11th October 2009, 05:44 | #2222 | Link |
WMV update
@buzz
I'm able to encode the video portion to WMV without any more issues. Quality is good. However, I have not been able to find a 6channel wma combination that works. No issues with 2 channel, though. I'm currently experimenting with just encoding the video, mux out the audio separately (to wav files, to 5.1 wma), then remuxing the video and audio together. I'll update once the first test is completed. |
12th October 2009, 16:00 | #2226 | Link |
buzzqw, for the multithread avisynth, can you make an option to choose the number of threads we want? I find that setmtmode(2,0) causes slowdowns, probably because of some sort of latency. I find setmtmode(2,3) 30% faster (I have a quad core) than (2,0).
12th October 2009, 18:34 | #2227 | Link |
I am having an issue converting a tennis match I captured to an h.264 compressed TS file. The x264.exe passes are failing immediately with an error I don't understand:
avis [error]: unsupported input format (DIB ) x264 [error]: could not open input file 'C:\Users\Rick\Downloads\PortableApps\HDConvertToX_2.1.458.3528\job1\hdconverttox_wta.2004.kremlin.open.finals.dementieva.vs.myskina.avs' |
12th October 2009, 19:20 | #2228 | Link | |||
HDConvertToX author
best solution will be using NVTools by Neuron2 Quote:
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
12th October 2009, 19:29 | #2229 | Link |
Yes, and I believe I have successfully encoded another video via the same method.
EDIT: Yep, just tried converting another one of these captures, and the x264.exe pass started just fine. I did not, however, resize and crop this test movie like with the one I am having trouble with. Could that be causing issues? Last edited by rickatnight11; 12th October 2009 at 19:32. |
12th October 2009, 20:30 | #2230 | Link |
Hi buzzqw, I came back!) Another problem, for the first time I tried to rip film with subtitles and got this
E:\temp\job1>"D:\tools\HDC\applications\mp4box.exe" -add "E:\temp\job1\hdconvert tox_vts_01_1.h264" -fps 25.000 -add "E:\temp\job1\hdencodertox-pid3.mp4":lang=e ng -add "E:\temp\job1\hdencodertox-pid4.mp4":lang=rus -chap "E:\temp\job1\chap ters.txt" -add "E:\temp\job1\hdc_subs.idx" "e:\film.mp4" AVC-H264 import - frame size 720 x 304 at 25.000 FPS Import results: 156291 samples - Slices: 1837 I 64944 P 89510 B - 1 SEI - 1770 I DR IsoMedia import - track ID 1 - Audio (SR 48000 - 2 channels) IsoMedia import - track ID 1 - Audio (SR 48000 - 2 channels) VobSub import - subpicture stream 'eng' Unknown input file type Error importing E:\temp\job1\hdc_subs.idx: Requested URL is not valid or cannot be found |
12th October 2009, 20:54 | #2231 | Link | ||
HDConvertToX author
i will try to replicate (i must admit that mp4 isn't my preferred container) BHH
13th October 2009, 01:25 | #2233 | Link |
I didn't know mine was still under approval. It's shown as uploaded to me:
HDConvertToX v.2.2.493.3695 report Input File: c:\users\rick\videos\wta.2004.kremlin.open.finals.dementieva.vs.myskina.ts ( C:\Users\Rick\Videos\WTA.2004.Kremlin.Open.Finals.Dementieva.vs.Myskina.ts ) Codec Video: avc Width / Heigh : 1280 / 720 Framerate / Framecount: 59.940 / 242416 Duration(hh:mm:ss): 1:7:25 Aspect Ratio: 1.7778 Resized resolution: 555 / 416 Crop Values : 168:10:182:6 Start Video Configuration -> Encoding Settings: X264 Slow ; Bitrate= 899 Encoding Preset: X264 Slow ; Bitrate= 899 Final Size: 500 Denoise Level: Super Light Video Handling: Force DirectShowSource2 (Haali) -> End Video Configuration Start Audio Configuration -> Audio Codec: Copy Audio Audio Bitrate/Quality: 128 Audio Channels: 2 Normalize: On Audio handling: Use Eac3to as demuxer Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 2: ac3, 2.0 channels, 384kbps, 48khz, dialnorm: -27db, -22ms -> End Full Audio List Full Subtitle List-> (*** mean selected) *** NONE -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> ColorMatrix: On -> End Advanced AviSynth Start Muxing Options -> <- End Muxing Options Start Queue -> prompt $d $t $_$P$G "C:\Users\Rick\Downloads\PortableApps\HDConvertToX_2.1.458.3528\applications\eac3to.exe" "c:\users\rick\videos\wta.2004.kremlin.open.finals.dementieva.vs.myskina.ts" 2: "C:\Users\Rick\Downloads\PortableApps\HDConvertToX_2.1.458.3528\job1\hdencodertox-pid2.ac3" "C:\Users\Rick\Downloads\PortableApps\HDConvertToX_2.1.458.3528\applications\x264.exe" --pass 1 --bitrate 640 --preset slow --sar 1:1 --output "C:\Users\Rick\Downloads\PortableApps\HDConvertToX_2.1.458.3528\job1\hdconverttox_wta.2004.kremlin.open.finals.dementieva.vs.myskina.h264" "C:\Users\Rick\Downloads\PortableApps\HDConvertToX_2.1.458.3528\job1\hdconverttox_wta.2004.kremlin.open.finals.dementieva.vs.myskina.avs" "C:\Users\Rick\Downloads\PortableApps\HDConvertToX_2.1.458.3528\applications\x264.exe" --pass 2 --bitrate 640 --preset slow --sar 1:1 --output "C:\Users\Rick\Downloads\PortableApps\HDConvertToX_2.1.458.3528\job1\hdconverttox_wta.2004.kremlin.open.finals.dementieva.vs.myskina.h264" "C:\Users\Rick\Downloads\PortableApps\HDConvertToX_2.1.458.3528\job1\hdconverttox_wta.2004.kremlin.open.finals.dementieva.vs.myskina.avs" "C:\Users\Rick\Downloads\PortableApps\HDConvertToX_2.1.458.3528\applications\mkvmerge.exe" -o "C:\Users\Rick\Videos\WTA.2004.Kremlin.Open.Finals.Dementieva.vs.Myskina.x264.mkv" --default-duration 0:59.940fps "C:\Users\Rick\Downloads\PortableApps\HDConvertToX_2.1.458.3528\job1\hdconverttox_wta.2004.kremlin.open.finals.dementieva.vs.myskina.h264" "C:\Users\Rick\Downloads\PortableApps\HDConvertToX_2.1.458.3528\job1\hdencodertox-pid2.ac3" --title "Done with HDConvertToX v.2.2.493.3695" -> End Queue AviSynth Script -> Working with files: C:\Users\Rick\Downloads\PortableApps\HDConvertToX_2.1.458.3528\job1\hdconverttox_wta.2004.kremlin.open.finals.dementieva.vs.myskina.avs DSS2("c:\users\rick\videos\wta.2004.kremlin.open.finals.dementieva.vs.myskina.ts",fps=59.940) last = isRGB(last) ? ConvertToYV12(last) : last last = isYUY2(last) ? ConvertToYV12(last) : last LanczosResize(555,416,168,10,-182,-6) hqdn3d(1) -> End AviSynth Script |
13th October 2009, 07:12 | #2234 | Link |
HDConvertToX author
do you got any error opening the script in virtualdub ?
you are using dss2, have you installed haali media splitter ? BHH
13th October 2009, 08:58 | #2235 | Link | |
FYI. I did not recode the movie again, I just changed the container type to mkv, cleared query, added to query, copied last string (where was mkv muxing command) and ran this command in HDC temp dir and got well muxed mkv with subtitles. |
13th October 2009, 15:59 | #2236 | Link | |
--------------------------- VirtualDub Error --------------------------- Avisynth open failure: LoadPlugin: unable to load "C:\Users\Rick\Downloads\PortableApps\HDConvertToX_2.1.458.3528\filters\SoundOut.dll" (C:\Users\Rick\Downloads\PortableApps\HDConvertToX_2.1.458.3528\job1\hdconverttox_wta.2004.kremlin.open.finals.dementieva.vs.myskina.avs, line 50) --------------------------- OK --------------------------- |
14th October 2009, 01:42 | #2237 | Link |
No sound bug
@buzz
I found a bug, I think. When I am encoding to WMV, if select no audio (under audio, as well as check no sound under audio/subs tab) - the avs script still has the audio commands in it. Let me know if you need a script or report. |
14th October 2009, 08:39 | #2238 | Link |
HDConvertToX author
update hdc for shutdown problem when using queue
@whipdancer thanks, i'll check BHH
14th October 2009, 09:08 | #2239 | Link |
HDConvertToX author
@whipdancer
fixed, use live update you must select No Audio as audio codec @rickatnight11 copy libsnd dll from encoder folder to your system32 folder btw this isn't the problem... BHH
14th October 2009, 11:55 | #2240 | Link |
HDConvertToX author
@chengbin
use live update (then resave hdconverttox.ini) added possibility to specify mt mode BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
