3rd June 2007, 13:30 | #161 | Link | |
Life's clearer in 4K UHD
And it's good to see you on the Doom9 forum - at last Cheers
4th June 2007, 17:54 | #162 | Link | |
It should not be too complex if we do not want to have menus, etc... J |
4th June 2007, 20:26 | #164 | Link |
Success with the PS3
With the .9 version, I was able to take an AVC-TS from BBC that I had downloaded from somewhere in this forum (about 20 seconds of a Beyoncé performance) and my PS3 was able to play the video without problems! That is awesome!
However, the MPEG audio (non AC3) was not recognized. I'm not sure whether the PS3 will even allow m2ts files with MPEG audio to play, or if it's allowed in Blu-ray discs. Either way, this is great progress!!! Now, if only TsRemux.exe would work under Mono... |
4th June 2007, 21:44 | #165 | Link |
I'm right now demuxing audio & video streams from a .mkv file. They appear to be AVC and DTS, respectively. Can I use TsRemux to remux these streams to a .ts or a .m2ts file?
If not, I'd like to request such a feature. Thank you. Oh, almost forgot: I've placed the version 0.0.9 in my box.net share. You can download the file from this address: http://www.box.net/shared/oi1g2ksqao Last edited by colinhunt; 4th June 2007 at 21:50. |
4th June 2007, 22:31 | #166 | Link | |
I guess it's quite hard to add a feature which would remux audio and video streams, especially as audio sync information in this case is stored in the MKV container. So, uh, forget I ever asked for such a feature Thank you for all your hard work so far; TsRemux is obviously on its way to become a very useful application. |
5th June 2007, 00:57 | #167 | Link | |
index was outside the bounds of the array Thx in advance for any replies |
6th June 2007, 07:39 | #168 | Link |
Looks like a great tool! Once MKV to TS support hits, this is gonna be the perfect tool for all hd streaming set-top box owners!!!!!
Thank you so much! If there is any way to donate, or help out, or test anything, let me know |
7th June 2007, 15:25 | #171 | Link |
New version 0.0.10:
Fixed handling of blu-ray PMTs spanning multiple packets. It is now possible to remux blu-ray titles that have tons of substreams, such as POTC. Fixed AC3 in VOB to TS conversion. Various other small fixes. 3rd output option is pre-alpha quality. It doesn't fully work, but you're welcome to test it on various hardware/software and report back issues. Big thanks if you can pinpoint errors and fixes in the files I mention above. Once this is finished I'll move on to MKV input support. |
7th June 2007, 19:29 | #173 | Link |
Version 0.0.10 mirrored here:
http://www.box.net/shared/seh3uu5zmh |
7th June 2007, 23:30 | #174 | Link |
problem with remuxing evo(vc1+ddp) to ts:
1. target file got much bigger than the source: from 137mb to 189mb 2. no audio: haali splitter and sonic demuxer only see video tsremux v0.0.10 did correctly recognize the elementary streams. |
8th June 2007, 00:43 | #175 | Link |
I tried Blu-ray option with TSremux v0.0.10.
I loaded .TS file, then chose Blu-ray option. TSremux created BD structure on hard disk with BDMV and other folder. Then burned BDMV and other folder to BD-RE with Nero using UDF 2.5. PS3 recognizes the disk, says BDMV on BD-RE, then it looks like it is trying to play the disk, but then goes back to XMB. Last edited by kabanero; 8th June 2007 at 00:51. |
8th June 2007, 01:36 | #176 | Link | |
2) Regular blu-ray M2TS files that contain DD+ also have this problem with haali and sonic. Nero splitter that's part of the blu-ray nero add-on works fine for M2TS. For TS I haven't found any splitter that can split DD+ probably because there is no official standard for it. |
8th June 2007, 04:05 | #177 | Link | |
8th June 2007, 09:29 | #178 | Link |
Version 0.0.11 mirrored here:
http://www.box.net/shared/1r35cv2lnd |
8th June 2007, 13:48 | #179 | Link |
check the mp4 faq, the specs are freely available
8th June 2007, 14:04 | #180 | Link | |
Blu-ray Disc Founders. Blu-ray Disc Format White Paper: General. Aug. 2004. http://www.blu-raydisc.com/assets/do...rmat-12834.pdf Blu-ray Disc Founders. Blu-ray Disc Recordable Format Part 1: Physical Specifications. Feb. 2006. http://www.blu-raydisc.com/assets/do...02f1-13322.pdf Blu-ray Disc Founders. Blu-ray Disc Format White Paper: 1.A Physical Format Specifications for BD-RE 2nd edition. Feb. 2006. http://www.blu-raydisc.com/assets/do...lean-13321.pdf Blu-ray Disc Founders. Blu-ray Disc Format White Paper: 1.B Physical Format Specifications for BD-R. Aug. 2004. http://www.blu-raydisc.com/assets/do...ions-12839.pdf Blu-ray Disc Association. Blu-ray Disc Format White Paper: 1.C Physical Format Specifications for BD-ROM 4th edition. Nov. 2005. http://www.blu-raydisc.com/assets/do...an22-13264.pdf Blu-ray Disc Founders. Blu-ray Disc Format White Paper: 3. File System Specifications for BD-RE, R, ROM. Aug. 2004. http://www.blu-raydisc.com/assets/do...sual-12838.pdf Blu-ray Disc Founders. Blu-ray Disc Format White Paper: 4. Key Technologies. Aug. 2004. http://www.blu-raydisc.com/assets/do...sual-12838.pdf Blu-ray Disc Association. Application Definition Blu-ray Disc Format: BD-J Baseline Application and Logical Model Definition for BD-ROM. Mar. 2005. http://www.blu-raydisc.com/assets/do...0307-13404.pdf Dressler, Rogers. Dolby Audio Coding for Future Entertainment Formats. San Francisco: Dolby Laboratories, 2006. http://www.dolby.com/assets/pdf/tech...whitepaper.pdf DTS, Inc. DTS-HD Audio: Consumer White Paper for Blu-ray Disc and HD DVD Applications. Nov. 2006. http://www.dtsonline.com/media/DTS-HD_WhitePaper.pdf Intel Corporation, et. al. Advanced Access Content Systems (AACS): Technical Overview (informative). July 21, 2004. http://www.aacsla.com/marketplace/ov...iew_040721.pdf NVIDIA Corporation. Checklist for Building a PC that Plays HD DVD or Blu-ray Movies. Sept. 2006. http://http.download.nvidia.com/down...ing_a_HDPC.pdf |
