2nd January 2015, 18:20 | #12905 | Link |
Pig on the wing
It's not the most efficient way (if you mean quality-wise). I personally use Apple's AAC codec for all my stuff, you can search for 'qaac' if you're interested. There's a big thread at hydrogenaud.io but probably something here as well.
2nd January 2015, 18:23 | #12906 | Link | |
EDIT : Also is there a list of AAC encodes with their comparisions ? nvm got it Last edited by Hitesh12; 2nd January 2015 at 18:28. Reason: 'how' missing |
2nd January 2015, 18:28 | #12908 | Link | |
Pig on the wing
2nd January 2015, 18:29 | #12909 | Link |
Pig on the wing
I think it can only work if you remux the whole Blu-ray folder and thus cannot choose what you mux or re-encode and then mux. At least that's what the example in the first post by madshi shows.
2nd January 2015, 18:31 | #12910 | Link | |
eac3to input.mkv 2: audio.dts 2: audio.flac Is there some other command to mux these ? |
2nd January 2015, 18:38 | #12911 | Link |
Thanks !
Another query () - AFAIK there are different DTS codecs (DTS, DTS-HD I think) So when I select .dts as output format, which DTS is it referring to ? Also how do I check which DTS codec does the file has ? I don't think mediainfo differentiates between different DTS codecs |
2nd January 2015, 18:41 | #12912 | Link |
Pig on the wing
If you don't have a DTS encoder installed and you don't specify -core, you get DTS-HD if the original track is such. Otherwise you get a regular DTS track. I don't know if there is a simple way to determine which is which other than using eac3to
2nd January 2015, 18:48 | #12913 | Link | |
Thanks for all the help |
2nd January 2015, 19:05 | #12914 | Link |
This is a very odd question but how do I access file in some other directory ?
Currently I'm moving files which I want to encode in the eac3to directory (Only then this works - eac3to input.mkv output.whatever) , which is not the correct way |
2nd January 2015, 19:22 | #12916 | Link |
Pig on the wing
It seems you first need to learn the basics of command line stuff. You might be better off using some GUI for eac3to such as the one here: http://forum.doom9.org/showthread.php?t=145574
2nd January 2015, 19:43 | #12917 | Link | |
"C:\Program Files (x86)\eac3to\eac3to.exe" "H:\my video.m2ts" 2: "P:\my video sound.ac3" |
2nd January 2015, 19:56 | #12918 | Link | |
"C:\Program Files (x86)\eac3to\eac3to.exe" "H:\my audio.ac3" stdout.wav | "C:\Program Files (x86)\neroAacEnc\neroAacEnc.exe" -q 0.4 -if - -of "P:\my audio.mp4" -q is for quality, 1 is the maximum. Other example with extraction from m2ts and downmix ; Code:
"C:\Program Files (x86)\eac3to\eac3to.exe" "H:\my file ac3 5.1.m2ts" 2: stdout.wav -downStereo | "C:\Program Files (x86)\neroAacEnc\neroAacEnc.exe" -q 0.65 -if - -of "P:\my file (only sound) aac 2.0.mp4" Last edited by Music Fan; 2nd January 2015 at 20:22. |
5th January 2015, 04:24 | #12919 | Link |
I'm having a problem with eac3to. I can't seem to extract the DTS-HD master audio from a BD. I can rip the BD then make an MKV then extract the audio but I can't seem to do it from my original source. I keep getting an error that says eac3to can't open the source file. eac3to gets to the end of it's 3rd Pass before giving me this error in the log.
What are some things I can do to troubleshoot? I've been using eac3to successfully for many years until recently. Recent rips of Stargate and Divergent are giving me trouble. Before that, no problems. Last edited by agogley; 5th January 2015 at 04:28. |
eac3to |
