8th December 2017, 20:02 | #47621 | Link |
No, a 1070 would not be enough for the "best" settings. A 1080 Ti is just enough for almost the best settings as long as you don't use too many enhancements and/or artifact removal options.
madVR options explained |
8th December 2017, 20:08 | #47622 | Link | |
What would it take to upscale 720p based on your settings.bin? |
8th December 2017, 21:27 | #47623 | Link |
720 is probably one of the hardest modes (when going to 4K) in my settings.bin. It probably needs a full 1080 Ti, but hopefully one without an overclock or power target increase. My Titan X, with the same number of cores, can run all my settings at stock.. but 720p might need an increase to the power limit.
8th December 2017, 23:30 | #47624 | Link | |
Windowed mode works perfect |
8th December 2017, 23:56 | #47628 | Link | |
FSE has to be on for me or I get no MVC 3D. |
9th December 2017, 00:05 | #47629 | Link |
i fixed the black screen issue, its not KODI DS or MADVR,...what was happening was when I pressed x on my remote to stop it would stop but also minimise to desktop, my desktop is black and my start menu hidden, hence the black screen. I think this was actually a problem with my AUTOHOTKEY script, I had a key mapped to that, bizarrely it was sending x + #d which is stop and minimise, very odd, there was nothing in my script. I deleted the line and re-added and now all ok.
So i'm now just left with the mystery why I have to use FSE mode to get MVC framepacked 3D when the whole world (mostly NVIDIA users) tells me I shouldnt need it. |
9th December 2017, 01:08 | #47631 | Link | |
AMD works with fullscreen windows mode! You need to stop using reclock or FRC! Try to get your card to work without these tools!!!! See my settings as I gave you before!!! I think MVC 3D will work. AMD is great, very stable, but does not do very high settings. Last edited by HillieSan; 9th December 2017 at 01:11. |
9th December 2017, 08:07 | #47632 | Link | |
9th December 2017, 10:17 | #47634 | Link | |
It would be interesting to create a few config options I consider optimal for different power levels without targeting specific GPUs. My current one would probably need to be called "heater mode". I do think I could do a much more reasonable profile for max quality, but without spending power just because it is available. I'll get started.
9th December 2017, 10:49 | #47636 | Link | |
You don't happen to have any recommended settings for watching 720p on a 2160p screen, using a GT740 (GDDR5), that I can use until I am able to get my hands on a GTX 1080? A GT740 will not be able to do any doubling at all, will it? |
9th December 2017, 10:54 | #47637 | Link | |
I have stuck with v. 0.87.10 longer than I should and mostly because the amount of options now make my head spin. |
9th December 2017, 16:54 | #47638 | Link | |
10th December 2017, 11:46 | #47639 | Link | |
Sorry for being a n00b; what's "RCA"? |
10th December 2017, 11:55 | #47640 | Link |
Remove Compression Artifacts
