Old 22nd December 2018, 23:37   #6541  |  Link
Ma
If you want to encode without VBV buffer, you could use --seek and --frames options, for example:
for %i in (0 1000 2000) do ffmpeg -i ../lighthouse_lossless.mp4 -v warning -f yuv4mpegpipe - | x265 --y4m - --crf 20 --seek %i --frames 1000 c%i.hevc
which expands to:
ffmpeg -i ../lighthouse_lossless.mp4 -v warning -f yuv4mpegpipe - | x265 --y4m - --crf 20 --seek 0 --frames 1000 c0.hevc
ffmpeg -i ../lighthouse_lossless.mp4 -v warning -f yuv4mpegpipe - | x265 --y4m - --crf 20 --seek 1000 --frames 1000 c1000.hevc
ffmpeg -i ../lighthouse_lossless.mp4 -v warning -f yuv4mpegpipe - | x265 --y4m - --crf 20 --seek 2000 --frames 1000 c2000.hevc
Finally you can put these 3 parts together:
mkvmerge -o c-whole.mkv c0.hevc + c1000.hevc + c2000.hevc
example for Windows
Ma is offline   Reply With Quote
Old 23rd December 2018, 00:10   #6542  |  Link
BLKMGK
Originally Posted by asarian View Post
Coding HEVC directly with (hardware-accelerated) NVENC, for instance, is an order of magnitude faster (and sometimes several orders of magnitude even) than what we can achieve with x265 itself, but you have no control over the process, and the quality is definitely lower than that of the latter.
I was more talking about OpenCL in x264; and especially used for the KNLMeansCL denoiser (QTGMC), where it speeds things up significantly. Even though I recently heard even OpenCL yields a theoretical lower quality.
As for the latter, typically you have to refresh your explorer window (a few times) to see how much is actually output already, or it will stay at 0 bytes.
As for chunks, I never used them before, so I can't really say something useful about that.
Ah, makes sense to use them for programmatic speedups and for filters I agree. I may try using my GPU a few times just to see if the results are acceptable to me but so far haven't been able to get it working the few times I've tried
This definitely wasn't a refresh issue in explorer, Chunk really doesn't appear to save any data until it hits its start frame and continues encoding after it hits its end frame. Ugh!
which expands to:
example for Windows
I've done this except I started and ended on keyframes with the understanding that not doing so could have poor joins. The issue with that is it requires first pulling an index and then skipping through it to build the jobs. The first test attempted I built the latter part by hand (PITA) and after encoding I couldn't detect the seams at all. Seemed a good path forward!
I then noticed chunk in the release notes. Chunk, from its description and some discussion I'd seen here, seemed tailor made for clutering but my tests sure don't seem to prove it out. I'll try your example and see if I can detect the seams, perhaps I've been too paranoid?
Thank you for the example of how to build the jobs!
Edit: Tested this method ignoring keyframes and thought I detected a hitch in the video. Sure enough VLC shows two dropped frames where the hitch occurs and I see it elsewhere too. I'll keep testing and see if the keyframes are the issue. I'll pull an index and create some jobs. I need an automated way to build jobs from the index but not at every break lol
BLKMGK is offline   Reply With Quote
Old 23rd December 2018, 01:29   #6543  |  Link
Ma
I tried to add --chunk-start/--chunk-end to the example and it is like this:
Encoding in parts of 1000 frames (+100 before, +100 after):
ffmpeg -i ../lighthouse_lossless.mp4 -v warning -f yuv4mpegpipe - | x265 --y4m - --crf 20 --no-open-gop --seek 0 --frames 1100 --chunk-start 1 --chunk-end 1000 c0.hevc
ffmpeg -i ../lighthouse_lossless.mp4 -v warning -f yuv4mpegpipe - | x265 --y4m - --crf 20 --no-open-gop --seek 900 --frames 1200 --chunk-start 101 --chunk-end 1100 c1.hevc
ffmpeg -i ../lighthouse_lossless.mp4 -v warning -f yuv4mpegpipe - | x265 --y4m - --crf 20 --no-open-gop --seek 1900 --frames 1200 --chunk-start 101 --chunk-end 1100 c2.hevc
mkvmerge -o chunks.mkv c0.hevc + c1.hevc + c2.hevc
Old 23rd December 2018, 05:00   #6544  |  Link
BLKMGK
That looks like a very good idea to get the encoder to take into account frames before and after the specified range in order for the encoder to be more efficient! It's not breaking on keyframes, am I wrong about their importance?
I tried your example on my sample file, I'm not spotting glitches or dropped frames in the statistics and I managed to extend it out some.
ffmpeg -i INPUT.MKV -v warning -f yuv4mpegpipe - | x265 --y4m - --crf 20 --no-open-gop --seek 3100 --frames 1200 --chunk-start 101 --chunk-end 1100 --csv stats.csv c3.hevc
If I'm wrong about the keyframes that will make life much easier. I'll try doing an entire film once I've incorporated this into my bash script, mux in sound, and check the synch.
Thank you! I really appreciate you providing examples too as it makes understanding what you're doing much simpler.
Old 23rd December 2018, 05:39   #6545  |  Link
nghiabeo20
What can SAO do? Does it improve quality/file size?
I'm targeting good quality with reasonable bitrate (5-6000 kbps for 1080p10, BD remux source) with CRF 21. Thanks!
nghiabeo20 is offline   Reply With Quote
Old 23rd December 2018, 13:42   #6546  |  Link
excellentswordfight
Lost my old account :(
Yes, SAO increases efficiency/compression. But it usually does it with the drawback of an slight reduction in fine detail. So its pretty great for low bitrate encodings and animation, but not so much if you wanna keep most of the detail.
Its best if you test it for yourself, and see what settings gives you the best results, but if you target that bitrate range I whould say that you might wanna turn it off.
And btw, I think crf21 will end up at a much lower bitrate for most content if you dont us tune grain or something similar. I get arround those numbers with crf18.
excellentswordfight is offline   Reply With Quote
Old 23rd December 2018, 16:46   #6547  |  Link
nghiabeo20
Maybe I'm doing something wrong. All I edit from the veryslow preset is these commands
bframes=6:subme=3:rd=5:qcomp=0.75:no-sao:deblock=-2:-2
however CRF 22 10bit without any tuning gives me a whopping 8500kbps for a 30s test clip from my The Hundred-Foot Journey bluray!
Old 23rd December 2018, 16:59   #6548  |  Link
Boulder
Pig on the wing
Boulder's Avatar
The bitrate depends a huge deal on the content. Grainy or noisy stuff requires much more than some clean CGI content.
Old 24th December 2018, 00:24   #6549  |  Link
excellentswordfight
As boulder said, thats very source dependant. And a 30s sample might not be representative either. But with that said i think your qcomp setting plays a role here (maybe deblock as well).
Old 24th December 2018, 04:17   #6550  |  Link
singhkays
Can anybody give any advice if there is any benefit by taking the following approaches? and is either one of the splitting methods preferred?
  1. Split a video file on keyframes
  2. Split a video file based on the shots (i.e. different camera angles)
other than the obvious ability to parallelize the encoding task
singhkays is offline   Reply With Quote
Old 24th December 2018, 08:09   #6551  |  Link
Selur
Selur's Avatar
Aside from further parallelizing the encoding more there is no reason to split a source unless you want to.
When having the split a source for parallelizing the encoding I would prefer to split 'a video file based on the shots' since the source simply might have key frames placed in a fixed interval not caring about coding efficiency. That said splitting on key frames is easier.
But splitting on key frames in respect to scenes and using the segmented encoding feature of x265 is probably the best easy to implement way. Ideally you wound split at the points where the encoder would want to set key frame for coding efficiency.
Old 24th December 2018, 23:28   #6552  |  Link
singhkays
Thank for the advice. I have specific question on the below
How would this work? Should I split on keyframes within the scenes?
I haven't heard about this. How does this feature work?
How do I figure out where the encoder wants to set key frames? I thought that was a user controlled option i.e. keyint
Old 27th December 2018, 13:32   #6553  |  Link
filler56789
SuperVirus
filler56789's Avatar
To whom this may interest...
latest revision(s) cannot be compiled under MinGW-w64 && MSYS(2).
Some recent changes prevent the libraries from being linked to the command-line .EXE.
filler56789 is offline   Reply With Quote
Old 27th December 2018, 14:32   #6554  |  Link
Ma
Multilib builds are broken (and builds with ENABLE_HDR10_PLUS too).
Simplest solution:
diff -r 537bba0b7fdc source/encoder/encoder.cpp
--- a/source/encoder/encoder.cpp	Thu Dec 27 11:56:52 2018 +0530
+++ b/source/encoder/encoder.cpp	Thu Dec 27 14:25:51 2018 +0100
@@ -69,7 +69,7 @@
     int doviProfileId;
 }DolbyVisionProfileSpec;
-DolbyVisionProfileSpec dovi[] =
+static DolbyVisionProfileSpec dovi[] =
     { 1, 1, 1, 1, 1, 5, 1,  2, 2, 2, 50 },
     { 1, 1, 1, 1, 1, 5, 0, 16, 9, 9, 81 },
diff -r 537bba0b7fdc source/x265.cpp
--- a/source/x265.cpp	Thu Dec 27 11:56:52 2018 +0530
+++ b/source/x265.cpp	Thu Dec 27 14:25:51 2018 +0100
@@ -690,7 +690,7 @@
                 args[argCount++] = token;
                 token = strtok(NULL, " ");
-            args[argCount] = '\0';
+            args[argCount] = NULL;
             CLIOptions cliopt;
             if (cliopt.parseZoneParam(argCount, args,param, i))
Old 27th December 2018, 15:46   #6555  |  Link
filler56789
SuperVirus
^ Thanks for answering.
OUCH! :-/ So I will have to wait.
Simplest solution:
@@ -69,7 +69,7 @@
     int doviProfileId;
@@ -690,7 +690,7 @@
             CLIOptions cliopt;
Since I didn't know the multilib builds are impossible for the time being,
the old error message
(something about "invalid conversion from char to char*")
just went replaced with a new one :-/
Old 28th December 2018, 07:36   #6556  |  Link
Yanak
Introduce --tune animation option
--psy-rd 0.4
--aq-strength 0.4
--deblock 1:1
--bframes increased by 2
Sorry if it's a silly question but Bframes increased by 2, means +2 from the default parameter which is 4 Bframes according to the doc, so it will be --bframes 6, or from 0 so it will be --bframes 2 ?
Thank you
Yanak is offline   Reply With Quote
Old 28th December 2018, 08:23   #6557  |  Link
Wishbringer
Silent Reader
Wishbringer's Avatar
Or from bframes you give per commandline?
What has a higher priority?
I expect: +2 from preset, except explicit given by command, then the manual value
Wishbringer is offline   Reply With Quote
Old 28th December 2018, 09:06   #6558  |  Link
LigH
LigH's Avatar
You will usually first use a preset, then a tuning (so the "animation" tuning will add 2 to the number of B frames of your preset); but if you also add an explicit bframes parameter later in the command line, it will supersede previously calculated values.
New German Gleitz board
Old 28th December 2018, 10:21   #6559  |  Link
RainyDog
Looks like we have a new AQ mode in x265 2.9+28
It scales the quantization step size according to the spatial activity of one coding unit relative to frame average spatial activity. This AQ method utilizes the minimum variance of sub-unit in each coding unit to represent the coding units spatial complexity.
Default 1.0.
**Range of values:** 0.0 to 3.0
+.. option:: --hevc-aq
+ Enable adaptive quantization
+ It scales the quantization step size according to the spatial activity of one
+ coding unit relative to frame average spatial activity. This AQ method utilizes
+ the minimum variance of sub-unit in each coding unit to represent the coding
+ unitís spatial complexity.
+.. option:: --qp-adaptation-range
+ Delta-QP range by QP adaptation based on a psycho-visual model.
+ Default 1.0.
+ **Range of values:** 1.0 to 6.0
RainyDog is offline   Reply With Quote
Old 28th December 2018, 12:57   #6560  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Seems interesting. It would be nice to hear of the cases which this new method targets.
