10th January 2004, 23:23 | #203 | Link |
Heres a link for the download of the test sample i did,
http://renault5archive.donnchadh.co.uk/cow.avi how could i make this better, to me it looks like the lines are to thick and its overly bright, what settings do i need to change to alter these factors cheers |
12th January 2004, 00:02 | #204 | Link |
Member
Hi mf, could you please fix this annoying "strength" bug? I hardly ever use full strength linedarkening, unless the source I have to work on is blurred as hell or features chroma ghosting etc. So I can put mftoon only to limited use atm
mrfil13: The clip doesn't looks "wrong" to me, but I don't know how it's supposed to look You can thin lines using the warpsharp filter. Brighness adjustment can be done via the levels filter. Use the vdub version of the filter to find the correct values, then enter them in your avs script. However, unless you know that you colours/brightness are off, I wouldn't start fiddling around with it. CU, lamer_de |
12th January 2004, 10:20 | #205 | Link | |
12th January 2004, 19:58 | #206 | Link |
Fascinated Lurker
Is there no other way of using mftoon without that specific warpsharp.dll? It's phenominally bug-ridden - I recall MarcFD taking just the warpsharp code because one of the other parts of the filter kept causing crashes all the time.
12th January 2004, 20:01 | #207 | Link | |
Unsharpmask() XSharpen() FrameCache() Then I'd be happy enough. |
13th January 2004, 14:58 | #208 | Link |
Fascinated Lurker
BTW, the warpsharp.dll pack posted on this site:
http://www.geocities.co.jp/SiliconValley-PaloAlto/2382/ Created Nov '03 184k, is much more stable than the 127k version you have linked to at the start of the thread and doesn't cause any crashing with autoloading so far. Are you aware of this version? It seems to work fine for me. |
13th January 2004, 15:44 | #209 | Link | |
14th January 2004, 12:04 | #211 | Link | |
14th January 2004, 17:58 | #212 | Link |
repost.. Help please Tk you []
Well, I'm just restarting to backup my Dvd's, so some questions here will be somewhat dumb or lamme.. I've been trying to backup Gits into 2 Cd's, with 2 ogg streams (jap, Eng), and the Dvd is interlanced, so I'm using Toms to deinterlace it.. The bitrate reported by Gknot ia around 1911, with a 704*368 pal Anamorphic aspect.. my question is.. What settings should I use.. I don't know if I'm choosing this right.. Size and audio are what I want, because I need extreme quality.. But I'm not sure about filtering and related issues..
Could all you help the newbie here?? Im using Knot latest build, VdubMod included in Gknot, and Avisynth 2.5 :P PS: The image back there was really cool.. I liked it.. Ohh, I don't mind speed.. I'm more consourned with the final quality Once again Thank you [[[]]] Arrakis_Dune OUT PS2: # # Created with Gordian Knot # # http://gknot.doom9.org # # PLUGINS LoadPlugin("C:\PROGRA~1\GORDIA~1\mpeg2dec3.dll") LoadPlugin("C:\PROGRA~1\GORDIA~1\undot.dll") LoadPlugin("C:\PROGRA~1\GORDIA~1\TomsMoComp.dll") # # SOURCE mpeg2source("E:\GHOST_IN_THE_SHELL\VIDEO_TS\New Folder\GITS Main.d2v") # # CROPPING crop(6,16,708,540) # # DEINTERLACING (1) #FieldDeinterlace() #FieldDeinterlace(blend=false) TomsMoComp(1,5,1) # # RESIZING LanczosResize(704,368) # # Undot() |
14th January 2004, 18:49 | #214 | Link |
Well, I was wondering if I could use your filters to help my backup.. I've read a lot, and they seem to be the ideal ones for the "job".. The only problem Is how to apply them to the rip.. If you could help I would be appreciated
[[[]]] Arrakis_Dune OUT |
14th January 2004, 22:30 | #216 | Link |
Thanks.. I was encoding a tinny bit to fast, without any improvementes to the eye.. So I knew something was wrong.. I was missing
mfToon() Anyway, on Ghost In The Shell, I must say your filters are the greates.. I've seen major improvments in the image quality and in the lines definition.. Once again, thank you Arrakis_Dune OUT |
14th January 2004, 22:36 | #217 | Link |
Sorry for the useless interruption. I splitted Arrakis_Dune's post from this thread, because I thought it was totally unrelated.
I guess it was not, since he added it back again. Sorry for the troubles! |
16th January 2004, 16:29 | #220 | Link |
Do you have new links to those 3 plugins you need? I can't get the ones in your first post to work at all! Thanks!
AMD AthlonXP 1800+ Abit KX7-333R 512 MB Mushkin pc3000 DDR RAM 80 gb IBM 60gxp Hercules 3D Prophet 8500 @ 300/300 http://www.battle.net/war3/ladder/w3xp-player-profile.aspx?Gateway=Sunken-Ruins&PlayerName=CacK http://www.battle.net/war3/ladder/war3-player-profile.aspx?Gateway=Lordaeron&PlayerName=zonto http://service.futuremark.com/compare?2k1=4303905 |
