Old 15th December 2013, 16:49   #18581  |  Link
jdobbs
Originally Posted by jbromley View Post
Hi folks, I was looking for some assistance with BD-Rebuilder...
I am attempting to shrink down some BDs that I have so I can keep them away from the kids. Most are about 30-40GB, and I want to upload them onto a central NAS, but am running out of space.
Anyhoo - I constantly get the following error message when the process has gone 50% (or thereabouts) through, ie when it has done the decoding.
CorrectMPSL error() 00009 2401.
I am using the following equipment to do this.
First the BRs are ripped straight to NAS, using AnyDVD and straight file copy, also including hidden files.
Next I have a virtual Windows 7 box, which has been installed using proper software, and has nothing else on apart from BD Rebuilder and required decoders. If I run INSPECT everything comes up ok.
I am using a second drive space of 80GB, which appears to be fine, for my Workfiles.
I've now tried about 10 different blu-rays, all to no avail...
Latest log file enclosed...
That error is an indicator of a subscript being out of range, the 2401 identifies the section of BD-RB where the error occurred. I looked at it, and it is a very small section of code. The only way I can see that error occurring is if the playlist has been modified somehow or has been deleted between the time the encodes were started and the rebuild began. I'm not sure how that would be possible -- but it might somehow be related to the availability of the NAS drive.
Also, 80GB is a very small space to use as your workdrive. It is likely that at some point you are going to hit an error due to no disc space being available.
Website: www.jdobbs.net
Old 15th December 2013, 17:10   #18582  |  Link
jbromley
feedback on error
Okay, hmmm, interesting thoughts. I've looked at that error link before, but there doesn't seem to be a conclusion to it.
I'm only using 80GB, as I have limited data storage on the virtual device. I will just try something else on the VM and make it a thick client.
As to whether the original files are being changed, I find that unlikely, as they're not being used by anything else, and what other program would be changing the files? Admittedly it does take 5+ hours (usually 10) to do the first 1/2 of decoding.
Otherwise, any ideas?
I'm just trying another rip direct from the BD player, but this isn't really practical for a final solution, as the BD drive is on a laptop that is constantly moving around, and can't be kept on all the time.
jbromley is offline   Reply With Quote
Old 15th December 2013, 17:27   #18583  |  Link
jdobbs
I looked at the link, but I didn't see the connection. As for the error -- while there could be any of many possible causes, I don't see how it could be caused by a bug in BD-RB. It is simply trying to access an array that was created from the first scan of an MPLS file using an index it pulled from that same file later. I could be missing something (it wouldn't be the first time). But there are only about 25 lines of code in section 2401.
Old 15th December 2013, 18:52   #18584  |  Link
Audiophile1178
jbromley, I'm not sure if this is related to what you're trying to do but one time I tried to use the source and working path for BDRebuilder through the network as I was low on space on my local rig at that time and BDRebuilder wouldn't work properly. I think it was due to not being able to access the files properly as I was doing the encoding on my main rig but using my network drives as the space for the work that were on another pc in the network What I didn't think of at the time and this idea MAY work for you. If you want to use your network drives to do the work but use another pc for encoding you might want to try mapping the remote drives on your encoding rig to have BDRebuilder think that those drives are local as windows explorer will show that drive as a local drive with a drive letter. You would then use those mapped drives as your source and encoding folders.
It's just an idea that may or may not help you accomplish what you're trying to do.
Audiophile1178 is offline   Reply With Quote
Old 15th December 2013, 21:59   #18585  |  Link
gonca
Originally Posted by gonca View Post
dfsooner had the same error
gonca is offline   Reply With Quote
Old 16th December 2013, 00:04   #18586  |  Link
jbromley
Thanks, I may well try that. I'm just moving my virtual systems to a much bigger server, so if it works that will solve that, also for the past 7 hours I've been trying to do the whole thing from a local machine, and also with the bd files copied to a local drive.
Old 16th December 2013, 00:19   #18587  |  Link
jdobbs
Oh, so the link pointed to the wrong post, you are referencing the post that was 4 responses below that one. I see.
In his case, this was his response on the next page.
Old 16th December 2013, 00:32   #18588  |  Link
gonca
I was linking to the page
Just saw how to link to an actual post
Old 16th December 2013, 08:37   #18589  |  Link
AmigaFuture
AmigaFuture's Avatar
Originally Posted by laserfan View Post
Wow, make us all feel bad!
Donations are especially appropriate as IIRC BD-RB celebrates its fifth anniversary this month! Longest beta trial in history maybe (calling Guinness right now...).
Hmm...Nope. It doesn't ...make...me feel bad. I am supposed to be included in that "All" statement? Wink! Even if I hadn't donated in that $ range??
It's all part his Master Plan for major fame...longest Beta in history. We're on to you.....!!!
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!!
AmigaFuture is offline   Reply With Quote
Old 16th December 2013, 08:53   #18590  |  Link
AmigaFuture
[12/15/13] BD Rebuilder v0.45.05 (beta)
[10:14:25] Source:  HANNA
  - Input BD size: 38.87 GB
  - Approximate total content: [02:44:25.521]
  - Target BD size: 22.95 GB
  - Windows Version: 6.1 [7600]
  - Auto Quality: Good (Very Fast), ABR
  - Decoding/Frame serving: DirectShow
  - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
[10:14:25] PHASE ONE, Encoding
 - [10:14:25] Processing: VID_50201 (1 of 11)
 - [10:14:25] Extracting A/V streams [VID_50201]
 - [10:39:43] Reencoding video [VID_50201]
   - Rate/Length: 23.976fps, 159,730 frames
   - Bitrate: 19,256 Kbs
 - [10:39:43] Reencoding: VID_50201, Pass 1 of 1
 - [13:10:56] Video Encode complete
 - [13:10:56] Processing audio tracks
 - [13:10:56] Multiplexing M2TS
 - [13:28:52] Processing: VID_50278 (2 of 11)
 - [13:28:52] Extracting A/V streams [VID_50278]
 - [13:29:03] Reencoding video [VID_50278]
   - Source Video: VC-1, 1920x1080
   - Rate/Length: 23.976fps, 1,748 frames
   - Bitrate: 5,358 Kbs
 - [13:29:03] Reencoding: VID_50278, Pass 1 of 1
 - [13:30:15] Video Encode complete
 - [13:30:15] Processing audio tracks
 - [13:30:15] Multiplexing M2TS
 - [13:30:20] Processing: VID_50283 (3 of 11)
 - [13:30:20] Extracting A/V streams [VID_50283]
 - [13:30:33] Reencoding video [VID_50283]
   - Rate/Length: 23.976fps, 2,247 frames
   - Bitrate: 6,130 Kbs
 - [13:30:34] Reencoding: VID_50283, Pass 1 of 1
 - [13:32:02] Video Encode complete
 - [13:32:02] Processing audio tracks
 - [13:32:02] Multiplexing M2TS
 - [13:32:07] Processing: VID_50285 (4 of 11)
 - [13:32:07] Extracting A/V streams [VID_50285]
 - [13:32:27] Reencoding video [VID_50285]
   - Rate/Length: 23.976fps, 2,112 frames
   - Bitrate: 13,367 Kbs
 - [13:32:27] Reencoding: VID_50285, Pass 1 of 1
 - [13:33:56] Video Encode complete
 - [13:33:56] Processing audio tracks
 - [13:33:56] Multiplexing M2TS
 - [13:34:02] Processing: VID_50286 (5 of 11)
 - [13:34:02] Extracting A/V streams [VID_50286]
 - [13:34:44] Reencoding video [VID_50286]
   - Rate/Length: 23.976fps, 5,440 frames
   - Bitrate: 13,397 Kbs
 - [13:34:44] Reencoding: VID_50286, Pass 1 of 1
 - [13:38:39] Video Encode complete
 - [13:38:39] Processing audio tracks
 - [13:38:39] Multiplexing M2TS
 - [13:38:49] Processing: VID_50287 (6 of 11)
 - [13:38:49] Extracting A/V streams [VID_50287]
 - [13:41:50] Reencoding video [VID_50287]
   - Rate/Length: 23.976fps, 19,080 frames
   - Bitrate: 13,321 Kbs
 - [13:41:50] Reencoding: VID_50287, Pass 1 of 1
 - [13:56:58] Video Encode complete
 - [13:56:58] Processing audio tracks
 - [13:56:58] Multiplexing M2TS
 - [13:57:39] Processing: VID_50288 (7 of 11)
 - [13:57:39] Extracting A/V streams [VID_50288]
 - [13:59:25] Reencoding video [VID_50288]
   - Rate/Length: 23.976fps, 12,821 frames
 - [13:59:25] Reencoding: VID_50288, Pass 1 of 1
 - [14:08:26] Video Encode complete
 - [14:08:26] Processing audio tracks
 - [14:08:26] Multiplexing M2TS
 - [14:08:50] Processing: VID_50289 (8 of 11)
 - [14:08:50] Extracting A/V streams [VID_50289]
 - [14:10:04] Reencoding video [VID_50289]
   - Rate/Length: 23.976fps, 8,789 frames
   - Bitrate: 13,319 Kbs
 - [14:10:04] Reencoding: VID_50289, Pass 1 of 1
 - [14:16:32] Video Encode complete
 - [14:16:32] Processing audio tracks
 - [14:16:32] Multiplexing M2TS
 - [14:16:43] Processing: VID_50290 (9 of 11)
 - [14:16:43] Extracting A/V streams [VID_50290]
 - [14:17:03] Reencoding video [VID_50290]
   - Rate/Length: 23.976fps, 4,576 frames
   - Bitrate: 13,333 Kbs
 - [14:17:03] Reencoding: VID_50290, Pass 1 of 1
 - [14:20:30] Video Encode complete
 - [14:20:30] Processing audio tracks
 - [14:20:30] Multiplexing M2TS
 - [14:20:40] Processing: VID_50291 (10 of 11)
 - [14:20:40] Extracting A/V streams [VID_50291]
 - [14:21:00] Reencoding video [VID_50291]
   - Rate/Length: 23.976fps, 3,168 frames
   - Bitrate: 13,317 Kbs
 - [14:21:00] Reencoding: VID_50291, Pass 1 of 1
 - [14:23:23] Video Encode complete
 - [14:23:23] Processing audio tracks
 - [14:23:23] Multiplexing M2TS
 - [14:23:30] Processing: VID_50292 (11 of 11)
 - [14:23:30] Extracting A/V streams [VID_50292]
 - [14:23:46] Reencoding video [VID_50292]
   - Rate/Length: 23.976fps, 2,132 frames
   - Bitrate: 13,287 Kbs
 - [14:23:46] Reencoding: VID_50292, Pass 1 of 1
 - [14:25:20] Video Encode complete
 - [14:25:20] Processing audio tracks
 - [14:25:20] Multiplexing M2TS
[14:25:25]PHASE ONE complete
[14:25:25]PHASE TWO - Rebuild Started
 - [14:25:25] Rebuilding BD file Structure
 - [14:25:28] CorrectMPLS() 00009  2401
[14:37:39] - Aborted per user request
Are you using a Mac using VMWare Fusion or Parallels? If so, which Mac OS X version? I may be able to help as I've come across that before.
Old 17th December 2013, 19:07   #18591  |  Link
TobiMan
when trying to import a .ts file into bd-rebuilder the log shows the following error:
[18:21:31] Importing TS: NUHR_2013_-_DER_JAHRESRÜCKBLICK
- Preparing TS for processing...
[18:24:34]ERROR: Gathering source file information. Aborted.
[18:24:35]ERROR: Gathering source file information. Aborted.
- Collecting audio/video streams from source...
The file was recorded from TV and has the following specs:
h264, 50 FPS progressive, 1280x720
AC3 2.0, 48 KHz, 448 kBit
Any idea why this happens and how to get it working (inspect.exe shows no errror)?
Thanks,
Tobi
TobiMan is offline   Reply With Quote
Old 17th December 2013, 19:12   #18592  |  Link
jdobbs
Originally Posted by TobiMan View Post
Thanks,
Tobi
That error occurs when BD-RB attempts to run MEDIAINFO against your source and the application returns an error. You might try running it manually and see what happens (MEDIAINFO.EXE can be found in the BD-RB TOOLS folder).
Old 17th December 2013, 19:47   #18593  |  Link
TobiMan
Thanks for pointing me out. Mediainfo showed more detailed information but no error. However, somehow I got the idea to shorten the filename and everything is fine now.
So my guess is either long filenames and/or spaces in filenames caused the issue. I will try later to find out as I am encoding right now ;-).
Thanks again
Tobi
Old 17th December 2013, 20:36   #18594  |  Link
nounours18200
As said in the very firstpost, the first time BD Rebuilder is lauched, there is a message to change the Codec in the Windows Ragistry.
Is there any risk that this change disturb the other programs installed in the PC ?
Tks
nounours18200 is offline   Reply With Quote
Old 17th December 2013, 21:03   #18595  |  Link
TobiMan
OK, I guessed wrong. The issue was because of German Umlauts (i. e. ä ö ü). Now that I know it is no problem to avoid this.
Thanks again!
Tobi
Old 17th December 2013, 22:45   #18596  |  Link
jdobbs
Tks
No, it shouldn't. It changes the default Directshow CODECs for VC-1, MPEG-2, and AVC to those found in FFDSHOW. The Directshow interface has been standardized, and if other programs access Directshow, these CODECs will work with them.
Old 18th December 2013, 02:34   #18597  |  Link
MrT.
Hi
thank you for your works on bdrb
I was wondering if there were other reasons for the video to freeze, but audio/subtitles to continue? With the common reason being a bad rip, some sort of video glitch.
At first this common reason was sound, for me. I tried doing planes, trains and automobiles and I saw a , maybe a .3-5 seconds freeze before scene change, and the re encode got stuck on that the rest of way. But then it has happened to me again with The right stuff. And with that latest one the Original video looks fine. I did a newer title recently and no issues.
I was just wondering if there was something I could do to look into it.
I recently did a fresh install, everything updated and configured.
A log would not shed light on this I believe? I mean..bd-rb finished the shrink to bd25 as per normal. No errors.
Maybe this is just a coincidence? maybe viewing the original video for glitches does not tell all and theres something wrong with the rip.
thank you for any insight.
MrT. is offline   Reply With Quote
Old 18th December 2013, 02:48   #18598  |  Link
jdobbs
Originally Posted by MrT. View Post
Hi
The only idea I have is that somehow the video did not complete encoding correctly. That would typically be because of a corrupt source.
Old 18th December 2013, 04:25   #18599  |  Link
SFiedor
Rodiefs
SFiedor's Avatar
Can't open file errors
First I want to say what a wonderful job you are doing on BD-Rebuilder!
I'm wondering if someone can help me. I just tried to backup the Season 1 BDs for the original Star Trek TV Series. On Season 1 Disk 2, I am trying to backup track 00010 using the "Other movie-only playlist" under the mode tab. It completes Phase 1 and when Phase 2 starts it comes back with the following error:
18:43:48]PHASE TWO - Rebuild Started
- [18:43:48] Rebuilding BD file Structure
- Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta
- Can't open file: D:\MULTIMEDIA FILES\TEMP\E5\WORKFILES\00075.track_4352.DTS
[18:43:51] - Failed to REBUILD
A similar error is also happening with track 00002 of the Season 1 Disc 3 Star Trek TV series. (Season 1 Disk 1 episodes backed up just fine).
Now if I take the two (Disk 2 and 3) BD rips and do a full backup of them - BD-Rebuilder backs up the rips successfully. I can also drag the 00010.mpls file or Disk 2 and the 00002.mpls file of disk 3 from their BD Playlist Rip folder to MPC and it plays fine.
I'm ripping the BDs to the hard drive using the latest version of AnyDVD HD. I'm just using BD-Rebuilder to strip away unwanted languages, subtitles, warning messages and previews, extras etc.
I'm not doing any compression on my BD-Rebuilder backups but I am backing up using the movie-only backup option to the hard drive. I've tried these backups on two different Windows 7 64-bit Ultimate machines with the same two errors when using BD-Rebuilder V0.45.05.
I've backed up several hundred BD movies using these settings with virtually no problems. But this is the first time that I tried backing-up TV BDs and by episode. I figured that 2 errors on 3 BDs seemed worth mentioning.
Any thoughts?
Attached is the log and BD-Rebuilder config files as well.
File Type: txt Star Trek Original TV series S1D2 track 00010 problem.txt (26.6 KB, 34 views)
File Type: txt BD-rebuilder Config.txt (805 Bytes, 39 views)
SFiedor is offline   Reply With Quote
Old 18th December 2013, 13:55   #18600  |  Link
jdobbs
Any thoughts?
The name of the file indicates that it is being kept intact -- and is the result of a simple extraction. But somehow at a point somewhere between extraction and rebuild the file has gone missing.
Why not just use the IMPORT function?
