Old 14th September 2018, 17:25   #16081  |  Link
Danette
Why don't you use build in QTGMC in ripbot264?
I just happened to pick QTGMC as an example. I have other custom script that I use as well.
Your script doesn't work because you most likely forgot to load all needed plugins used by that script
Loadplugin("C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\AviSynth plugins\RgTools\RgTools.dll")
Loadplugin("C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\AviSynth plugins\nnedi3\nnedi3.dll")
Loadplugin("C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\AviSynth plugins\masktools\masktools2.dll")
Loadplugin("C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\AviSynth plugins\mvtools\mvtools2.dll")
LoadCplugin("C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\AviSynth plugins\Yadif\Yadif.dll")
This didn't work either. If I'm not mistaken, the QTGMC avsi file should pull in all of those plugins, without having to call them independently. For example; using the problem script:
Import("C:\Program Files (x86)\AviSynth+\plugins\QTGMC-3.32.avsi")
video=AssumeTFF(video)
video=QTGMC(video,Preset="Very Slow")
worked in older RipBot264 versions (1.19) and also works in MeGUI without specifying the supporting plugins, even though it doesn’t work in 1.23.
I have tried other script, such as Bordercontrol, with same failure pattern.
Essentially, there appears to be no custom script that can be called, from outside of ripbot264, that will work in version 1.23.
Danette is offline   Reply With Quote
Old 14th September 2018, 17:39   #16082  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
AviSynth should return some error message. Use that as clue.
PS. Are you sure you are using 64 bit filters?
Old 14th September 2018, 18:47   #16083  |  Link
Danette
The only error message occurs when I try to run the job with the script. Then I get the RipBot264 error message:
"The type of file 'C:\Temp\RipBot264temp\video.264' could not be recognized."
When I open that video.264 file, it's empty.
If it's referring to the source video, that same source video runs fine when the Avisynth script isn't applied.
In the case of the QTGMC example, I loaded the plugins contained in RipBot264. So, here is how it looks:
LoadPlugin("C:\Users\Main\Desktop\RipBot264 v1.23.0.7\Tools\AviSynth plugins\RgTools\RgTools.dll")
LoadPlugin("C:\Users\Main\Desktop\RipBot264 v1.23.0.7\Tools\AviSynth plugins\nnedi3s\nnedi3.dll")
LoadPlugin("C:\Users\Main\Desktop\RipBot264 v1.23.0.7\Tools\AviSynth plugins\masktools\masktools2.dll")
LoadPlugin("C:\Users\Main\Desktop\RipBot264 v1.23.0.7\Tools\AviSynth plugins\mvtools\mvtools2.dll")
LoadPlugin("C:\Users\Main\Desktop\RipBot264 v1.23.0.7\Tools\AviSynth plugins\mvtools\yadif.dll")
As always, the job fails immediately with the error message. Preview window also doesn't show the preview.
Old 15th September 2018, 02:37   #16084  |  Link
byteshare
ByteShare
byteshare's Avatar
Would you post your full script from the Edit > AviSynth > Show Video Script
And the error message from the "Preview Script" from the same location
Old 15th September 2018, 02:44   #16085  |  Link
byteshare
ByteShare
byteshare's Avatar
VideoPreview/Crop Issue
I'm having an issue with previewing the video so I can select the crop since the autocrop is likely failing for the same reason:
Video mediainfo:
General
Complete name               : C:\ReEncode\Crop\Queen Millennia 01x01 A World Turned Upside Down [Village Video] [ENG Dub].mpg
Format                      : MPEG-PS
File size                   : 379 MiB
Duration                    : 21 min 45 s
Overall bit rate mode       : Variable
Overall bit rate            : 2 438 kb/s
Writing library             : encoded by TMPGEnc (ver. 2.59.47.155)
Video
Format                      : MPEG Video
Format version              : Version 2
Format profile              : Main@Main
Format settings             : CustomMatrix / BVOP
Format settings, BVOP       : Yes
Format settings, Matrix     : Custom
Format settings, GOP        : M=3, N=16
Format settings, picture st : Frame
Bit rate mode               : Variable
Bit rate                    : 2 005 kb/s
Maximum bit rate            : 8 000 kb/s
Width                       : 352 pixels
Height                      : 480 pixels
Display aspect ratio        : 4:3
Frame rate                  : 29.970 (30000/1001) FPS
Standard                    : NTSC
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 8 bits
Scan type                   : Interlaced
Scan order                  : Bottom Field First
Compression mode            : Lossy
Bits/(Pixel*Frame)          : 0.396
Time code of first frame    : 00:00:00:00
Time code source            : Group of pictures header
GOP, Open/Closed            : Closed
Stream size                 : 312 MiB (82%)
Writing library             : TMPGEnc 2.59.47.155
Color primaries             : BT.601 PAL
Transfer characteristics    : BT.470 System B/G
Matrix coefficients         : FCC 73.682
Audio
Format                      : MPEG Audio
Format version              : Version 1
Format profile              : Layer 2
Bit rate mode               : Constant
Bit rate                    : 384 kb/s
Channel(s)                  : 2 channels
Sampling rate               : 48.0 kHz
Frame rate                  : 41.667 FPS (1152 SPF)
Stream size                 : 59.7 MiB (16%)
If I try to get a new frame I get the same result. The video plays fine (although needs to be cropped) with VLC and MPC-HC
A sample of the file: https://mega.nz/#F!lkhm2ARL!vuCAnj9Kpy_tEVDU_RnTvQ
Old 15th September 2018, 06:00   #16086  |  Link
burt123
burt123's Avatar
Hey byteshare,
I remember this green screen thing being discussed quite some time ago..
Maybe this might help...and maybe a couple of the other posts.
https://forum.doom9.org/showpost.php...ostcount=15375
burt123 is offline   Reply With Quote
Old 15th September 2018, 07:42   #16087  |  Link
byteshare
ByteShare
byteshare's Avatar
Originally Posted by burt123 View Post
Hey byteshare,
Tried that, looks normal. Also, I don't get the green preview on other files. You can try loading the test clip and I'm guessing you'll get the green preview as well. I posted a link (~8MB) in the post about the issue.
Old 15th September 2018, 09:48   #16088  |  Link
Atak_Snajpera
Works fine on Windows 7
Old 15th September 2018, 12:46   #16089  |  Link
burt123
burt123's Avatar
Hi again,
Got your sample, and same result as Atak, on W7, but will try it on W10 tomorrow.
But how about you try a quick encode, and see if once it's been thru Ripbot, that it might get rid of the green screen.
I did an "Automatic" cropping setting, and used SD-NTSC 720x480, and it turned out just a little different size to original.
Old 15th September 2018, 16:13   #16090  |  Link
Danette
There is no error indicatedwhen the "Preview Script" is opened. It simply opens to a normal-sized MPC for a split second and then the MPC window collapses into a very wide, but short, shape with no image.
Here is the script from the "Show Video Script" section:
#MT
Import("C:\Users\Main\Desktop\RipBot264 v1.23.0.7\Tools\AviSynth plugins\Scripts\MTmodes.avs")
#PREFETCH_LIMIT=0
#VideoSource
LoadPlugin("C:\Users\Main\Desktop\RipBot264 v1.23.0.7\Tools\dgindex\DGDecode.dll")
video=MPEG2Source("C:\Temp\RipBot264temp\job1\job1.d2v")
#Deinterlace
Import("C:\Users\Main\Desktop\RipBot264 v1.23.0.7\Tools\AviSynth plugins\Scripts\QTGMC-3.32.avsi")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins\RgTools.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins\nnedi3.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins\masktools2.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins\mvtools2.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins\yadif.dll")
#Decimate
#Crop
#Resize
#Tonemap
#Levels
#Colours
#Denoise
#Custom
#Prefetch
video=Prefetch(video,4)
#Subtitles
#AudioSource
Import("C:\Temp\RipBot264temp\job1\job1_a1.avs")
#Triming
#AVSameLength
#ColorSpace
#Return
return video
Old 16th September 2018, 02:19   #16091  |  Link
burt123
burt123's Avatar
Hi again,
Hey byteshare,
So, I have tested this on my Windows 10 (1803) PC, and it's fine, no green screen here.
So you're going to have to dig a little deeper, my friend.
Old 16th September 2018, 15:03   #16092  |  Link
Ryushin
Minor Quibble
When selecting x265 and it is an HDR source, it always defaults to enabling the tonemap function. Can the default be changed to leave the BT2020 colorspace instead of converting to BT709?
Ryushin is offline   Reply With Quote
Old 17th September 2018, 09:07   #16093  |  Link
byteshare
ByteShare
byteshare's Avatar
Confirmed the problem is with the original container (.mpg) when I re-mux to mkv with MKVToolNix I don't get the issue.
Update: Tested all 27 files with this issue after batch re-muxing them to MKV from MPG and they are displaying correctly
Old 17th September 2018, 09:10   #16094  |  Link
byteshare
ByteShare
byteshare's Avatar
Try clicking in the seek bar and then clicking play for the error message
Old 18th September 2018, 05:51   #16095  |  Link
Shrekage
Hi.
Is there any possibility to have the PC name be in the encoding status instead of the IP address? unless I see the "starting..." which displays the name, It is hard to keep up with 16 server IP addressees that keep changing.
Shrekage is offline   Reply With Quote
Old 18th September 2018, 08:46   #16096  |  Link
byteshare
ByteShare
byteshare's Avatar
With the official EncodingServer 1.12.1.0 I'm no longer getting a server stuck on starting an encode but I am getting it stuck while encoding now:
I also figured out why 1.12.1.0 wouldn't start on one PC. Had something to do with Windows update. After running Windows update, which I hadn't done in a while, it opens without issue now.
Old 18th September 2018, 11:23   #16097  |  Link
burt123
burt123's Avatar
Hi byteshare,
That screenshot is massive....
I have to agree with you, I have had a couple stall, but they have been on the server, not the client (if that makes any difference).
Oh, btw, do you have any problems stopping that server, so another can take over ???
But it's a whole LOT better
Old 18th September 2018, 11:30   #16098  |  Link
Atak_Snajpera
I think that this time problem might be on your side. Before releasing I've tested new encoding server (1.12.1) on virtual machine (win10) using 16 running server (extreme stress test) many times. I have never experienced this kind of issues. Well to be honest I haven't noticed any problems at all. At this point I can only advise you to check what is happening under the hood. Open Process Hacker and check if ffmpeg.exe or/and x265_x65.exe is still in memory. I suspect that ffmpeg.exe just died and stopped serving frames to an encoder.
Old 18th September 2018, 11:51   #16099  |  Link
HehoChef
x265 anomalies
Hey guys,
I'm new to the party, acquired a capable Drive and am know ripping, remuxing and partially compressing my BluRays and UHD's.
Thanks to RipBot and distributed encoding, x265 is now feasable for normal people as well.
I'm just baffled by the results im getting:
The resulting Bitrate while having an constant CQ vastly differentiates with the preset.
For example, i reencoded the first 20 Minutes of a 4K remux, @ 3840x1608, keeping 10bit and HDR, assuming that this should be x265 strongest disciplin, with the following results:
-cq 17, slower :20,2MBps
-cq 17, default: 14,5MBps
-cq 17 ultrafast: 4,6MBps
Of course they look very different.
I redid the same thing with Handbrake, yielding similar results.
Shouldn't cq encoding always keep the same visual quality, and the slower speeds allow for better compression, meaning that the tendency should be the other way around. At least thats the way it was with x264.
Maybe someone could give me a rundown of what I'm not understanding, or respectively what I'm dowing wrong.
Thanks a lot
HehoChef is offline   Reply With Quote
Old 18th September 2018, 12:05   #16100  |  Link
byteshare
ByteShare
byteshare's Avatar
Hi byteshare,
No, not usually
