15th May 2003, 20:50 | #21 | Link |
Asker of Questions
Are they dboost and dstren? They seem to do essentially the same thing, one right after the other.
"The real trick to optimizing color space conversions is of course to not do them." --trbarry, April 2002 |
15th May 2003, 21:07 | #22 | Link |
I personally don't like the thinning of the lines in my anime so i try to minimize all the warping settings as much as possible, but this is definately a useful "filter".
I'm not much of a programmer, and I honest don't feel like testing to see if my guesses on redundancy are correct, but to me it seems like detail range and detail limiter are somewhat redundant, despite having a different range of perameter values. But also wondering, will cwarp work if you omit cwarp2 (does it default to 0/1 thus enable it's typing to be redundant, perhaps making that your "obsolete") cwarp = Default(cwarp, true) # chroma warp on/off cwarp2 = cwarp ? 1 : 0 aWarpSharp(cm=cwarp2 you also don't ask cwarp2 to be identified in mftoon() only cwarp, yet i don't see cwarp anywhere, only cwarp2 Last edited by WyldeF1r3; 15th May 2003 at 21:13. |
15th May 2003, 22:12 | #23 | Link | ||
And about the cwarp: nope . cwarp is boolean, and the line you pasted converts the boolean into int. I did this because I originally didn't know there were 3 values for aWarpSharp's "cm" . But I left it in there cause cm=2 will usually be more crappy than cm=1 anyway. |
16th May 2003, 16:24 | #24 | Link |
Yoshi
The thing that is unacceptable in this filter is the overall darkening of the picture, as MPEG4 tends to overcompress dark colors that are still noticeable.
It also would not be a useable one since the only accurate way to use a contrast filter is before deinterlace/decomb. Since this filter will interpolate lines, there is no way to use it there, so it is not a useable filter You can do all the sharpening you want, but as soon as I saw the bicubic resize in the script = interpolation = tough to decomb
member of www.clan-ee.com |
16th May 2003, 16:37 | #25 | Link | |
A) It doesn't darken the whole picture anymore. That was fixed in v0.30. B) What you say only applies to lumi-masking. C) You can simply turn off the interpolated sharpening, just do sharpen=false. D) You should never use these kind of filters on interlaced material, except if it has support for it. Last edited by mf; 16th May 2003 at 16:39. |
16th May 2003, 17:42 | #26 | Link |
1) People tend to overlook your strength at hiding this obsolete parameter while looking for it, isn't it ?
2) Levels(0, 1, 255, 255, 0) = Invert(Y=3,U=2,V=2) from my filters's package, AFAIK. But it might be slower... 3) There could be smarter edge detectors than "sobel", especially if they only detect dark lines. But that's would be of little help anyway. Last edited by Kurosu; 16th May 2003 at 17:48. |
16th May 2003, 18:02 | #27 | Link | ||
18th May 2003, 07:05 | #29 | Link |
Yoshi
looks allrite with the newer versions. (did not look around lol)
but I could always do a chain SmartSmooth to emphasize edges. SmoothHiQ(5,8,16,256,6).SmoothHiQ(5,8,16,256,6).SmoothHiQ(3,8,16,256,4).SmoothHiQ(3,8,16,256,4) lol, makes them ****** PinkPineapple DVD's look nice and focused
member of www.clan-ee.com Last edited by Guest; 18th May 2003 at 07:26. |
18th May 2003, 11:43 | #30 | Link | |
23rd May 2003, 20:30 | #31 | Link |
Just a quick question for you mf or actually maybe not so quick. Ok, so I have been trying to modify mftoon to work for a dvdrip but I can only seem to get it to work one way. Here is my script:
LoadPlugin("C:\Video\Avisynth Plugins\MPEG2Dec3.dll") LoadPlugin("C:\Video\Avisynth Plugins\Decomb.dll") Import("C:\Video\Avisynth Plugins\mfToon-v0.32.avs") MPEG2Source("C:\DVD\VIDEO_TS\DVD.d2v",idct=5,cpu=2) Telecide(post=false).Decimate(5).FieldDeinterlace(full=false) crop(12,2,704,476) mfToon(sharpen=false,cwarp=false,ssw=3,ssh=3) BicubicResize(640,480,0,0.5) But, if I do it this way this means that I am resizing three times, first to supersample it and then to resize again to do mergeluma() and then again after mfToon(), I can get mfToon to work like this if I eliminate mergeluma() but I would like use it and also only resize it twice. Is there any way that you can think of to do this? I have been trying for quite a while now and I can't seem to figure it out. I don't think there will be any loss in quality by resizing three times like this but definitely it will slow it down. I guess, the real problem is that the frame size for mergeluma() must be the same so if I change orig.width and orig.height to 640 and 480 respectively everywhere obviously it doesn't work, I guess I could also resize to 640x480 before the first mergeluma() but then I still have to resize three times. Maybe you or someone else can think of a way around this since I can't seem to. EDIT: Don't bother actually, I made my own script and stole some of the routines you used in mfToon, seems just as good since the source is fairly clean plus it is a lot faster Last edited by BoNz1; 23rd May 2003 at 22:37. |
24th May 2003, 03:45 | #32 | Link |
Cool. Now that I have Avisynth 2.5.1 working on my machine, I want to play around with this. I created a script that CCE accepted, but when I hit decode it thinks about it for about 5 seconds and then it thinks it's done. Of course, nothing has been produced except a small file that doesn't amount to anything.
I noticed that somebody had shown some screen shots of Naruto. I wonder if the original source files were .avi files (fansubbed divx files). Does mftoon work with these type of files? I'm sure the answer is right in front of me and I'm missing something. thanks. |
24th May 2003, 11:48 | #33 | Link |
YAY! Feedback! ^__^
Bonzi: You have sharpen=false set, so the resizing routines are left alone. mfToon isn't resizing with sharpen=false set. So ssw and ssh have no influence either. And warping isn't done either, so cwarp is ignored too, in this mode. Zeus: I don't know for sure, but I think CCE only eats YUY2. Try putting ConvertToYUY2() at the end of your script. |
24th May 2003, 18:02 | #36 | Link |
Ahh....Thanks. I appreciate you letting me know that.
I encoded a 1 minute segment and it took about 25 minutes (just did a CBR) and will burn it to a DVD+RW and check it out later on the TV to see if I like the results. If they are promising, then I don't mind the extra time involved. Thanks for all your answers and help! I appreciate it. |
27th May 2003, 19:34 | #40 | Link | |
Ahhh....Nuts!!
Core 2 Duo intel, overclocked at something (can't remember what i set it at), about 2 TB in hard storage, nvidia 9800 GT and a pretty old 19tftscreen. Crusty007 at en.Wikipedia.org |
