Old 10th October 2021, 15:30   #61  |  Link
PCU
Don't know about advanced settings of x265
Just look at the scroll bar, lots of advanced settings!
PCU is offline   Reply With Quote
Old 13th October 2021, 00:17   #62  |  Link
benwaggoner
If you enjoy those, you'll love the x265 thread and the official x265 documentation.
Ben Waggoner
My Compression Book
Old 13th October 2021, 08:17   #63  |  Link
PCU
Thank you. please add thanks button to every reply if it's possible.
Old 10th January 2022, 13:21   #64  |  Link
PCU
Guys, do you think this claim is true?:
x264 cannot actually achieve lossless. It's lossless setting is close but ProRes422 is generally a little better quality, faster rendering, and smaller. MagicYUV is another possible option.
Old 10th January 2022, 13:34   #65  |  Link
rwill
Please stop. My head hurts.
Really how can something has a little better quality than lossless ?
Old 10th January 2022, 13:42   #66  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
I don't think is true, but you can try it yourself.
Take a source, use x264 lossless to encode the file, then use SSIM and PSNR to compare it with the source.
If they return infinite, so perfect score, then it's really lossless, if they don't, then it's not.
I would be very surprised if the result came out anything other than infinity, so lossless.
ProRes is lossy and uses the DCT, so I expect the result from SSIM and PSNR to be a real number, lower in value.
Old 10th January 2022, 13:58   #67  |  Link
PCU
God willing, how literate are the users of pro NLEs. I could not tell him how literate he was!
Old 13th March 2022, 10:29   #68  |  Link
PCU
What do you think about this opinion:
https://www.quora.com/What-is-the-mo...pression-codec
Most codecs are not truly lossless, since mathematically lossless compression usually doesn’t give significant reduction in size and bit rate, and thus lossless compression is pretty much useless for video.
Now, you can ask about “visually lossless” compression, which means that the input and output are not bitwise identical, but that the differences are not visible to a human observer with some specified visual acuity under some specified conditions.
Of the current lossy codecs, H.265 and VP9 are probably the best for quality at a fixed bit rate.
If possible, you should compare codecs using your own typical content, and viewing under your own typical viewing conditions.
If you read the literature of codecs, they are always comparing their new codec against some previous best result. However, be wary of what measure they use for comparisons. Until recently, it was common to use measures like PSNR or SSIM to rate codecs, and these measures do not correlate well with human quality judgements. The VMAF video quality measure created by Netflix is designed to be better, but you should be aware of what it was designed to pay attention to. Also be aware that there are 3 different sets of “calibration” data for VMAF, depending on whether the viewer is assumed to be watching a UHD monitor at 1.5 times picture height, a HD monitor from 3 times picture height, or a mobile device from significantly further than 3 times picture height.
Old 13th March 2022, 11:05   #69  |  Link
kolak
Answer states established facts. Typical 'scholarly' answer
You have mathematically lossless codecs (modes) and visually lossless. h264/5 can be both, other codecs can be just on of those.
Old 13th March 2022, 14:50   #70  |  Link
rwill
Well if someone does not want to dive into codec details and does not want to research his use case I would recommend him to use 7zip for his lossless needs.
Old 13th March 2022, 16:53   #71  |  Link
PCU
Besides being 100% lossless, I'm looking for the highest compression codec.
Old 13th March 2022, 16:56   #72  |  Link
PCU
Can we call it the new video codec benchmark? If yes, how to use it:
https://github.com/Netflix/vmaf
Old 14th March 2022, 11:09   #73  |  Link
Sharc
The "best" codec for archiving is the one which will still be available for decoding the archived files in 100++ years
Old 14th March 2022, 11:48   #74  |  Link
kolak
Exactly.
Also with lossless you don't gain much between best and worse codec, so chase for the best losses compression is about pointless. Some work better for anime, others for noisy etc. but on average all decent ones will be very similar:
Use what works for you from the workflow point.
All those metrics are pointless for mathematically lossless codecs. They are lossless, so all will have same value (1 or whatever means "same as source)
If you familiar with ffmpeg use ffv1, which should hold for years as many national archives are now using it. It's efficient and not terribly slow. x264 is also viable option (x265 is slower for no real gain).
Old 14th March 2022, 12:11   #75  |  Link
PCU
Thanks, but:
There are multiple criteria to take into account: encoding speed, decoding speed, bit depth, codec features, temporal compression, sub-resolution decoding. And quality-wise there are multiple different metrics (sign to noise ratio, human vision, generation loss, etc.). So I'd say it's a very hard topic to discuss...
Goal: best compression for HDR:
Current codecs:
MagicYUV
FFV1
x265
AV1
VC-2
JPEG XS lossless
Ut Video Codec Suite
CorePNG
Lagarith
So, what do you recommend for example: recoding video games with HDR, at least 60 FPS, 4K?
Old 14th March 2022, 14:48   #76  |  Link
kolak
Your workflow/specific case dictates your choice.
UHD 60fps requires very fast codec.
Most codecs from your list won't work due to performance.
As I said- first look what apps you can use and what options they give you. Encoding 4K games at 60 fps isn't that trivial.
Why do you need lossless encoding for games? Is it not overkill?
All mentioned quality metrics are meaningless for lossless encoding as there is no difference to the source, so nothing to measure (nor any generation loss).
Old 14th March 2022, 15:41   #77  |  Link
PCU
I edit the recorded videos of the game and sometimes I have to convert them lossless.
I use Premiere Pro and Media Encoder and talk to the plugin developer for Premiere Pro to add which lossless codec to PP and AME, but it's hard work which codec is better.
So, I think only these 3 codecs are what I really need to make a decision about, right?:
MagicYUV
FFV1
x265
Old 14th March 2022, 16:35   #78  |  Link
kolak
If you really need lossless file ( I still don’t think you do) and you edit in Premiere then MagicYUV will be your best bet ( once you have plug-in which lets Premiere to import it at 8bit+).
Ffv1- may be hard to get real-time encoding and Premiere doesn’t support it if I’m correct. x265 is another option, but of course through GPU encoding.
So your long list and loads of thinking got simplified to basically a single choice
Old 14th March 2022, 18:50   #79  |  Link
PCU
FFV1 is supported by Voukoder, x265 does not support HW acceleration and I'll have to pay for MYUV for full version!
But I think it all ends in MYUV!
Old 14th March 2022, 20:44   #80  |  Link
Zarxrax
You can use DNxHR or Prores. They are perceptually lossless and probably faster than even Magic YUV. Can encode in FFMPEG and at least one of them should be supported in premiere. Nothing to buy.
Zarxrax is offline   Reply With Quote
