#61201 | Link | |
What happens if in both players, instead of using the internal audio renderers, you manually select the DirectSound audio device (Topping?) ? Do the frame drops stop then? I know this is not what you want, but it's to find out if the audio renderer is the cause.
HTPC: Windows 10 1909, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti |
#61202 | Link |
thank you so much. Everything works as you thought.
I changed the audio renderer: ![]() now MHC-BE is perfect: ![]() I never thought madVR would get swayed by audio. I'm afraid there are no solutions. I would prefer to select "MPC AUDIO RENDERER" but it is not possible. MPC-HC with its internal audio Renderer is no problem. MPC-BE only Thanks everyone for the help, much appreciated.
TV:LG B9 65 Amplifier: Denon X4500H Front Speakers: n. 3 XTZ Cinema M6 Subwoofer: XTZ 10.17 EDGE Atmos Speakers:n. 4 XTZ S2 Surround Speakers: n. 2 XTZ Spirit 2 - HTPC: Fractal Meshify C-RX 5700 XT Last edited by senzaparole; 12th January 2021 at 23:35. |
#61203 | Link | |
Wouldn't hurt to try the releases here download the standalone filters packages (x64) and register it in the system it will then come up as another audio output that you can select in the drop down, then test and see if you can find a version that works without dropping frames. Last edited by ryrynz; 13th January 2021 at 01:14. |
#61204 | Link |
MadVR 3d
Hello, I've been using lav filters and Madvr for 3d for 4 or 5 years now with no issues. About a week ago, it stopped working. Anyone know anything about this? I've reinstalled madvr and lav and still it doesn't work, when it does flip into 3d, its like the 3d is in slow motion. I thought it might be my hdmi to ethernet converters screwing something up so I connected the computer to my spare projector with straight HDMI and it did the same thing. I thought it was one specific file as we had literally watched 3d the day before and then realized it was all of them. Anyone have any ideas? I'm thinking a windows 10 update maybe or something broke it. Its a windows 10 machine with I3 processor Skylake with internal intel graphics.
#61205 | Link |
Impossible to say without more information, things do not break like that by themselves.
Under "View update history" in Windows Update settings, you can see exactly what date Windows installed updates, and also uninstall them. Maybe check that. Maybe it installed a new graphics driver?
#61206 | Link | |
#61207 | Link |
When you say "previous version", was it a monthly ("quality") update, or a full new release ("feature update")? Can you give the two versions before/after the update?
#61208 | Link | |
@ryrynz I solved the problem!!!!! In the MPC Audio Renderer settings it was enough to change the DEVICE BUFFER from 50 ms to DEFAULT! Now I don't lose frames anymore and madVR's OSD is perfect! Thanks for your help!
TV:LG B9 65 Amplifier: Denon X4500H Front Speakers: n. 3 XTZ Cinema M6 Subwoofer: XTZ 10.17 EDGE Atmos Speakers:n. 4 XTZ S2 Surround Speakers: n. 2 XTZ Spirit 2 - HTPC: Fractal Meshify C-RX 5700 XT |
#61210 | Link |
Regarding the screenshot of madVR info - how did you manage to almost set / sync display Hz to video Hz ? Setting the TV to 23 or 24Hz would that suffice? Appreciated
HTPC Build : 8700k / 16GB DDR4 / 1080Ti GPU - Setup for FullHD / 4K MKV Playback - PotPlayer + madVR Display #1 - 32GK850G Display #2 - Sony 49XF9005 (ISF Calibrated) |
#61212 | Link |
I have just downloaded beta 120, is there a way to copy HDR settings for different devices. I want to use the same settings, changing only DPL values. I don't know how to do that. Hopefully somebody can help me, thanks a lot to all of you |
#61213 | Link |
@webbo - That's AMD
Henry LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2 NVIDIA GeForce GTX 960 | LAV Filters | madVR | MPC-HC | Plex | X-Rite i1Display Pro | DisplayCAL | HCFR |
#61214 | Link |
Hello! It is madVR that changes the TV refresh rate adapting it to the native one of the movie.
#61217 | Link |
Is madVR or the video driver responsible for the depth information in 1080p 3D frame packed output? I found at least one of my 3D BD's when ripped to .mkv and played back from the PC has intermittent odd depth shifts (like the image will jump forward or backward a bit mid scene). The jumps aren't there when the 3D BD is played from a Blu-ray player.
#61218 | Link |
Hi everyone.
So I got a new LG CX OLED and I have this issue with subtitles using MPC-HC with MadVR : - with the internal subtitle renderer, no problem with .ass subtitles (I can change their look) but in HDR, subtitles stay bright white whatever my changes - with xySubFilter, .ass subtitles are out of whack (generally looking extemely small) but I can change the color of HDR subtitles - with DirectVOBsub, any subtitle in SDR is easy to set up as I want, but then MPC-HC doesn't output in HDR (I guess since DirectVOBsub is not part pf MadVR) Does anyone know the settings to be able to set the color of subtitles to light gray and with whatever font and size I want, whatever the resolution of the content and whether it is SDR or HDR? Thanks |
#61219 | Link |
Do you have issue with ass subs only? If so, upload it somwhwere.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
#61220 | Link | |
I was wondering if you ran into any favorable results in trying to figure this out. Ive been trying to accomplish this all month. |
