27th November 2011, 15:16 | #11121 | Link | |
MPC-HC disappearing subtitles
Madshi, I want to ask you about this fix:
P.S. If you block OSD message any time you encounter word "Play" or "Pause" in OSD text, here translation of these words into Russian: "Play"="Воспроизведение", "Pause"="Пауза". |
27th November 2011, 21:45 | #11123 | Link |
PQ comes down to decoder (shouldn't cause PQ issues in theory) and renderer. The renderer can have a very large affect on PQ. So to answer your question, if you use LAV Video and madVR in all those players, they will look identical. If you're using internal decoders and/or renderers, then there could be a difference. Again, the decoder SHOULDN'T make a lot of difference in PQ unless it's doing some kind of post processing.
28th November 2011, 11:47 | #11127 | Link |
Playing with MKV files...
Double checked my setup and disabled the internal audio switcher that was still running and unchecked the DVD Title Set filter from the internal splitter's list. I do find it interesting that both you and the last poster who said it worked for them was using ReClock, but that's just a coincidence, I'm sure. Oh well. Still seems to be a bug in MadVR, or more accurately I think, a change in Windows made to disrupt using third party players for DVD playback in Windows. Can't have a free app outperforming WMP on picture quality after all.
Intel Core i7 920, 6 GB RAM | GeForce GTX670 | Win8.1 | LAV 0.64 / MadVR 0.87.10 | Zoom Player v10 / MPC-HC 1.7.8 |
28th November 2011, 12:08 | #11129 | Link | |
I can do the same thing by selecting VMR for renderer for the duration. With native screencap capability even in exclusive mode it would be a simple case of pause the movie and take the screencap! Basically it's just inconvenient. For 'me' being able to screencap without messing around is the last peice in the puzzle for MadVR. Last edited by oddball; 28th November 2011 at 12:11. |
28th November 2011, 12:49 | #11131 | Link | |
EDIT: I tried disabling both exclusive and use seperate presentation for good measure. Restarted the movie and tried to screencap. No dice. Same error. Last edited by oddball; 28th November 2011 at 12:53. |
28th November 2011, 13:05 | #11132 | Link | |
28th November 2011, 13:25 | #11133 | Link | |
I already knew that. Makes no difference to screencaps though. |
28th November 2011, 13:36 | #11134 | Link | |
28th November 2011, 14:03 | #11135 | Link | |
Sent from my Xoom using Tapatalk
28th November 2011, 14:21 | #11137 | Link |
Or you're playing anything thats not 8-bit 4:2:0
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 28th November 2011 at 21:44. |
28th November 2011, 20:46 | #11138 | Link |
Can you care to explain ? It's true that 99% of the content is 4:2:0 right? I know of the Hi10P content around, but there isnt much content encoded in this format right?
Anyways, i would like to know why there is a difference in other formats, because ffdshow doesnt support it? |
28th November 2011, 21:43 | #11139 | Link |
Hi10p is something else (10-bit depth H.264), and all Hi10p content I've seen (just some anime reencodes) is still 4:2:0. I'm also curious about what other content is in higher than 4:2:0 though. Don't think it even matters unless the original source is also higher.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
