19th June 2010, 19:43 | #12001 | Link | |
I often say "maybe"...
So am I wrong ?
We are spitting food to these hungry eyes. You see they ask, we know they are greedy of our rot. Better than to give jam to pigs. x264 r2146 MOD Last edited by MatLz; 19th June 2010 at 19:53. Reason: No "é" in english language... |
19th June 2010, 20:31 | #12002 | Link |
For pure decoding all builds give the same performance because GCC is used as compiler for libavcodec.dll
MPC-HC 2.2.1 |
19th June 2010, 20:40 | #12003 | Link | |
In fact, the only 'filtering' I use is the 'gamma-contrast-brightness...', so can it be the cause of the small speed gain I noticed ? |
20th June 2010, 11:51 | #12004 | Link |
That filtering is done using the GPU, so it does not affect performance. You need to do benchmarks to see if there are actual differences.
MPC-HC 2.2.1 |
20th June 2010, 13:30 | #12005 | Link | |
Casimir666 has added support for MPC Matroska Splitter for PGS sub today Thanks to him And it's working great Seb.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
20th June 2010, 14:35 | #12006 | Link |
Sorry if this has been discussed already, but I just couldn't find anything useful.
I'm using the ffdshow DXVA video decoder for all my DXVA compliant files, but I also have a few H.264 encodes that aren't DXVA compliant (too many reference frames). So I thought I could use the "normal" software ffdshow video decoder for these, i.e. only use the DXVA decoder for files it's going to support. Is it possible to (automatically) do this? I'm using the latest MPC-HC and ffdshow builds. CPU is a Core 2 Duo E8400, ATI HD5750 graphics. Thanks! |
20th June 2010, 15:46 | #12007 | Link |
The DXVA decoder checks for compliance and only decodes streams that pass that test. Whatever other decoder you have installed will take care of the rest.
MPC-HC 2.2.1 |
20th June 2010, 16:32 | #12008 | Link |
clsid,
am I correct to read your words that if the stream is not DXVA compliant the building of the graph will fail and then the player will have to select another decoder? If that's the case this is very inconvenient because for example if one (like I do) uses ZoomPlayer's "Smart Play" functionality and have configured FFDShow DXVA decoder for H264 when the building of the graph fails an error message will appear and then the default directshow graph creation will kick in. In most cases this default graph will be a mess ... at least not what the user wants. As we all know most if not all computers have more than one filter for each format and also most of us have configured ffdshow raw decoding both for audio and for video but use it only in certain cases. All this usually leads to 2-3 decoders in both the video and audio chains and this is never good. So isn't it possible to add an option in the ffdshow DXVA decoder to fallback to the defaul ffdshow decoder when the stream is not DXVA compliant? |
20th June 2010, 16:36 | #12009 | Link |
The graph won't fail. The decoder will simply deny the connection. Then DirectShow will try inserting the next available decoder into the graph (which usually is the regular ffdshow decoder).
MPC-HC 2.2.1 |
20th June 2010, 16:47 | #12010 | Link |
4:2:0 hater
There has been a lot of talk about ATI cards being able to decode 5.1 streams, and I keep seeing files that crash the driver, play with artifacts or simply BSOD, like this one. It's 4.1 compliant in everything except resolution, so it's actually 5.0. MPC reverts to software decoding, but ffdshow uses DXVA and the driver crashes. Play it a second time and you'll get a BSOD.
http://www.megaupload.com/?d=QH4TWGBO (35MB) |
20th June 2010, 16:49 | #12011 | Link |
well, if the decoder denies the connection this means that ZoomPlayer will fail to build the graph with the preconfigured decoders and will fallback to the default directshow graph building.
I tried the following: 1. disabled the H264 DXVA codec in ffdshow DXVA configuraiton. 2. configured ffdshow DXVA decoder as the prefered H264 decoder 3. played a H264 file and got the following warning Code:
Could not find a suitable Decoder for "[Source File: Smart Play Graph].Video" SubTypes: {31435641-0000-0010-8000-00AA00389B71} Code:
Could not create a Smart Play Graph, will now try a standard graph... |
20th June 2010, 17:31 | #12012 | Link | |
20th June 2010, 18:02 | #12013 | Link |
Disabling DXVA and then setting it as preferred decoder will obviously fail. Duh. First do things the right way and if it still fails then you should ask the ZoomPlayer developers to handle this kind of situation properly.
MPC-HC 2.2.1 |
20th June 2010, 18:19 | #12014 | Link |
clsid,
I was just trying to simulate an non dxva compliant stream playback, because I couldn't quickly find one that isn't. That's the only reason I changed ffdshow's config. Of course I won't leave it this way. Well I'm not sure it's players responsibility to change decoders depending on the DXVA compliance of the stream. AFAIK there is only one media subtype for both DXVA and non DXVA H264 streams so the player cannot have different configurations for different H264 streams. One more reason that brings me to the same conclusion is that all other DXVA capable decoders fallback to software mode without the need to rebuild the graph or change the decoder. This is true for MPC's Video decoder, Cyberlink's one, DivX's one and I'm pretty sure it's the same with Microsoft's DTV-DVD decoder too. So I think it's only FFDShow that's making it in different way which is not very convenient for the users. I'll be glad to be proven wrong here and somebody to show me how to use ffdshow DXVA decoder in Zoomplayer or DVBViewer (another player in which you can configure only one H264 decoder at a time) |
20th June 2010, 19:09 | #12015 | Link | |
4:2:0 hater
Writing on ATI forums is useless IMO. ATI cards definitely have bad support for high resolution and high number of ref frames. The issue I see here is that this particular file is blocked by MPC, but not by ffdshow. Looking at how it crashes the driver here I'd say MPC is right and ffdshow is not. Also, why MPC blocks it if this card can play 5.1 streams? |
20th June 2010, 20:14 | #12016 | Link |
be patient They've just added support for 5.1 streams. Maybe they will fix it. But I don't know why I have to choose skip all checks in ffdshow to play 5.1 streams if my card and my driver support it. I didn't have problems with 5.1 streams until this sample of yours
And I believe that wating 3 minutes to play that sample is equal to the blue screen you had. because my monitor went black after that yet my computer was working. I could hear the sound. stupid driver |
20th June 2010, 21:51 | #12017 | Link | |
The behavior of ffdshow is working fine and is intentional to allow fallback to software decoders other than ffdshow. This will not change!
MPC-HC 2.2.1 |
20th June 2010, 22:16 | #12018 | Link |
SERIOUSLY?? Man all the fun happens when I'm on vacation. I came back home just for tonight but I'll have to grab that and give it a quick test before I leave for the rest of the week. Do you have a link?
20th June 2010, 22:20 | #12020 | Link | |
