Old 15th August 2017, 09:04   #44661  |  Link
Originally Posted by dvd1 View Post
Which filters to use for dvd to 1080p?
sorry but you have to try that out by yourself i have no personal experience with such a card try super xbr.
Old 15th August 2017, 09:57   #44662  |  Link
FDisk80
Are there any screenshot comparison between different options for chroma & image upscaling anywhere?
FDisk80 is offline   Reply With Quote
Old 15th August 2017, 11:36   #44663  |  Link
ryrynz
ryrynz's Avatar
There's a few pages around online but nothing recent comparing them all. There are a few good videos people have used in the forums but honestly you could find anything as good yourself with your own content.
Based on my own tests I'd absolutely avoid sharp scalers on animated content.. Also I've found that while in many scenes chroma upscaler differences can be quite subtle, with others the differences can be significant.
Old 15th August 2017, 12:16   #44664  |  Link
FDisk80
Yea, it's too bad there is no proper comparison available.
I'm so lost with all those new NGU settings.
Old 15th August 2017, 12:20   #44665  |  Link
ryrynz
ryrynz's Avatar
Just FYI, there's no need to quote when replying directly after a post. Asmodian posted his settings earlier in the thread and likely has them in his guide/signature, that's a good place to start and just scale things back to suit your cards performance. Once that's done find a few good scenes to use for comparison and change things up a lil and see what you prefer.
Old 15th August 2017, 12:29   #44666  |  Link
FDisk80
Yes, he explains about what everything does very nicely. But I would really love to see some closeup screenshots.
Something like this but comparing between NGU.
Old 15th August 2017, 17:12   #44667  |  Link
dvd1
DVD, 1080P, 720P and SD profiles
What did I do wrong ?
thank you
dvd1 is offline   Reply With Quote
Old 15th August 2017, 17:23   #44668  |  Link
ashlar42
Originally Posted by cork_OS View Post
Maybe if madshi would accept donations for madVR, he could devote more time to it's development.
I'm not madshi but... come on... we have a developer giving away the best video renderer on the market for free. How do you manage to be unsatisfied by this? I can relate to the anticipation and excitement for new releases, but pressuring him seems downright rude to me.
Old 15th August 2017, 18:46   #44669  |  Link
cork_OS
cork_OS's Avatar
I definitely do not want to be rude or put pressure on him. If the acceptance of donations is inappropriate on current stage, I apologize.
I'm infected with poor sources.
cork_OS is offline   Reply With Quote
Old 15th August 2017, 21:10   #44670  |  Link
Asmodian
thank you
It is better to do it the other way around (easier to think through):
If (srcWidth <= 1024) AND (srcHeight <= 576) "SD-DVD"
Else If (srcWidth <= 1280) AND (srcHeight <= 720) "720p"
Else If (srcWidth <= 1920) AND (srcHeight <= 1088) "1080p"
Else "Fast"
You might also make a "fast" profile for the else statement, for everything above 1920x1088, but if you never watch anything UHD then it is not important. Without an else statement, and not matching an if statement, madVR picks the first profile ("1080p" in your case).
madVR options explained
Old 15th August 2017, 23:24   #44671  |  Link
ryrynz
ryrynz's Avatar
Hey Asmodian, ATM I'm using a bunch of these single commands and it's fine but I'd like to tidy it up and have as a single command with an OR or whatever.
if (srcHeight <= 480) and (filepath = "D:\Video\Anime\*.*") "Anime 480"
if (srcHeight <= 480) and (filepath = "D:\Video\Cartoons\*.*") "Anime 480"
I basically want
if (srcHeight <= 480) and (filepath = "D:\Video\Anime\*.*") or (filepath = "D:\Video\Cartoons\*.*") "Anime 480"
What's the proper syntax to achieve it? Cheers.
Old 15th August 2017, 23:48   #44672  |  Link
QBhd
QB the Slayer
QBhd's Avatar
thank you
He is my profile script...
QB's Profile Script
FPS can have a huge impact.
I have a lot of different source types, but feel free to slim it down based on your needs.
QB
QBhd is offline   Reply With Quote
Old 16th August 2017, 01:09   #44673  |  Link
mrcorbo
I basically want
if (srcHeight <= 480) and ((filepath = "D:\Video\Anime\*.*") or (filepath = "D:\Video\Cartoons\*.*")) "Anime 480"
That should work. You want filepath A OR B to be tested first for True/False and then have that result AND srcHeight tested to both be True to activate the profile. The extra parentheses around the filepath clauses should do this.
mrcorbo is offline   Reply With Quote
Old 16th August 2017, 01:37   #44674  |  Link
ryrynz
ryrynz's Avatar
Did the trick, thanks.
Old 16th August 2017, 04:24   #44675  |  Link
Asmodian
I also have a script for various resolutions and frame rates but I try to combine them when possible, e.g. 720p60 using the same profile as 1080p30.
If (deintFPS<31)AND(srcWidth<=1024)AND(srcHeight<=576) "SDp30"
ElseIf (deintFPS<61)AND(srcWidth<=1024)AND(srcHeight<=576) "SDp60"
ElseIf (deintFPS<31)AND(srcWidth<=1280)AND(srcHeight<=720) "720p30"
ElseIf ((deintFPS<31)AND(srcWidth<=1920)AND(srcHeight<=1088)) OR ((deintFPS<61)AND(srcWidth<=1280)AND(srcHeight<=720)) "1080p30"
ElseIf ((deintFPS<31)AND(srcWidth<=4096)AND(srcHeight<=2160)) OR ((deintFPS<61)AND(srcWidth<=1920)AND(srcHeight<=1088)) "2160p30"
ElseIf ((deintFPS<61)AND(srcWidth<=4096)AND(srcHeight<=2160)) OR ((deintFPS<121)AND(srcWidth<=1920)AND(srcHeight<=1088)) "2160p60"
Else "Fast"
Old 16th August 2017, 08:15   #44676  |  Link
70MM
X Cinema Projectionist NZ
Guys the frames are dropping again like dead flies!!!
Last night we reinstalled the drivers and everything was fixed, see my post two up...
I thought all these issues were over, I just turned on the PC and away the frames are dropping again.
Ive had to revert back to Nnedi 128 for chroma upscaling and NGU sharp high for luma upscaling to stop the frame drops. Now its reverted to exactly what it was doing before the new driver reinstall that stopped it last night, just for half a day
What else do you think we can do please...
70MM is offline   Reply With Quote
Old 16th August 2017, 09:03   #44677  |  Link
can you upload your OSD somewhere else and make sure the nvidia power settings are NOT set to "optimal".
Old 16th August 2017, 09:24   #44678  |  Link
70MM
Sorry what do you mean to upload my OSD to somewhere else, did my dropbox one not show?
Power settings not on optimal?
Do you mean in Power Options? I have mine set to High Performance, changed it to Balanced (recommended) but it didnt fix it... Which one should it be on when using the Ti card?
Should I remove madvr and re install it?
Im currently on the version before the latest one...
Old 16th August 2017, 09:29   #44679  |  Link
yes didn't work.
https://abload.de/img/optimalbkzi8.png
this si by default set to optimal which is a very common issue.
Old 16th August 2017, 10:05   #44680  |  Link
70MM
huhn you are absolutely brilliant!!!
That finally fixed it.
I never knew about that setting and have never gone into that section, Im still learning...
When the drivers we re installed it worked fine after that, it was just restarting tonight that the dropped frames started again... Maybe it kind of grabbed Adaptive last night but as it wasnt saved reverted back to optimal.
Gee there are so many small areas us new comers can get trapped by.
Is there anything else in that area that i have to be aware of?
Is there anything that can ever revert it back to default again?
Anyway it looks like Im finally fixed on this one once and for all. Many thanks again...
