5th July 2008, 20:57 | #21 | Link |
Just FYI in MPlayer's SVN the problem with the ASF/WMV file and -vo gl's ati-hack not working reliably should be fixed.
Note that ati-hack scales the width up to the next power of two, so it might almost double the amount of RAM needed by the vo (not that it should matter on any non-ancient PC). |
5th July 2008, 21:39 | #22 | Link | |
Software Developer
6th July 2008, 09:03 | #23 | Link | |
1) there seems to be yet another problem, the texture upload does not seem to work reliably (starting from the certain line, the same line is repeated all over) - this seems to be a different bug, since the stride/layout of the PBO does not matter at all, but it seems to only happen when copying from an offset in the PBO. 2) PBOs quite a bit slower for these dimensions on ATI cards anyway. How I wish for OpenSource drivers, then at least I can find out myself wtf they are doing! |
6th July 2008, 13:54 | #24 | Link | |
Software Developer
9th July 2008, 19:21 | #25 | Link |
Software Developer
MPlayer for Windows installer with new CPU detection code:
MPUI.2008-07-09.Full-Package.TEST-2.exe Feedback welcome
12th July 2008, 16:23 | #26 | Link |
Bug
I've download MPlayer Sherpya-SVN-r27081-4.2.3 and I've found this message is displayed in console many times during playing many .avi movies:
[mpeg4 @ 0pee9970]Invalid and inefficient vfw-avi packed B frames detected What is it? |
12th July 2008, 16:31 | #27 | Link |
Software Developer
Maybe it's "packed bitstream", as found in AVI's created by DivX. This "feature" will pack several frames into one frame, which is required to workaround technical limitations in Video for Windows (VfW).
You can use Avidemux to "unpack" such AVI files. Simply open the "packed" AVI and you will be asked to unpack. Simply agree and save the AVI. That's it...
12th July 2008, 16:43 | #28 | Link |
Software Developer
Another attempt to fix the CPU detection in my MPlayer for Windows installer:
MPUI.2008-07-12.Full-Package.TEST.exe Screenshots of the "Please select CPU type" page would be welcome
13th July 2008, 05:47 | #30 | Link | |
Naturally, I was asked to unpack! But FOURCC in source file was "xvid", not "divx"... And after saving I've found FOURCC become "divx"! Why? After saving my problem was solved. Thank You very much! But I want to know why this message about "Invalid and inefficient vfw-avi packed B frames" didn't appear in previous mplayer versions? Maybe, it will be solved in next versions?.. Because it's very hard to me - to open and save in avidemux about all my .avi files - about 100 files! |
13th July 2008, 13:46 | #31 | Link | ||
Software Developer
For example DIVX, XVID, DX50 and so on. But those FourCC's can be used interchangeable. There is not one "offical" FourcCC for MPEG-4 ASP video Nevertheless some Hardware-Players won't accept the stream, unless it uses the "DIVX" FourCC as used by DivX, that's why Avidemux defaults to that one. It's no problem, your stream was MPEG-4 ASP before and it is MPEG-4 ASP afterwards. Don't worry about it... Quote:
Nevertheless "unpacking" is proper way to fix those files... BTW: Are there any playback problems on the "packed" files or is there just the error message? In the latter case, you can simply ignore the error message, if you don't want to unpack all of your files
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 13th July 2008 at 13:49. |
13th July 2008, 21:48 | #32 | Link | |
Software Developer
MPlayer for Windows 2008-07-13
15th July 2008, 02:47 | #33 | Link |
I'm getting a crash when trying to install 'MPUI.2008-07-13.Full-Package.exe' on WinXP SP3.
I did the following during a Custom Installation attempt: -unchecked 'Set File Associations' -unchecked 'Create Shortcuts' (included Desktop and Quicklaunch icons) I get the crash right after I click next on the installation location screen. (MPUI.2008-07-13.Full-Package.exe has encountered a problem and needs to close. ...) The detail is a crash in nsisarray.dll, offset 00001da8 The crash also leaves remnants in C:\Documents and Settings\ (UserProfile) \Local Settings\Temp I did not try a 'Complete' install because I do not want my file associations changed. |
15th July 2008, 02:53 | #34 | Link |
Software Developer
I do not call the NSISArray plugin directly in my installer code.
Obviously "Ultra Modern UI" (UMUI), on which my installer is based, is using the NSISArray plugin in it's "internal" code. So most likely this is either a bug in UMUI or NSISArray, so I don't know what I could do about it... BTW: I never encountered that crash on my machine [EDIT] The page right after "Install Location" page is the "Strat Menu Folder" page. Is there something unusual in your Startmenu folder at: C:\Documents and Settings\John Doe\Start Menu\Programs Like a great number of items (folders or shortcuts) or very long file/folder names or foreign characters ??? Anything that might cause an array to overflow ??? [EDITē] It's normal that a crashed installer will leave some files in $TEMP, because the installer doesn't get a chance to clean-up...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 15th July 2008 at 03:32. |
15th July 2008, 16:49 | #36 | Link |
Software Developer
1. What video renderer did you select?
2. What does the log show ??? 3. Can you provide a short sample file?
16th July 2008, 05:55 | #37 | Link | |
Thanks for your reply though. One thing i have noticed.. h.264 looks a lot better with MPC/dshow then it does with the open source decoders. (i just wish i had the power for smooth playback with dshow) Last edited by The_Rebel; 16th July 2008 at 05:58. |
16th July 2008, 11:21 | #38 | Link | ||
Software Developer
gl:ati-hack:force-pbo:lscale=5 Quote:
Also MPlayer uses "libavcodec" as H.264 decoder, that's the very same decoder as used by MPC-HC (internal) and ffdshow
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 17th July 2008 at 19:26. |
17th July 2008, 15:28 | #39 | Link | |
17th July 2008, 19:25 | #40 | Link | |
Software Developer
MPlayer for Windows 2008-07-17
mplayer, mpui, player, smplayer, win32 |
