26th May 2007, 18:44 | #264 | Link |
PgcEdit daemon
Oops, that's right. Strange, as the menu, the shortcut key and the icon call the same function.
Thanks for the report!
26th May 2007, 19:09 | #265 | Link |
Just a Member
Thanks for the new version
Web sites with my tools http://download.videohelp.com/jsoto http://jsoto.posunplugged.com/ |
26th May 2007, 20:20 | #266 | Link | |
I get following (not always) application error if I call the trace from the menu. Code:
can't read "::tr::current(Title)": no such variable can't read "::tr::current(Title)": no such variable while executing "set ::tr::backup_current($set,Title) $::tr::current(Title)" (procedure "snapshot_pos" line 13) invoked from within "snapshot_pos $set" (procedure "snapshot_state" line 3) invoked from within "snapshot_state auto" (procedure "cleanexit" line 2) invoked from within "cleanexit" (procedure "::tr::dvd_trace" line 5) invoked from within "::tr::dvd_trace" (menu invoke) |
26th May 2007, 20:36 | #267 | Link |
PgcEdit daemon
PgcEdit v8.2.1
PgcEdit v8.2.1 released!
Sorry, Trace mode is broken in v8.2 when it is activated via the Trace menu. (The shortcut key Control-T and the toolbar icon worked as expected.) Please download v8.2.1, that fixes this problem. Thanks Tobi and JM for submitting this bug!
26th May 2007, 20:37 | #268 | Link |
PgcEdit daemon
26th May 2007, 21:24 | #269 | Link |
Doh, was about to post the tracemode bug... As usual, you beat me to it!
Thank you for work on this program. There is a lot of new polish here and there, and it shows. I also like the new bug dialog. Edit: Potential Bug The warning dialog for the "Delete Last PGC in Domain" menu option says that it will only show once per session, but it kept popping up every time until I turned it off. Last edited by Dr.Khron; 26th May 2007 at 21:30. |
26th May 2007, 23:32 | #270 | Link |
PgcEdit daemon
Well, it's not really a bug, just an omission. I have changed the method, but I forgot to remove the message "this warning will be displayed only once per session."
27th May 2007, 08:37 | #273 | Link |
PgcEdit daemon
That's right, blu. The problem is caused by the third number in the version string. I was aware of the problem when I have released 8.2.1, and I have modified (again!) the autoupdate code. It should work without problem now, for version strings with 2 or 3 numbers, with or without beta extension.
Updating from v8.2 or any 8.2betaX version to 8.2.1 must still be made manually.
27th May 2007, 09:37 | #275 | Link |
PgcEdit daemon
Indeed, it was a good idea, easy to implement.
However, as you have probably noted, the buttons are not present when the small size preview option is selected, by lack of space. Also, they are not present when there is only one cell in the PGC, as they are useless.
27th May 2007, 18:39 | #276 | Link |
JuSt a PoWer uSEr
Hi, r0lZ
Thanks for the new version. A suggestion. Can you add in the tools menu, for the argument an %VMG and it always sends the path to Video_ts.ifo. this is need in order to easily call Vobblanker and Titlewritter. instead of using %I thanks |
27th May 2007, 19:01 | #277 | Link |
PgcEdit daemon
Use "%p\VIDEO_TS.IFO" (with the quotes.)
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 27th May 2007 at 19:04. |
27th May 2007, 20:37 | #279 | Link |
Trace mode closes toolbar and edit buttons
Hey!
This is _the_ best tool ever and I use it alot. However, there is an annoying 'feature' that seems to survive from version to version... When I enter the trace mode, the toolbar and the edit buttons disappear. Ok, I can live without the toolbar, but I use the edit buttons all the time! So every time I have to re-enable the edit buttons from the View toolbar. Is there a reason for this behaviour? I would really like the different areas to remain intact independent of each other! Thank you so much for all your efforts with this excellent tool! /Håkan, Sweden |
27th May 2007, 20:56 | #280 | Link |
PgcEdit daemon
Welcome to the forum, IrmaIsfot, and thanks for your appreciation!
The reason is that, when you are in trace mode, you should not edit the DVD, as this can confuse the trace. However, I have not disabled completely the ability to edit the DVD, as it is possible to combine tracing and editing to do interesting things. For this reason, it is possible to force PgcEdit to keep the toolbars opened in trace mode. Just untick Trace -> Hide toolbars in trace mode. Is it easy enough?
