25th March 2011, 08:00 | #13301 | Link |
If you switch the VC-1 decoder in ffdshow to "wmv9" (i think it was called), it should work. avcodec just does not support interlaced vc-1.
Other people seem to be using either the MS Decoder (considering its their own format, i would figure they do a good job at decoding it), or the Cyberlink/ArcSoft solutions.
25th March 2011, 11:51 | #13303 | Link | |
25th March 2011, 17:29 | #13304 | Link |
@Devs:
I've fixed a few typos in the ffdshow.rc: http://www.mediafire.com/?bobhnrul2i1fesq Please review and commit. Thanks! |
25th March 2011, 22:49 | #13306 | Link |
Hi all,
there was an oddity that I fixed in rev. 3789: prior to rev. 3789, all subtitles format except substation alpha formats (SSA / ASS / ASS2) could be turned on / off based on preset. however, I couldn't see an apparent reason for this discrepancy, of course preset info is not available at early loading stage, but it seemed irrelevant to this case. so in rev. 3789, substation alpha formats can be turned on / off based on preset as well. if you have such subtitles and you notice any problems with rev. 3789 or later, please let me know. b.t.w. it appears as if some other settings on this page can also be preset settings, but I'll leave it for now. Last edited by tal.aloni; 25th March 2011 at 22:52. |
26th March 2011, 09:19 | #13307 | Link |
Thanks! I see you resized the "Search in" radio button which I was about to report
There are some issues with colons in the "Resize & aspect" options, specifically "Specify aspect ratio" and "PAR out of device". Both "reach" into another control element. Not a biggie but maybe you can take a look at those. Anyway, why isn't DXVA installed by default? It should be, IMO. |
26th March 2011, 12:57 | #13308 | Link |
I believe DXVA can confuse many users who are not familiar with the technology, it's advantages and disadvantages (no post-processing, etc.), or don't even know if their hardware even support DXVA.
I think that for the non-savvy, our recommendation should be to skip DXVA usage completely, and only when there is a good reason to use DXVA, learn about it and install it, at that stage, the user will figure out for himself to select DXVA during installation. fixed in rev. 3791 |
26th March 2011, 13:03 | #13309 | Link | |
26th March 2011, 14:10 | #13310 | Link |
Updated German language file:
http://www.mediafire.com/?v10ngh2wi0mb9i3 |
26th March 2011, 20:58 | #13311 | Link | |
27th March 2011, 16:30 | #13312 | Link |
Enable subtitles
Hey, sorry for asking something that is probably really easy, but...
I just installed MPC-HC and ffdshow tryouts, because I wanted to test the superior subtitle rendering compared to VobSub. But it looks like I can't get it to work: Apparently, my subtitles are rendered by MPC-HC itself. First without effects, and after turning them on in the MPC options, they started flickering. It doesnt matter if the subtitles filter in the ffdshow tryouts config is activated or not, MPC-HC seems to ignore ffdshow on subtitle rendering. How can I connect the ffdshow subtitle rendering to MPC-HC so it works without problems? by the way, I'd prefer if subtitle effects were enabled. Last edited by V!roX; 27th March 2011 at 16:33. |
27th March 2011, 20:03 | #13313 | Link |
Update for Czech translation:
ticket 3250134 |
28th March 2011, 13:35 | #13314 | Link | |
28th March 2011, 15:36 | #13315 | Link |
Is it known problem that ffdshow has problem with interlaced MPEG2 content?
The situation: Win7, EVR, libavcodec or libmpeg2 (doesn't matter), YV12 or NV12 output (doesn't matter), haali or gabest ts splitter (doesn't matter). The problem: if "Set interlaced flag in output media type" is set to "Auto" then frame rate flows from ~35 to ~50 fps on my interlaced PAL samples, combing is obvious. If force bob deinterlacing and proper field order then there is no combing and I have proper 49-50 fps. |
28th March 2011, 15:46 | #13316 | Link | |
I use MPEG profile for output to NV12 becouse of HW deinterlacing and using it for DVB-t LiveTV. FFDshow 3775, MSVS 2010 (x86)
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
28th March 2011, 16:19 | #13317 | Link |
I have found a regression related to the recent cleanup of the Output page in ffdshow video decoder. It has broken thumbnailing by Windows Explorer. I have narrowed it down to the setting "Allow output format changes during playback" (which has been removed). Thumbnailing works when that old setting is in indeterminate state, but not when fully checked.
@stargazer69 Can you have a look at this issue? Here is a reg tweak to enable thumbnailing if needed: Code:
Windows Registry Editor Version 5.00 [HKEY_CLASSES_ROOT\.flv\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}] @="{c5a40261-cd64-4ccf-84cb-c394da41d590}"
MPC-HC 2.2.1 Last edited by clsid; 28th March 2011 at 21:00. |
28th March 2011, 18:35 | #13318 | Link |
typo lover
Hi, devs.
Why did you change Japanese transration ? r3796 changed some correct transration to wrong. Please revert r3796, and return them to Yamagata's.
my repositories Last edited by Chikuzen; 29th March 2011 at 01:29. |
28th March 2011, 20:26 | #13319 | Link | |
One problem with the current flagging algo (MatMaul's code IIRC) is that if force bob is used and field order can't be detected the auto field order falls back to bottom field first even for PAL content. Since PAL is nearly always top field first it should fall back to TFF for PAL IMHO. The optimal solution would be to improve the auto field order detection and auto flagging in general, but I don't even know if that's possible. TVs and STBs don't have these combing/field order issues though. The (automatic and not configurable) implementation in MPC-HC's libmpeg2 based MPEG-2 decoder works better for me (with JanWillem32's test build it outputs NV12 with the "set interlaced flag..." option cheked). I see no combing with that decoder with my problem sample, but it has other weaknesses compared to ffdshow, less configurable, no support for 4:2:2 sources and needs FTC to be on in MPC-HC + EVR-CP with some other samples. Last edited by Ger; 22nd April 2011 at 15:31. Reason: Added sample link and more details |
