on under the hood. That describes me, and maybe I'm assuming too much to assume that there are many like me, but it seems to me that there would be. |
12th February 2006, 14:18 | #237 | Link | ||||
clueless n00b
about profile creation/deletion: I don't know which build you're using, but as it is now, when you add a profile, it's saved to your HD, and when you delete one, it's immediately deleted. This behavior has been in megui since I refactored profiles so that would be for a week now. So I guess the "saving everything at exit" can safely be removed, it's no longer needed.
12th February 2006, 18:35 | #238 | Link |
Addition of a 5th digit to all the bitrate settings. That way we can do in the 10's of MBps of video. Some people I have noticed need ore bitrate and in order to use MeGUI to do that they need one more digit.
16th February 2006, 11:39 | #239 | Link |
I'm new with MeGui, but in some encoding that I do, I found that it is not possible to have different type of audio encoding for two audio (e.g. I want to encode the first audio in 6ch mode, but the second only in stereo). I can do manually a new job for every audio-encoding, but...
The second question is the job window: is it possible to have it resizeable? Thanks damjang |
