15th January 2007, 21:36 | #841 | Link |
I never seen an ADV_PCK, so can you please give a hex dump of the first 128 (0x80) bytes? Based on your description above I would say that BackupHDDVD indeed tries to decrypt this kind of block.
15th January 2007, 21:50 | #842 | Link | |
I did find references to ADV_PCKs in the patent, but the header and subheader IDs were the only thing I could find. Worse, when I tried to match up the code to the patent, it didn't seem to jive. There's no reference to stream id 0xbb in the patent, but thats exactly what's looked for in the code. (it looks like t and t2 are the packetid and subpacketid but i forget which is which -- and i might be wrong) Also the patent refers multiple packets per pack (at least in one example), but the code assumes only one with a header length of 128 bytes ... and that length doesn't jive with the patent either. Maybe a navigation pack has a specific format that has only one packet in it? The whole pack/packet thing was a source of confusion for a while. I guess a pack is 2048 bytes long which contains packets of various types. What's really needed is a copy of the HD-DVD 1.0 spec, but you have to be a DVD Forum member to get a copy. I'm guessing they probably will be filing an amended patent later with updated information? I could be way off base here. All of this info is based on sifting through what I could find in just a couple of hours. Last edited by cwm9; 15th January 2007 at 21:53. |
15th January 2007, 21:58 | #843 | Link | |
15th January 2007, 22:01 | #844 | Link |
The code of BackupHDDVD does look specifically for a nv_pck using a number of byte markers. First of all this is not an elegant way of doing it, and second it might be error prone. So if we would actually find a adv_pck in the wild, we can see whether it will be decrypted or not. I was making a small demuxer, so I will see if I can find something. The only problem is that I do not own any of the movies that are mentioned to not work properly.
15th January 2007, 22:03 | #845 | Link | |
15th January 2007, 22:16 | #847 | Link | |
Remember: this could be completely and totally wrong, it's just a GUESS at this point. |
15th January 2007, 22:28 | #848 | Link |
Here is a modified version of BackupHDDVD that will compute it's own hash, thanks to OverlordQ, and then retrieve a key from the online database at http://www.hdkeys.com/
It also writes the key to keydb.cfg for later use. http://www.hdkeys.com/files/BackupHDVD_HDKeys.com.rar The syntax it uses to retrieve the keys is as follows: http://www.hdkeys.com/getkey/hddvd/hash It then reports: Title|VolumeKey Have fun!
mmm...muffins |
15th January 2007, 22:30 | #849 | Link | |
Acccording to the doc, the Advanced packet contains 'specific data structure for copyright protection system' ...
15th January 2007, 23:01 | #850 | Link |
I'm anxious to try this backup method but I'm wondering how and if I can connect an Xbox HD DVD drive to my PC. My system specs are listed below:
MB: ABIT NF7-S v2.0 CPU: AMD XP-M 2400+ @ 2475 VC: ATI Radeon 9800Pro->XT Cat 7.1 430 mem / 385 core Mem: PDP PC3200LLK 512mbx2 PSU: Ultra XConnect 500 Watt ATX HD: 2 x Seagate Barracuda 120.0GB Ultra ATA/100 Optical Drives: BenQ DW1620 Pro and Liteon SOHD-167T LCD: LG Flatron L17108 Case: Kingwin KT-424-BK-WM OS: Windows XP Professional w/ SP2 |
15th January 2007, 23:35 | #851 | Link |
Country Member
Mister Muffin - I know your posts pertain to both threads, but please be careful about cross posting. You can assume people interested in web access to keys will read that thread.
Wookie Groomer - you've been around long enough to know all about rule 12. Please observe it. Multiple post deleted. Regards
Les Only use genuine Verbatim or Taiyo Yuden media. Last edited by blutach; 15th January 2007 at 23:39. |
15th January 2007, 23:58 | #852 | Link |
The more I'm reading the AACS spec, the more I'm confused...
The backuphddvd tool treats packs as NV_PCK and others. For others, the PES flag is checked (Header[20] & 0x30 == 01) to see if the content is encrypted. If the data is encrypted, it's decrypted with the Title key which is a simple decryption with the Volume Key. The spec (0.912) however talks about the content key Kc: Each Encrypted Pack is encrypted by a 128-bit Content Key (Kc). The Content Key (Kc) is calculated by a 128-bit Title Key (Kt), a 32-bit Title Key Data (Dtk) and the least significant 96 bits of the CPI field in the GCI_PKT as follows Kc = AES-G (Kt, Dtk || CPIlsb_96) from the decryption process: If the PES_scrambling_control of the current Pack is 01b or if the current Pack is an HL_PCK, the Player calculates a 128-bit Content Key (Kc) using Title Key (Kt) It's also not clear why they stress the importance for HL_PCK (hightlight) while first they say to use it for all encrypted packs. Could it be that it's only done for HL_PCK with the Kc and otherwise with the plain Title key ? If it's always with the Kc, then how can backuphddvd decrypt any content successfully with the wrong key ? Also any idea where to find more information about the HD DVD-Video Specifications ? It's not really clear what must be cleared here: HeaderPart[0x3c]=0; // Clear CPI field HeaderPart[0x48]=0; Last edited by Nutrition24; 16th January 2007 at 00:11. |
16th January 2007, 03:16 | #854 | Link | |
Posts: n/a
16th January 2007, 03:28 | #855 | Link | |
16th January 2007, 03:47 | #856 | Link | |
At first the more I read the more confused I became, but at least some of it is becoming clearer. Part of my problem was that I had initially read the HDDVD patent w/o reading the AACS spec, so there were a few details I had confused. AACS seems to slice up the standard packs at certain points and insert extra information, most notably the key and the 0x20 PES decryption indicator. According to the decryption part of the spec, you're supposed to decrypt the pack if EITHER the PES bit is set OR it's an HL_PCK. The ADV_PCK stuff I found earlier is something that's forbidden to be encrypted, but it would still be embedded in an "encryption pack" marked either don't encrypt (pes bit not set) or maybe in an HL_PCK, I don't know. The point is, I'm now trying to figure out how to determine when a pack is an HL_PCK which is kinda hard since I could only find two references to it anywhere and I now think that the ADV_PCK is not (directly) related to the problem. |
16th January 2007, 04:53 | #857 | Link | |
http://www.aacsla.com/specifications...orded_0.91.pdf |
16th January 2007, 05:05 | #858 | Link | |
Are you going to prove me wrong, or just continue to stall? I suspect you could have the Blu-Ray version working in only a couple of days given the work you have already done here. It's not fair that you attack only one format - if you are true to what you say you are, you would have already released a Blu-Ray version of this program by now... Color me skeptical of your true motives at the moment. |
16th January 2007, 05:41 | #859 | Link |
interlace this!
@ HD Hell:
dude, most of us can't afford an xbox 360 drive, let alone one of them AND a blu-ray drive. chill out. the guy gave the community something for free, started the hunt to break AACS. blu-ray will be broken soon enough. but don't get shirty that an anonymous person isn't giving you what you want. he didn't have to post anything at all, then you'd have nothing to complain about except a pile of HD-DVDs that you can't decrypt. not a good first first post there...
sucking the life out of your videos since 2004 |
